Post pics of the underside of your car and exhaust
Old Dec 24, 2002 | 09:02 AM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
I want to see all kinds of setups
Old Dec 24, 2002 | 09:20 AM
385LT1's Avatar
http://www.abrinoperformanceengineer...member%205.jpg
http://www.abrinoperformanceengineer...s/DCP01155.JPG
http://www.abrinoperformanceengineer...s/DCP01140.JPG
Old Dec 26, 2002 | 04:07 AM
MdFormula350's Avatar
wow thats an awesome looking undercarriage!!!
Old Dec 26, 2002 | 08:38 PM
rezinn's Avatar
That doesn't look much like the bottom of a thirdgen
Old Dec 26, 2002 | 09:13 PM
385LT1's Avatar
Maybe the other project will suffice then.........
click to enlarge
there is more on my site.... Under: A.P.E. / Operation Ralley Stroker....
Enjoy...
Old Dec 26, 2002 | 11:08 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Nothing special but here goes...
Old Dec 27, 2002 | 02:46 AM
rezinn's Avatar
Sure had me fooled, looks great
Old Dec 28, 2002 | 01:57 PM
fish's Avatar
looks like one of thes tires need alittle air in it. cool system thoe. wish i had it on my RS!
Old Dec 28, 2002 | 05:50 PM
Marc 85Z28's Avatar
deadbird - Few questions for ya
1. Did you need a special crossmember for that setup?
2. That passenger pipe clearance looks REAL tight by the panhard bar brace - how does the suspension travel affect it?
3. How long are those mufflers?
Also, did you fab up that yourself, or have a shop do it? I want to try this myself after seeing this and Willie's setup. What kind of bends did you use?
Old Dec 28, 2002 | 08:04 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Not mine
Attached Thumbnails Post pics of the underside of your car and exhaust-91zexm2.jpg
Old Dec 28, 2002 | 10:35 PM
deadbird's Avatar
Engine: TPI 305/ v6
Marc.. A few answers for ya
1. Honestly, I didn't need a special x-member but, I chose to modify mine to assure I'd have at least or better ground clearance than aftermarket 3" header/y-pipe/exhaust combos. I based front/mid ground clearance off the Edelbrock TES/y-pipe setup I had on the car prior to the Hooker/dual change.
Here's what I did to my x-member to assure max ground clearance...
http://www.deadbird.org/anews/xm02.jpg
2. No matter what angle I take the picture at, it will always look tighter than it really is (added pic below). While it's not as good as the pass side, the drivers side had 2" of clearance at it's tightest point w/about 1" more I can move it up if interference is an issue. The pipe (as appears above) doesn't actully run over the panhard bar but instead, wraps the spring a clears over the outmost point of the panhard mount (the 2" clearance). In all honesty, I laid under the car for a long period of time before deciding that if my suspension compresses suddenly more than 2".. I'm going be worrying about something other than the exhaust rubbing (that would be a hell of a bump).
3. The mufflers are exactly 14½" long and are made by me. I could not find a muffler that fit my location and moderatly low noise tone requiements. They are straight through and here's all they consist of (acoustic dampening fiberglass packing/insulation not shown in pic)..
http://www.deadbird.org/anews/du03.jpg
I cut, fit and welded all of the exhaust (and x-member) myself because I am (try to be anyways) a frugal person. I used 8- 90° bends and 2- 7' lengths of straigh pipe from JCWhitney. Overall (excluding headers), to make my duals, ran just under $150.
Old Dec 28, 2002 | 11:35 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Pics........
Mufflex...............
Attached Thumbnails Post pics of the underside of your car and exhaust-myexh1.jpg
Old Dec 28, 2002 | 11:37 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
One more..........
Another shot.........Race setup.........
Attached Thumbnails Post pics of the underside of your car and exhaust-myexh2.jpg
Old Dec 29, 2002 | 07:15 AM
Marc 85Z28's Avatar
Thanks!
Now I REALLY want to attempt this...
Old Mar 17, 2005 | 11:46 PM
NEEDforSPEED's Avatar
Bump
Old Mar 19, 2005 | 04:46 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
heres mine 2 3inch pipes into one 4inch pipe into a flowmaster
you can see the rest at.
http://datrcom.org
Attached Thumbnails Post pics of the underside of your car and exhaust-c-documents-settings-darcom
Old Mar 19, 2005 | 11:40 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
dual 2 1/2"
Old Mar 23, 2005 | 02:08 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Hooker LT's, 3" pipes into 4" Y collector then back down to 3" Blowmaster exhaust. The y-pipe is dented in for extra clearance under the crossmember... I have not managed to scrape this exhaust on anything
Attached Thumbnails Post pics of the underside of your car and exhaust-exh1.jpg
Old Mar 23, 2005 | 02:14 AM
does any have sound clips?
Old Mar 23, 2005 | 07:20 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
mine has sound clips you can hear them here.
http://www.darcom.org/darcom/darcom/darcom_006.htm
Old Mar 24, 2005 | 09:20 PM
[VU]Juan's Avatar
Car: 84 TransAM
Engine: Chevy 355
here's my setup, true dual 2" pipes all the way, then flowmaster 40 series dumps.
here's the sound clip for it...
http://www.virtual-underground.com/p...ta_exhaust.wav
Old Mar 27, 2005 | 11:18 AM
iamiroc's Avatar
Car: 1988 camaro iroc-z28
Engine: 305 tpi
heres mine
new flowmaster kit
Old Mar 27, 2005 | 12:08 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
not on my car yet..
Old Mar 27, 2005 | 03:56 PM
Car: '89 IROC-Z
I'll try to get a sound clip of my car tonight. I've attempted several times but even standing 30+ feet away my crappy digital cameras sound is too sensitive and gets distorted by the "drone" of the Blowmaster
Old Mar 27, 2005 | 04:52 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
http://datrcom.org
very interested in some more info on your set-up. please send me a PM with as much info as possible.
Old Mar 27, 2005 | 08:13 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
it has hedman hedders with 3 inch collectors then to 3 inch pipes going around my frame and the spohn torque arm into one 4 inch pipe to one 40 series flowmaster
you can see all about my car at:
http://darcom.org
Old Mar 27, 2005 | 08:35 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
http://darcom.org
do you happen to have the part number of those headers? is there anything you would do different if you were to do it agian?
Old Mar 27, 2005 | 08:53 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
headman hedders part number #68460
this is the best ehaust i have ever had performance wise ,i started out with a stock exhaust witch was a stock 3 inch setup then put a flowmaster,then added edelbroks hedders. then i went with these headman headers with a duel pipes into two dyno max muflers .then to my current setup with is the four inch. every thing incresed with this setup 1/4 mile times and big notice in gas mileage.
Old Mar 28, 2005 | 05:22 PM
jbqualls's Avatar
Car: 2001 Z28 camaro
Dynomax 3" setup
Attached Thumbnails Post pics of the underside of your car and exhaust-c-documents-settings-qualls
Old Mar 31, 2005 | 01:22 AM
onebinky's Avatar
Here's my car with the most recent dual setup. I swapped to a T5 though, and couldn't get the header clearance I wanted near the bellhousing so I swapped out the hedman LT's for shorties. The dual setup wouldn't fit at all then, and I wasn't about to do a third dual exhaust setup. I have a 3" hooker cat back minus the cat now
Attached Thumbnails Post pics of the underside of your car and exhaust-underclean1.jpg
Old Mar 31, 2005 | 06:09 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
3" duals
Attached Thumbnails Post pics of the underside of your car and exhaust-dualies-004.1.jpg
Old Mar 31, 2005 | 06:10 AM
I Know it was a bad picture..
Attached Thumbnails Post pics of the underside of your car and exhaust-dualies-002.1.jpg
Old Mar 31, 2005 | 06:11 AM
crude but effective...
Attached Thumbnails Post pics of the underside of your car and exhaust-dualies-0051.jpg
Old Mar 31, 2005 | 06:13 AM
believe it or not it runs faster 1/4`s with the pipes on...
Attached Thumbnails Post pics of the underside of your car and exhaust-z28-exh-012.1.jpg
Old Apr 2, 2005 | 04:05 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
What kind of headers are those?
Justin
Old Apr 2, 2005 | 04:28 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
greezemonkey's headers are the hooker BBC swap headers
here is some of mine:
http://www.cardomain.com/memberpage/437351/4
Old Apr 2, 2005 | 08:15 PM
5.0Camaro's Avatar
yea wish they made them like that for the SBC would make it a lot easier to route the exhaust with the spohn torque arm.
Justin
Old Apr 2, 2005 | 08:25 PM
klumb15's Avatar
for the guys that have LT headers and a single pipe catback style exhaust, do you make a custom y pipe or does a company sell one that works on our cars??
Old Apr 2, 2005 | 08:38 PM
5.0Camaro's Avatar
It would have to be custom.
Justin
Old Apr 3, 2005 | 08:19 AM
mw66nova's Avatar
Engine: 7.0L
mufflex makes a y-pipe to fit the sbc hooker headers, but for the hedmans, your on your own.
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
Linson
Aug 21, 2015 02:12 PM
penguinpanda0
Aug 15, 2015 06:45 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
