Who has 275 tires on the back?
Old Feb 3, 2003 | 09:53 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
what size rims, what backspacing and what did you do to the car to make them fit?
Steve
Old Feb 3, 2003 | 02:32 PM
Camaro1991RS's Avatar
I had 275/60/15 tires on stock rims on the back of my Camaro when I bought it.
Old Feb 3, 2003 | 08:05 PM
406-Z's Avatar
Car: 87 IROC Z-28
Engine: 406-Mini Ram-AFR 195's-DFI Gen 6.32
Transmission: 700-R4 w/Art Carr converter
Axle/Gears: 9" - 31 spline - 3:89
Got 285/40-17 BFG KDW on the rear with Centerline Saber and 5" backspace.
Old Feb 4, 2003 | 12:02 AM
Kandied91z's Avatar
295/35/18....don't know the backspacing but they are a +58mm offset and 10.5
Old Feb 6, 2003 | 11:00 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
i have um 275/65-15's on the back of my car on 15x8 rim 4.5bs 0mm offset Draglite.
Hope that helps. if you go with like what i have rolling the rear lip is a good idea but does not have to be done and they fit fine.
Old Feb 7, 2003 | 05:37 PM
TwnTrboZ28's Avatar
I have 275/60/R15 tires on 15x8 wheels. I put air shocks on the rear so my fenders don't rub. works great.
Old Feb 7, 2003 | 09:21 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
275/40/17 on a 17x9.5 Rim with 7" Backspacing.(4thGen Rear)
Old Feb 7, 2003 | 09:49 PM
CAMARO85500's Avatar
You can go with a 10 inch rim 5.5 back spacing.
http://camaro85.homestead.com/page1.html
Old Feb 8, 2003 | 09:26 AM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
i use a 295/50/15 on stock 15inch z28 wheels on my 86 camaro
Old Feb 9, 2003 | 07:20 PM
RICHRAD's Avatar
Holy Ssh-moley! got a pic of that!
Old Feb 9, 2003 | 07:35 PM
85_ZED28's Avatar
Car: '85 Z28
Ya i wannna see a pic!
Old Feb 10, 2003 | 04:08 PM
Kontrax's Avatar
Car: 86 Camaro
there ya go. they don't rub eather. pretty cool huh?
Old Feb 10, 2003 | 09:07 PM
Shagwell's Avatar
Car: projects.......
Wholy Crap! - I didn't think 295/50's would fit under the car on stock rims. - oh well. Doesn't help me much having 16" GTA wheels. I'll be running 295/50/15's on the back as soon as I get my 15x10 convo pro's though...
thanks for the insite...
Old Feb 10, 2003 | 09:42 PM
I had 295 on ten inch rims when I bought my car.Before I put mickeys on mine.I have 13.5 inch wide tires on there now.
Old Feb 11, 2003 | 01:02 PM
darbleinad's Avatar
Car: 84 Trans Am
those rims are 15 x 7 inch? i am amazed that the 295/50/15s fit on the rims so well and dont bulge out. those seem to fit as well as my 255/60/15 tires. any tips on how you got those tires to fit on to the rims so well? and the tires dont rub or anything? thanks.
Old Feb 11, 2003 | 03:25 PM
Kontrax's Avatar
Car: 86 Camaro
no the tires don't rub at all. i work at a custom wheel shop and we do all sorts of tire/wheel combos on cars. had a set of 295's in the shop and i mounted them on to see if they would fit and they did no problem. my shocks and springs are also gone on the car. its on the trailor in the pic because its going to get the radiator support welded in this week, then off to my shop. going to put 2002 ws6 springs in the rear with my air lift and KYB shocks.
Old Feb 12, 2003 | 12:03 PM
pecha's Avatar
Car: 98 T/A
Engine: ls1
295 at the back of my last car - 91 Firebird (TBI) and no rubbing!
Old Feb 12, 2003 | 02:26 PM
darbleinad's Avatar
Car: 84 Trans Am
and these 295 width tires fit fine on 15x 7 rims, not bulging out or sidewalls getting to squishy?
Old Feb 12, 2003 | 03:28 PM
pecha's Avatar
Car: 98 T/A
Engine: ls1
darbleinad they were ok
the other thing is that I had this car for a week and then I sold it so I might get not the best feeling of it
well they smoked good as for one_wheel_wonder
Old Feb 12, 2003 | 04:35 PM
darbleinad's Avatar
Car: 84 Trans Am
hahhaa...nice...i like that picture
Old Feb 12, 2003 | 05:20 PM
RICHRAD's Avatar
Most 15" tires will fit a 15" x 7" rim. A 295/50 should only be mounted on an 8.5" or wider rim according to manufacturer. Don't let the photo fool ya. There is extreme sidewall tapering going on there. It makes for a weak mounted tire most likely....
Old Feb 12, 2003 | 05:25 PM
darbleinad's Avatar
Car: 84 Trans Am
hehehe...thats why i asked the question twice. for exmaple BFG recommends nothing bigger wider than 255/60/15 tire on a 7" wide rim. now i know that they just covering their asses and you can go a little wider without any sidewall problems, but 295 seems way to wide for a 7" rim. however, in the pictures there doesnt appear to be too much sidewall flex/tapering......so i am not sure what to think about this. seems like some of these guys have had really wide tires with no problems......
Old Feb 13, 2003 | 09:05 PM
RICHRAD's Avatar
Go for it ...but keep them underinflated so you'll get some decent tread wear
Old Feb 15, 2003 | 09:07 AM
Kontrax's Avatar
Car: 86 Camaro
i've been working as a service tech for years now. there is nothing wrong with 295/50's on a 15x7 wheel. i don't know who told you to use 8.5 and above but thats not right. as you can see the 295's fit fine on the 15x7's. i don't see how a photo would be fooling anyone if its real....i wouldn't have commented on the topic if i didn't know anything about it
Old Feb 15, 2003 | 09:03 PM
RICHRAD's Avatar
let me restate "according to most automotive tire manufactures websites" ....'nuff said
Old Feb 16, 2003 | 03:14 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Transmission: broken
how abou 295/40R17 or 285/40R17 on a 17x9.5" rim?
Old Feb 16, 2003 | 03:40 PM
Kontrax's Avatar
Car: 86 Camaro
on a 17, the biggest you can go is a 315 with the right backspacing without tubbing the wells.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
