5x120 wheel spacer
Car: 1985 trans am/ 1991 RS
Engine: 355sbc/ v6
Transmission: 700r4 automatic
5x120 wheel spacer
Hi I did ls1 front brake upgrade and need wheel spacers to clear the calipers,
the closest bolt pattern I can find are these universal ones that list 5x120 and are 8mm thick, they have a 78mm inside diameter, and I believe 151mm total diameter
would I run into any problems using them? If so can anyone guide me to the correct sized spacers?
thanks
thanks
Re: 5x120 wheel spacer
Hawk's sells 'em. for use with their Firehawk's.
https://www.hawksmotorsports.com/r15...4-spacer-pair/
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
To answer the original question, yes they will work. I used a set of 5x120 slip on spacers on my 92 and there was enough wiggle room in the holes to fit the 5x120.65 pattern.
Josh R
Aug 2, 2012 11:02 AM
