what backspace needed for 26x12x15 tires
Old Apr 16, 2014 | 11:13 AM
MachinistMark's Avatar
Car: 85 Trans Am
Engine: 416 headed LG4 (i think)
Transmission: auto
Axle/Gears: 9 bolt, unknown ratio
Stock rear end, stock tubs
Planning on 15x10 convo pro's
Old Apr 16, 2014 | 01:31 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: what backspace needed for 26x12x15 tires
my 15x8s have a 4.5" backspace, so I would guess a 6 or 6.5" backspace would be required for a 10" wide wheel.
Old Apr 17, 2014 | 08:45 AM
Car: 85 Trans Am
Transmission: auto
What tires are you running?
Old Apr 17, 2014 | 08:51 AM
Car: 1983 Z28
I have 275/60/R15's on the rear, they fit very nicely, no rubbing or anything. Up front I have 165s on 15x4" rims but I'm over that look and plan to put the stock size on the front eventually.
*EDIT* I mistyped earlier on my front tire size, I corrected it.
Old Apr 22, 2014 | 08:36 AM
Car: 85 Trans Am
Transmission: auto
Will a 295/50/15 fit with stock wheel wells and a stock rear end on 15x8 wheels?
Old Apr 22, 2014 | 08:40 AM
Car: 1983 Z28
No, you'd have rubbing issues. 275 is the largest you should put on an 8" rim. you need a 10" rim to safely handle a 295
Old Apr 22, 2014 | 11:04 AM
Car: 85 Trans Am
Transmission: auto
OK
Would a 295 rub on a 10 inch wheel? Car has a 9 bolt and isn'tlowered.
Stock tire size is about 26 inches tall, don't want to run any taller, will make the already crappy gear ratio feel even crappier.
I just want to run the widest possible rear tire without having them stick way out of the fenders either
Old Apr 22, 2014 | 11:25 AM
Car: 1983 Z28
OK
I'm fairly certain that it would w/out air shocks or something. I THINK there was a member on here who had those for a little while but go rid of them, RonUSMC, hopefully he chimes in.
My 275's are a 28" tire, but that doesn't bother me. (I also have a 9-bolt).
You're going to have a hard time tucking 295's in nicely, 275's are about the largest that can fit however a lot of people run 255's.
IROCZ1989
Jan 24, 2016 03:55 PM
kah992
Aug 19, 2015 02:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
