4th gen rear in 3rd gen..again...
Old Jan 21, 2004 | 01:16 AM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
Alright iv done a search on this and what i got is some yeah itll work....but i want to know for sure....the rear end is a direct bolt in? exept its just a little longer.... so the driveshaft is the perfect length, stock 3rd gen torque arm will work, now what size rear are in the newer camaro's? and how much stronger are they? they must be pretty good if they hold up with the more powerful motors.... i need some definate hard information about this before i go ahead and do it. plus how hard is it to convert from rear drum to disc? alot of work involved?
Old Jan 21, 2004 | 03:51 AM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
RE:4th gen rear
I just finished with the fourth gen rear swap in my car. Everything is a direct bolt on. Stock Driveshaft=yes, although this would be a good time to get an aluminum piece. Stock torque arm=absolutely. The rears in the newer generations are the exact same ten bolt rears as the ones in ours except they're longer. IIRC they don't handle any more power either, about the same. As far as drum to disc, I would suggest getting the entire rear end with brakes and all. It'll all work with your car.
Old Jan 21, 2004 | 06:01 AM
ede's Avatar
ede
any 3rd or 4th gen f body rear will work, direct bolt in. some brakes are differant. there is no strength differances between 10 bolts reguardless of what year they came from
Old Jan 21, 2004 | 12:21 PM
Car: 85 Camaro Z-28
Engine: 6.6
Even if it was from a 2002 SS? with 3.42's and posi.... if theres no difference in strength why do people swap them and how come then run the LS1's with these rears? and mod them.....
Old Jan 21, 2004 | 01:07 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yes.even from a 02 ss
people swap them because they're cheap upgrades...
they're cheap upgrades because LS1 owners can easily frag them, so they swap em out for 9" or 12bolts instead....
to the 4thgen owners, they're useless... heck i had one GIVE me a 3.42 posi disc rear, and i didnt even ask for it.
Old Jan 21, 2004 | 01:15 PM
Car: 85 Camaro Z-28
Engine: 6.6
how is it considered an upgrade if its no better than the stock 3rd gen ones tho? i maybe misunderstanding whatyou mean but if it can handle bolt ons for an LS1 running 12's-13's shouldnt it be better? my brothers snapped with a posi slicks running a 13.30
Old Jan 21, 2004 | 01:19 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i can blow them up with a stock l03 if i had slicks...... traction is what kills them... normally the tires will spin before enough power goes thru em to blow.... once you have massive traction, then they start breaking.
its a upgrade because alot of 3rdgen owners got bad gear ratios, no posi, and drum brakes..... by putting this on, you can get better ratios, a posi, and discs.....
the strength diff is ZERO. the actual diff is exactly the same... the ONLY diffs between the 4thgen and 3rdgen ones are:
  • longer axle tubes
  • longer axles (because of the longer tubes)
  • diffrent brake mounting flanges (for the diffrent 4thgen brakes)
other then that, they're identical to the late 3rdgen ones... like whats in my 91.
Old Jan 21, 2004 | 07:29 PM
bEtUr4dRustang's Avatar
I disagree.
The axle out of 4th gens have 28 spline axles while the pre-88 cars only had 26 spline.
Also, a 2002 SS camaro has a Heavy duty zexel torsion unit which is a clutchless positraction type device and is much much stronger than any third gen stock posi. SS's run low 13s or high 12s stock. These axles hold up perfectly well to 11.5 second passes.
I will agree that there is near little difference between a non SS and a third gen axle except for the 28 vs 26 spline though that only applies to the weaker pre-88 axles.
Old Jan 21, 2004 | 08:35 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Didnt the 2002 SS's have the upgraded AUBURN posi unit? I believe the Zexel torsen is the take off unit that they have to sell used now.
Old Jan 21, 2004 | 09:46 PM
As far as I know, you can order it either or, but i think someone else should back me up on that before you take it as fact.
Zexel does make two models of their torsion unit, the regular one and the heavy duty. The regular Zs get the regular duty one and the SS's can either get an Auburn or the heavy duty Zexel.
Old Jan 22, 2004 | 01:24 AM
Car: 85 Camaro Z-28
Engine: 6.6
i am kinda planning on buying this one from the guy, he said this.I have a 4th gen rear axle out of a 2002 SS camaro. The camaro now has
a 12 bolt. The fact that it is out of an SS means it has the heavy
duty Zexel Torsion unit installed by SLP. This "posi" is an amazing unit
and requires no posi lube to be added to the differential oil. It has
3.42 gears and is in perfect condition. There are roughly 3500 babied
break-in miles on the rear end. LS1 guys are running in the 11s on slicks
with these rears, something which a non SS rear has a lot of trouble
doing.
is this true? i think he sounds like he knows what he's talking about. he said it before i even posted about it.
Old Jan 22, 2004 | 02:37 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Also, most people swap them if they are running 4th gen offset wheels as 3rd gen wheels will stick out like this,
Old Jan 22, 2004 | 04:06 AM
Car: 85 Camaro Z-28
Engine: 6.6
but is it true about his rear axel??
Old Jan 22, 2004 | 04:37 AM
Frains90RS's Avatar
Car: 1990 Camaro RS
Oops.
Forgot about the SS part. Betur4d in right on.
Old Jan 22, 2004 | 08:01 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
yes the SS and firehawk cars got a diffrent posi.... but if you wanted to (and could find one) you could bolt that exact same posi in your 3rdgen housing.
like i said, same rear.
Old Jan 22, 2004 | 12:41 PM
Car: 85 Camaro Z-28
Engine: 6.6
so this SS unit is stronger, so itll handle 4-5k rpm off line starts? with slicks? even tho there both 7.5's are the ring and pinion weak in them? i mean he wants a pretty penny for that rear, so id ont want to put it in, and it not hold up.....
Old Jan 22, 2004 | 01:48 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
the 7.5 rear is the older design,they are 7-5/8 with the 28-spline axles...
Old Jan 22, 2004 | 10:23 PM
jaderagtop's Avatar
Woah, woah...hold the phone....
WHY ON EARTH do you think that you need to launch at 4,000 RPM? If you have an engine that starts making peak power at '4-5k' RPM, you're definitely gonna need something A LOT stronger than a 4th gen rear... I hope you're planning on revving to 11k RPM, too, because there's not much point in launching at 5000 and shifting at 6000... considering a well-built and balanced "race" 400 redlines at about 6,000. It makes good power too...and you've got a T5? Not for long, you don't...
Chris
Old Jan 23, 2004 | 12:29 AM
Car: 85 Camaro Z-28
Engine: 6.6
i shouldnt have to explain, ill let others do the B!tching......all i want to know is if the 4th gen rear is any good for me....
Old Mar 30, 2004 | 03:17 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
hi
so if i got the forth gen rear assembly the wheels from a fourth gen fit perfect in the rear like they do on the fourth gens, and if so can i get those 11 inch wide zr1 wheels that rock so much butt, also that picture above that shows the wheel and tire sticking out is that a stock third gen wheel on a fourth gen axle assembly?
thanks guys
Old Mar 30, 2004 | 03:22 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: hi
thanks guys
thats a 3rdgen car, 3rdgen rim, with a 4thgen rear.
Old Mar 30, 2004 | 04:49 PM
Zepher's Avatar
The above image is a 3rd gen wheel, but not a stock one, it's an American Racing 16" wheel.
Old Mar 30, 2004 | 05:07 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Re: hi
thanks guys
With fourth gen wheels (ZR1's), the wheels will fit perfectly. if theyre going to be 11" wide, though, ull need to do some modifcations in the well. Do a search and you'll find out how. Otherwise, they'll go perfectly with the car.
Old Mar 30, 2004 | 07:44 PM
Engine: 350ci
more questions
all righty
in the front the spacers are still needed for the fouth gen wheels or is there a certin back spacing i can get?
rear, if i get a fourth gen rear say out of a v6 camaro/firebird and i happen to get disc brakes, what alteration do i need to make to my stock rear drum system, bigger master cylinder, booster propotioning valve, what do i need and if you know prices or links to show me where to buy these things if i need them thatd rock hard core.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
