What is the biggest rear tire....
Old Mar 27, 2015 | 11:55 AM
Markys88's Avatar
Car: 88 Camaro
Engine: 355cid
Transmission: 700r
Axle/Gears: 9'' w/ 4.10
Hey everyone,
Got a tire size question. I would like to know what the widest rear tire I can run on 10'' rims with a stock width differential. I can run a 29.5x10.5x15 MT slick with a slight bit of trim work on the wheel wells, but when looking up tire dimensions to equate to the slick size, nothing seems to ad up. And no two places I look them up from agree on section/tread width/ or diameter sizes. Any help is appreciated.
Old Mar 27, 2015 | 01:47 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: What is the biggest rear tire....
I'm currently running 15x8's with 4.5" backspacking and 275/60R15's. They tuck nicely and don't rub.
On a 10" you can run 295/55R15's. That would be a 28" tire. Fairly positive you MAY be able to squeeze 305's under there...maybe.
Old Mar 28, 2015 | 08:44 AM
Markys88's Avatar
Car: 88 Camaro
Engine: 355cid
Transmission: 700r
Thanks RedLeader! Would you mind sharing a picture or two of your ride so I can see what 275's would look like?
I'm trying to pack as much rubber under there as possible and use the old rims I have to boot. Thanks for the reponse!!
Old Mar 28, 2015 | 04:12 PM
Night rider327's Avatar
Car: 1988 Camaro
I run 1978 trans am ws6 15 x 8 wheels (IIRC they are 4.5" BS)
275/60-15 tires..
Here is a couple pics of mine
https://www.thirdgen.org/forums/atta...icture-575.jpg
https://www.thirdgen.org/forums/atta...d-dscf3555.jpg
Old Mar 28, 2015 | 05:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
295:55 is all i would do. It fits but may need some inner wheel well work depending on backspacing
Old Mar 29, 2015 | 04:01 PM
nd2bfstr's Avatar
Car: 91 camaro
Engine: 434 sbc
Transmission: powerglide
Axle/Gears: 9" 4.56
I ran a 8" wheel with 5" backspace with a 28"x10.5" slick. on the same wheel a 29x10.5 slick and it rubs inner fenderwell and rear gfx with bumpstop cut believe it only rub when turning has spool . just went with 15"x10" with 6.5" backspace with offset lwr control arms and wolfe mini tub. no rubbing now.
Old Mar 30, 2015 | 08:02 AM
Car: 1983 Z28
Sure thing! Here are some. Most of these pics are before the paint job. I also included a couple up close of the wheel well so you can get an idea of what that is like. I'm running a 9-bolt rear end, just fyi. I don't believe it makes any difference but it's worth noting.
Attached Thumbnails What is the biggest rear tire....-pic-1-11-1   What is the biggest rear tire....-img_20131210_192142_136.jpg   What is the biggest rear tire....-img_20131210_192025_084.jpg   What is the biggest rear tire....-rsz_image_2.jpg
Old Apr 1, 2015 | 03:48 PM
Markys88's Avatar
Car: 88 Camaro
Engine: 355cid
Transmission: 700r
Thanks for the responses and pics!!! I am putting on 295/50/15's on it this weekend and post up pics when I get it done. Thanks again.
Old Sep 25, 2015 | 12:32 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Engine: 5.0L TPI. Custom Tune
Transmission: 5 Speed/ Pro5.0 short /hurst stick
Axle/Gears: 1LE 10 bolt Rear/T2R 3.45 PBR/disc
Bumping this thread back up. i'm hopeful that the 295 fit under there for you..
Old Sep 25, 2015 | 03:20 PM
Markys88's Avatar
Car: 88 Camaro
Engine: 355cid
Transmission: 700r
I did install them and took them right back off. They were plenty wide, but too short. Looked kinda dorky to me. So I ponied up and bought 28x11.5x15 Hoosier quick Time Pros. Love the look and fit nicely. I think I may stuff a 29 under there next year. Here's a few with the new hood and rear balognies....
Old Sep 25, 2015 | 08:07 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
very nice looking car, well built!!
Old Sep 26, 2015 | 07:58 AM
Markys88's Avatar
Car: 88 Camaro
Engine: 355cid
Transmission: 700r
Thanks for the kudos! I have gotten a lot of the demons out of this thing since I bought it a couple of years ago. Rear suspension all upgraded, front end lowered and new drilled and slotted GM rotors, stainless brakelines all around, Eaton posi and girdled cover. Waiting to do rear disc swap, aluminum radiator, DeRali pan, new trans and oil coolers, and interior upgrades this winter. Got a pile of parts but not much time to work on it. Barely been out with it this year. The recent pics are on the way to car show in Perry, Kansas. Had a ball. I was the only third gen there.....
Old Sep 28, 2015 | 10:15 AM
BrianChevy's Avatar
Car: 1987 IROC Z/28
did you have any room to move the tire MORE INWARD? Seems like the 295 MIGHT be able to tuck a bit more under (only from the width perspective).
I am trying to go 315 with low profile (30) for road racing.. 315x30r18
Old Sep 28, 2015 | 02:40 PM
Markys88's Avatar
Car: 88 Camaro
Engine: 355cid
Transmission: 700r
I had a set of 29.5x10x15 slicks on these same wheels and would likely rub the outer wheel lip. I think I could go another 1'' on the inside.
Old Oct 7, 2015 | 08:13 AM
Markys88's Avatar
Car: 88 Camaro
Engine: 355cid
Transmission: 700r
I just bought these Centerlines this weekend. Wanted the Billet Specialties wheels but whoa man are they expensive. Got these for a song over the weekend. They are a 315/60/15 Mickey Thompson ET Street in the rear. Couldn't believe they fit and have room inside for more. What do ya'll think?
Attached Thumbnails What is the biggest rear tire....-20151004_154529_resized.jpg
Old Oct 7, 2015 | 10:19 AM
BrianChevy's Avatar
Car: 1987 IROC Z/28
This looks like a tight fit, but the right offset. Do you know the rear wheel width & backspace / offset of those wheels so I can verify my calculations?
How close is it to hitting the inner fender? you probably want to be careful on launch, the car will settle when launching and you might catch an edge.. (just something to watch for.)
Old Oct 7, 2015 | 10:55 AM
Car: 1983 Z28
They look pretty good, but I think their a little ballooned.
Old Oct 7, 2015 | 12:59 PM
Markys88's Avatar
Car: 88 Camaro
Engine: 355cid
Transmission: 700r
Not sure what offset they are. I do know I have at least an 1-1/2'' clearance to the inside from the tire to inner fender. They are a 30'' tall tire with close to 12'' of tread width. I know there isn't a lot of fender lip clearance, and haven't driven it much less tried to do a hard launch, but for no more than I gave for the set, I was happy to see they would fit under the car. They are a big damn tire for sure. I won't run them, but it was a cool pic anyway.
Old Oct 7, 2015 | 01:02 PM
Markys88's Avatar
Car: 88 Camaro
Engine: 355cid
Transmission: 700r
They also had 40 lbs of air in them when the pics were taken. Haven't aired them down yet to see clearance changes.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
z28addict8490
Aug 7, 2015 08:48 PM
