350 tranny swap
Old Dec 7, 2002 | 08:14 AM
zboss86's Avatar
350 tranny swap
What are people doing about the torque arm mount when they swap to a 350 tranny from a 700r4?
I take it we have to change shifters also...
Old Dec 7, 2002 | 08:50 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Re: 350 tranny swap
dont have to change the shifter, though it is prefered
B&M and Hurst both sell a torque arm bracket
its about $90 from jegs
Old Dec 7, 2002 | 09:17 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Axle/Gears: 3:73 Posi
Iam not 100% positive here. but I think I had over heard that you can change the tailstocks on the th350 and the 700r, like I said I am not positive on this. BUt have heard of it being done. ANyone??????
Old Dec 7, 2002 | 01:43 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i dont think you can swap tails due to speedo gear location differences plus cant guarantee the 4 bolt holes align from 700 to 350, if they did then id think theres no point in B&M having bracket for this
good luck
Old Dec 7, 2002 | 02:54 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i think hes talking about changing the tail shaft on the th350 from 6" to 9", i don't know if you can but it will save you from buying a new driveshaft. i used the b&m kit for awhile but if you are making some power i'd go with the spohn or bmr setup. with the arm bolted to the back of the tranny my drivetrain flexed so much on shifting that the front u-joint was hitting the tunnel. you can use the stock shifter but the letters might not match up , do it by feel.
Old Dec 8, 2002 | 08:17 AM
zboss86's Avatar
hmmm...
I've been wondering about that mark above that ujoint. Hell, I never thought about that dude flexing that much. The ole 408 does have some torque now.
Say Summit or sombody does have a kit torque arm kit that you can put a torque arm mount on a 350 tranny though...
xkingcodex
Feb 12, 2020 07:43 PM
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
crazynights
Aug 21, 2015 06:53 AM
