C6 Z06 Wheels installed. 19x12 18x9.5 PICS
Old Oct 8, 2017 | 10:36 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Thought i would share this info with anyone trying to do this, i didn't find much info online prior to doing it myself. For the fronts it only required 1.5" wheel adapters and clears everything. For the rears it required 1.5" wheel adapters and i had to smash in the wheel wells a bit, not too much and hard to tell in the pics, but once you have the adapters a couple of test fits and you can tell what is needed to fit, but i also had to cut the bump stops out because i did not want the wheels to stick out, im sure you can get them to fit without cutting them off and installing thicker adapters, but the wheels will stick out that much more. with my set up i have at the closest point 5/16" clearance to the lower control arms. my lca's are aftermarket boxed in style, so im unsure if this would work with stock or other style lca's.
Summary:
Front:
1.5" wheel adapter
18x9.5 Z06/GrandSport wheels +40 offset
275/35/18 tires
Rear:
1.5" wheel adapter
19x12 Z06/Grandsport wheels +59 offset
325/30/19 tires
My previous setup which fit with greater clearance and required all the same modifications to not stick outside the car:
Front:
2.25" wheel adapter
17x9.5 ZR1 wheels +56 offset
275/40/17 tires
Rear:
1" wheel adapter
17x11 ZR1 wheels +50 offset
315/35/17
Attached Thumbnails C6 Z06 Wheels installed. 19x12 18x9.5 PICS-22281547_2041023279502703_5993383872916541836_n.jpg   C6 Z06 Wheels installed. 19x12 18x9.5 PICS-22310469_2041023262836038_2424934839886986682_n.jpg   C6 Z06 Wheels installed. 19x12 18x9.5 PICS-22366355_2041023316169366_8619655579623577112_n.jpg   C6 Z06 Wheels installed. 19x12 18x9.5 PICS-22308964_2041023396169358_2677444609175541688_n.jpg   C6 Z06 Wheels installed. 19x12 18x9.5 PICS-22281584_2041023372836027_1989963718995596358_n.jpg
C6 Z06 Wheels installed. 19x12 18x9.5 PICS-22365449_2041023342836030_7924020267084852703_n.jpg   C6 Z06 Wheels installed. 19x12 18x9.5 PICS-122.jpg   C6 Z06 Wheels installed. 19x12 18x9.5 PICS-120.jpg   C6 Z06 Wheels installed. 19x12 18x9.5 PICS-123.jpg   C6 Z06 Wheels installed. 19x12 18x9.5 PICS-124.jpg
C6 Z06 Wheels installed. 19x12 18x9.5 PICS-22279479_2041036719501359_6697981246230430598_n.jpg
Old Oct 9, 2017 | 11:45 AM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Re: C6 Z06 Wheels installed. 19x12 18x9.5 PICS
Looks great, nice job!
I have have the exact same (Grandsport) wheels and tires on my Trans Am project. I have a 4th gen rear (actually a 9 inch that's 4th gen width) so it works without spacers in back. I think I have slightly less spacing up front as well.
Old Oct 10, 2017 | 09:50 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Nice setup
Old Oct 11, 2017 | 02:21 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Bulge of the tire is flush with the flair. That's just how I like them.
Looks "really" good.
18's and 19' look perfect. Gives it a little "stagger" without looking to "old school".
And a Absolutely Beautiful Car you have there.
Nice job...
Old Jan 12, 2018 | 12:00 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Could you snap a photo of the right rear in relation to how close the tire is to the panhard rod mount? I am in the middle of a mini tub install to run basically the same wheels and I think I am going to interfere with the panhard rod. It looks like you didn't have a problem. Any underside pictures of the rear on both sides would be awesome!
Old Jan 11, 2019 | 04:23 PM
JohnnyIroc's Avatar
Car: 85 TA
i just installed same sized wheels with 1.75" spacers on the rear, so i just went out to snap 2 pics. If its a 4th gem width rear you'll have no problems.
Old Jan 11, 2019 | 10:57 PM
Abubaca's Avatar
Good lookin car! ...but to be honest, I like the ZR1's better.
Old Mar 8, 2019 | 01:04 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Don't normally like anything larger than 18" for more than one reason, especially on the Camaro, but this combo looks awesome! I think bc the front is an 18, and the 19 is just used in the back where the styling of the car is conducive to a larger wheel. Now you need some really BIG brakes....
Old Mar 8, 2019 | 09:06 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Looks good Even tho not a fan fir corvette wheels
but a lot of meat out back now
