advantages of a single exhaust over a dual exhaust
Old Apr 3, 2005 | 03:26 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
other than ground clearance, cause i have longtubes and the y-pipe would still hang a bit low, what would the advantages of going to a single large 3" or 3.5" pipe over a dual 2.5" exhaust be, anything?
Old Apr 3, 2005 | 03:37 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Less weight.
Old Apr 3, 2005 | 03:59 PM
mw66nova's Avatar
Engine: 7.0L
my system doesn't seem to weigh that much, and you know how much more reduction i need to do
basically, i need someone to convince me to go back to a single system. i'm think velocity/scavaging type stuff. any effects? i have an h-pipe in my system so...
Old Apr 3, 2005 | 04:55 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I did say keep the duals... but hey- if you want to go back to a single throat go with that mufflex 4inch sewer pipe and a spintech..at least you will still be able to wake the dead
Old Apr 3, 2005 | 05:32 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
pros? hmm well most custom dual setups on these cars looked stupid and rigged. i said most, i think willie has the only one that i like.
Old Apr 3, 2005 | 05:34 PM
mw66nova's Avatar
Engine: 7.0L
even though i did an extremely good job at tucking the pipes and everything, this right here is the reason i am considering the single pipe. i think that with a catback, the car doesn't look quite so backwoods. being that the car has no gfx and has huge back tires, this is an image i am trying to avoid.
Old Apr 3, 2005 | 05:45 PM
I think you did a good job on the exhaust ( fitment wise) it`s not the sweetest system around but it get`s the job done. I think you going to see all of the single system too though..I always spot the cat and pipe riding the outside of the frame on 4 & 6 bangers. without GFX your going to see it I think..and I know how you feel about those It would look nice lower and if the exhaust is the problem, well, you know what to do.
Old Apr 3, 2005 | 05:55 PM
mw66nova's Avatar
Engine: 7.0L
i have longtube headers though, so a y-pipe is going to run right....
screw it, i'm keeping my duals. i love the sound.
Old Apr 3, 2005 | 05:58 PM
You just put a big smile on my face
Old Apr 3, 2005 | 08:46 PM
Slag02's Avatar
Car: 85 Suburban
Transmission: TH400
Exhaust is like Women.... Two are always better than One.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Djmathis123
Sep 8, 2015 08:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
