15x9 with 5.5 bs?
Old Dec 10, 2015 | 07:14 PM
sheikss's Avatar
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
15x9 with 5.5 bs?
Thinking of buying me some weld rts in 15x9. Weld calls for a 5.5 backspace and I would run a 275 mt on the back. I know I have to use the medium pad height since I have ls rear brakes. Anyone got an idea of how these will fit up? I don't want the tire stick out past the fender.
Old Dec 12, 2015 | 08:26 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 15x9 with 5.5 bs?
Fitment should be quite good, wheel will be under the fender with no stickout
Old Dec 17, 2015 | 05:04 PM
sheikss's Avatar
Pulled the trigger today and picked up the rears.
Old Dec 19, 2015 | 08:57 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
I doubt you can fit a 15x9 up front, but you can try a rear to see. And with the rears being a 5.5" BS, you probably can't tuck an 8.5 up front without it looking goofy.
Old Dec 19, 2015 | 09:52 AM
sheikss's Avatar
Going with these on the rear only. Going to go 15x4 on the front.
Old Dec 19, 2015 | 05:08 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
5.5 back space..your going to rub inside.. I also run a weld wheel RTS. my backs are a low pad and fit fine with the PBR calipers. and new pads..just so ya know.. when the car was new I ran weld Drag Lites. bolt on.
Old Dec 19, 2015 | 05:27 PM
sheikss's Avatar
What should I have went with?
Old Dec 19, 2015 | 05:29 PM
this is a 15x10,275 6.5 back space. Low pad. (low pad fits)
this below shot shows a 15x8 with a 4.5 back space. with a 28x12.5x15 ET street on a weld drag lite tire fits under car. no rubbing
its close to what a 275 60 15 would be.. other tires will have a stiffer side wall. you could do a 15x8.5..check fit and see.
note in the above pic the fronts are a med pad rts wheel. 15x3.5 wide..see how the stick out
below pic show what a med pad looks like on. front/back will be the same.
take a look at the lower shot.. low pad wheel nexed to a med pad wheel (RTS WHEELS)
Old Dec 19, 2015 | 06:13 PM
I would test fit. get what you want. the way you want..i know on my car. I played with dif sets and sizes of wheels.
in the end I did cut out the bump stops to fit 325 50 15s tucked under the car.
and weld wheel aluma star2.0 on the fronts..
Old Feb 1, 2016 | 05:59 AM
sheikss's Avatar
Stuck a wheel on yesterday, looks to fit perfect. Now to figure out what tire and size to run. Going to grab one of my 15x4 fronts for my 4th gen and see how that fits on the front since I have ls brakes all around.
lt1z350
Exterior Parts for Sale
Dec 30, 2015 05:55 AM
mustangman65_79
Dec 15, 2015 04:18 PM
claw87
Dec 11, 2015 07:45 PM
hartsmike
Wheels and Tires
Dec 8, 2015 11:17 PM
86CamaroDan
Dec 7, 2015 10:09 AM
