Ws6 immediatly shuts off help
Old Oct 26, 2004 | 03:04 PM
Calico's Avatar
Car: 1985 Buick Regal T
Engine: 87 3.8 turbo/lc2 drive train
Transmission: 200r4brf
Yesterday after I was done changing my oil my T/A would crank over but it would immediatly shut off..checked the batt connections they are good...I didn't add to much oil... I was thinking it might be a fuel related problem?Oh yeah I'm gonna check the maf now! Anyone have any ideas?
Old Oct 26, 2004 | 03:11 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Fuel pump priming?
Old Oct 26, 2004 | 03:13 PM
vernw's Avatar
Axle/Gears: 4.11 posi Ford 9"
Any chance youi knocked off the electrical connection for the oil pressure sender right above the oil filter? I believe if the ECM doesn't see oil pressure it will shut down after a few seconds....
Old Oct 28, 2004 | 09:11 AM
Calico's Avatar
Naw I figured it out...my fuel pump went...any ideas how to replace it?
Old Oct 28, 2004 | 12:25 PM
pasky's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=265285
https://www.thirdgen.org/techbb2/sho...hreadid=264787
Im sure someone else can explain the real way on dropping the gas tank. But honestly im not gonna look, just do a if you don't want to do the trap door.
One thing I would do before ruling its the pump....Change the relay.
Old Oct 28, 2004 | 08:17 PM
Calico's Avatar
whats up pasky...I searched but came up with nothing...also what relay are you talking about?
Old Oct 28, 2004 | 08:19 PM
vernw's Avatar
The fuel pump relay
Old Oct 29, 2004 | 09:18 AM
Calico's Avatar
ok gentlemen how do I check the relay and where is it located?
Old Oct 29, 2004 | 12:55 PM
Damon's Avatar
It's one of the relays up under the hood near the power brake booster. I don't remember which one and they were different for different years/engines. I suppose you could pull one at a time and when you no longer get the fuel pump to prime when you turn the key then that's the one.
Old Oct 29, 2004 | 07:00 PM
Calico's Avatar
checked the relays they are good!
Old Nov 1, 2004 | 08:42 PM
Calico's Avatar
what up I'm about half way through taking my car apart! A great learning experince....I've got the exhaust off...Track bar off, track brace off, disconnected all fuel lines, the harness, now I'm taking off the rear sway bar...What will happen if I run the car with out the cat? Also there is a gold emmisions line the connects to the cat...what does it do? what will happen if I gut the cat?
Old Nov 5, 2004 | 09:03 AM
Calico's Avatar
just dropped the fuel tank and replaced the fuel pump...the car does the same thing...Any ideas now?fuel pump is fine I here it working...the fuel lines have fuel going thru them but I think its clogged some where...I think its the fuel filter
Old Nov 5, 2004 | 10:50 AM
Damon's Avatar
Early on your metioned checking the MAF but you didn't say if you got around to that (or how you checked it if you did).
As a quick and dirty test for a bad MAF to just unplug it and try starting the engine. If the MAF was bad the engine will now run, but the check engine light will be on, obviously. A start and immediate stall is classic bad MAF symptoms.
Old Nov 7, 2004 | 10:59 AM
Calico's Avatar
ok I'll try that thanks later on today
Old Nov 9, 2004 | 08:57 AM
Calico's Avatar
I unpluged the maf tried it the car still won't run...It turns overs but turns off immediatly
Old Nov 9, 2004 | 11:32 AM
vernw's Avatar
In-line fuel filter clogged?
Old Nov 9, 2004 | 01:08 PM
Damon's Avatar
I'm wondering if the fuel pump is being shut off because the ECM isn't seeing any oil pressure or RPMs (or something similar). ECM fires up the fuel pump automatically when cranking over with the starter but once it starts and begins to run on it's own the ECM looks at some stuff to keep the fuel pump running- I beleive an RPM signal from the distributor and oil pressure from the sender above the oil filter. Others could probably tell you exactly what it looks at, but those 2 jump to mind.
When you have this "start and then stall" does the fuel pump shut off and cause the engine to stall? Might be a good idea to put a FP gague on it and watch if you've got fuel pressure once it fires up. It's gotta be either fuel or spark- the engine wouldn't fire up if it was a mechanical problem inside the engine.
Old Nov 9, 2004 | 01:13 PM
Damon's Avatar
BTW- I'm starting to get a sinking feeling about this. I've been through threads like this before. It usually ends up with something like this: "So I tightened the license plate bolts and the engine suddenly started running perfectly again!"
In other words, it ends up being something that couldn't possibly have been figured out by reading the thread. I mean, other than knocking the connector off the oil pressure switch above the oil filter (or breaking the sender itself) there is just NO WAY an oil change could cause a problem like this. Are we getting the WHOLE story here?
Old Nov 10, 2004 | 08:14 PM
Calico's Avatar
electronic control module
Yeah I've been updating this thread as I do something...like today I pulled the ecm...Its not fuel related...is throwing a weird security code nac or noc or something like that...the ecm most likely isn't sending signal to the injectors to fire properly...so were testing the ecm
Old Nov 15, 2004 | 03:49 PM
Calico's Avatar
I replaced the ecm but retained the old prom! The car is throwing this weird anti-theft code...the car will start then shut down! Does anyone know about the security codes in these cars?
Old Nov 15, 2004 | 06:26 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
I know there are 15 different Vats security codes. If u think its a security reason; your car would even try to turn if your vats was working properly.
So I really doubt its that, and I also thought vats didnt come out till 89??
Old Nov 16, 2004 | 09:32 AM
Calico's Avatar
it throws a security code i have no idea wht it is
Old Nov 16, 2004 | 09:40 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
oil change should not cause this problem.....
how was the car running before the oil change? did you put oil in it? do you have oil pressure? is you oil pressure sender hooked up and working? did you do plugs or anything at the same time.
jeff
Old Nov 16, 2004 | 04:52 PM
Calico's Avatar
i'm gonna check the lock cylinder
Old Nov 17, 2004 | 04:27 PM
Calico's Avatar
Code 46=VATS
Its coming up code 46...which is the code for VATS or the vech Anti theft System
So far we tested the key they are both good...The 5 volt input to the computer is good the 12 volt on the power input is good! Is there a way to by-pass the vats system? what should I do is there some sort of procedure? Also where is the Vats Control Module located?
Old Nov 18, 2004 | 11:47 AM
Damon's Avatar
If it was the VATS system I don't beleive it would even try to start. When I had a VATS problem on my Camaro absolutely NOTHING would happen when you turned the key. Not even a click. VATS only deals with starter de-activation, to my knowlege. I don't think it will shut off an engine once it's running. Perhaps someone more knowlegable could chime in on this.
Old Nov 20, 2004 | 09:20 PM
Calico's Avatar
It was the vats changed the ignition cylinder and key cranked it over and went cruising thanks guys The Don appreciated your help no more bumming rides from my little sister:rockon:
Old Nov 21, 2004 | 08:18 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Weird...I also would have thought that VATS only disables a car from starting. When we were working on David's the other day and he turned the key, it jsut wouldn't start. All the lights would come on as normal but it would say "SECURITY" or "ANTI THEFT" whichever and nothing else....so he hotwired it
Though I suppose if it were malfunctioning, it could cause an issue like this especially since it was throwing the code...
Old Nov 21, 2004 | 08:22 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I thought VATS started in '89. :shrug:
Any way, the easiest way to check the fuel pump for basic function (ie turns on and test static pressure) is to put 12v to the G terminal in the ALDL. I wish people would do that before going nuts with everything else.
Old Nov 21, 2004 | 08:30 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Roughly 2/3 of GTA's received VATS in 1988. I know on my 1989 I dropped my key in the snow and my car would not crank. I guess 1988 was different?????
Old Nov 21, 2004 | 08:42 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
UA6. No kidding. Was it only the GTA's (only thing I can find RPO data on) and Vettes (IIRC they did start in 87 or 88) that got the UA6 option in 88? I would think it would operate the same as well. From reading the initial posts I was originally leaning toward a MAF relay. :shrug:
Old Nov 21, 2004 | 08:51 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
For reasons never explained to me the Camaro never received UA6 until 1989.
I guess his ignition must have been worn enough that an intermittent connection was being made at the resistor. I have heard of wires breaking behind the cylinder and shorting out as well. Ah the joys of 15 year old cars
Old Nov 21, 2004 | 08:54 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
It was probably finding a less resistant path to follow.
Maybe someone in DIY could pipe in if they ever came across any difference in the years for VATS. :shrug:
Old Nov 23, 2004 | 03:34 PM
Calico's Avatar
no It never even showed the security or check engine lite just threw a code 46...dunno
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
Gunner242
Dec 25, 2015 04:49 PM
ironbmt
Sep 27, 2015 06:00 AM
