TPI Swap help
Old Nov 19, 2004 | 11:23 PM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
TPI Swap help
I am swapping the TBI on my 91 RS to SD TPI from a 90 bird.
I have the harness in the car and have noticed the pinouts on a connector are different from the old harness, however I cannot figure out what this connector is for. Can anyone tell me what is the white fourth connector by the three ecm connector is for, and where i can find a pinout for that connector? I cannot continue until I figure this out. I have looked everywhere....
Old Nov 19, 2004 | 11:56 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
What type of harness is it? Is it a flat or square connector and how many terminals?
Old Nov 20, 2004 | 12:05 AM
vette9190's Avatar
Its a factory GM SD TPI harness from a 90 bird. The a rectangle shaped conntector with two rows. I will have to check the number of terminals , it is now afet midnight here so it will have to wait till morning
Old Nov 20, 2004 | 09:00 AM
JP86SS's Avatar
Instrument Panel
Sounds like the I/P connector for the right hand side of the dash.
there's a couple of posts about it. I'll see if i can put a link.
Jp
edit:
https://www.thirdgen.org/techbb2/sho...%2FP+connector
Check the info carefully against your setup to be sure the pinouts match.
Old Nov 20, 2004 | 10:41 AM
vette9190's Avatar
Thanks for the link that was just what I needed.
Just one more thing, anyone have the pinouts for the other side of the connector. the one in the car for an LO3 car. That way I know which wires are going to have to be repined,
Old Nov 20, 2004 | 12:58 PM
vette9190's Avatar
Different pinouts
This is what my pinouts on my harness and car are. The harness is Stock GM speed density TPI 1990 Pontiac Firebird(I was Told when I bought it), The Car is 1991 Chevy Camaro RS that had TBI on it.
Pin harness car
A NA Brn
B Pnk/Blk same
C Brn/WH same
D Brn NA
E White/Blk same
F Pnk/Blk same
G Pnk/Blk same
H Tan/BLK same
J orj same
K NA Brn
L Blue same
M Blk/Wh Orj
N Orj/Blk same
P Red NA
R NA PPL
As you can see these are different from what is in the links above.
Old Nov 20, 2004 | 02:39 PM
JP86SS's Avatar
That's why its good to check them agaist YOUR car.
There are alot of variances but most have the same functions, just on different pins.
Jp
Old Nov 20, 2004 | 02:55 PM
vette9190's Avatar
OK
I have pins A- J figured out, also I have Pins L and N figured out
pin K on the car is VSS related no pin on harness side that I could find, also pin R on car is Vss related but no pin on harness I could find.
Pin M on harness is ecm ground but I do not know what it is on the car side the wire is orange so I don't think its ground.
PIN P on harness a red wire- I have know clue what its for.
Please help me with these this is the last thing I have to finish for the swap before I start trying to start it and burn chips.
Old Nov 20, 2004 | 03:06 PM
JP86SS's Avatar
orange is "usually" ECM backup power.
The red one has me stumped. I'll look through some more notes.
FOUND IT !
P= (red wire) is the VSS to curise control module.
J= orange could be serial data output from the ecm to the ALDL pins M & E both connected to it.
http://www.wideopenwest.com/~JohnandRuth/9092wire.zip
download this file (Ms word doc) it has some 90-92 wire diagrams.
OK its fixed and works now.
Old Nov 20, 2004 | 03:27 PM
JP86SS's Avatar
Those diagrams are for a 90 IIRC, don't take them as gospel but should provide some good info.
Old Nov 20, 2004 | 04:08 PM
vette9190's Avatar
I can't unzip the file. I am at my inlaws now they have 98se.
I will try again later from my PC or if you could can you email it to me.
vette9190@yahoo.com
Old Nov 20, 2004 | 04:27 PM
JP86SS's Avatar
You've got mail!
Old Feb 15, 2005 | 11:50 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I am having some issues with this connector on my 91 that was originally a TBI 305, swapped to a DFI setup and I am now changing it to a SD TPI 730 setup.
Problem here: https://www.thirdgen.org/techbb2/sho...hreadid=242358
The link for the 90 wiring diagram is not working...could anyone email me the applicable schematic?
TIA,
Old Feb 16, 2005 | 06:33 PM
JP86SS's Avatar
My web site is stacked with stuff and the links to the above docs aren't working.
Send me an email and I'll be glad to send anyone the info.
John
Old Feb 16, 2005 | 09:31 PM
JP86SS's Avatar
Links put back up
If you were trying to get the docs and info from the above links, use this one.
http://www.wideopenwest.com/~johnand...TESS/Monte.htm
I put the items on a quick page so I can add to it later without reconstructing the addresses.
Links are at the bottom.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
