275/60r15 wheels with a 4th gen rear end?
Old Jul 5, 2021 | 04:37 PM
9sinthe86TA's Avatar
Car: 1986 Pontiac Trans Am WS6
Engine: 383 Stroker
Transmission: TCI 725hp built 700R4
Axle/Gears: 94 Camaro 10 bolt. Posi 3.23
Hey, I was wondering what backspacing wheels would it take to make this tire size work? I've read forums and this seems like a common rear tire size, however, I swapped in a 94 Camaro rear end and it's like 4 inches wider. Has anyone swapped rears from a 4th gen and ran 275/60r15s?
Thanks, Sean
Old Jul 5, 2021 | 05:35 PM
Abubaca's Avatar
Re: 275/60r15 wheels with a 4th gen rear end?
I would agree that the quick math on a 4th gen rear is 4" wider, though I don't have the exact measurement. But using 4" inches...figure obviously 2" on each side, soooo each wheel would need approximately 2" more offset, which converted to mm, is about 50mm. That's what you'd be looking for, for the wheel to fit like stock.
Old Jul 5, 2021 | 07:03 PM
Engine: 383 Stroker
Yeah, I currently have a set of GTA wheels on it, and the tire is just barely sticking past the lip. Personally, I kinda like the look. But ill go out there and just take some measurements and figure it out
Old Jul 7, 2021 | 06:55 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Depends on the wheel are going to run a 15x8 or 15x10
Thanks, Sean
Old Jul 7, 2021 | 11:08 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
That 275/60-15 is pretty dang tall (28 inches)...
Old Nov 22, 2021 | 07:30 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
https://www.thirdgen.org/forums/whee...5x10-17x7.html
heres my setup
Old May 14, 2022 | 10:29 PM
Engine: 383 Stroker
Its been a fat minute since Ive been able to get back on here. But I was planning on 15x8s all around. Im pretty sure if I go 5in back spacing ill be fine. However, I have forever been in love with torque thrusts and I want a set bad. I can only find reasonably priced ones with 4.5 backspacing. The wheels now are 4.75. Im thinking a quarter inch wont be too bad, but I don't know
Old May 14, 2022 | 10:30 PM
Engine: 383 Stroker
Originally Posted by irishhockey34
Thats a badass set up you got there. I was looking for something similar, but with torque thrusts and maybe 15s all around.
Old May 15, 2022 | 12:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
15x10 7.25-7.5” bs is right for that tire with a 4th gen rear
gta324
Wheels and Tires
Jan 12, 2017 08:56 PM
utfan01ss
Wheels and Tires
Oct 15, 2014 06:14 PM
89importeater
Feb 16, 2008 08:55 PM
pasch
May 1, 2007 05:35 AM
JADIII35
Jun 21, 2005 10:15 PM
