stops running
Old Jul 11, 2002 | 08:14 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
stops running
I have a 91 ta 305 currently i am having running problems At first i thought it was ing related but now i am not so sure. well first let me tell you guy what i have done to try to rectify the problem. I have replaced plugs wires cap and rotor module and coil all are new and some days the car will start others it won't. In lost I am now thinging it may be fuel pump, injectors, fuel filter related now or some sensor i am unaware of Please help I need to make car operational by the end of summer so i can drive it to storage not have it towed. thanks in advance
Old Jul 11, 2002 | 08:40 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
when you had the dist. open, did the wires to the module look ok sometimes they get crispy...could be the pickup coil..check the wires closely for cracks and such.
Old Jul 11, 2002 | 10:47 PM
91blkta's Avatar
When i had it open the wires looked pretty good but i will recheck my work when time permits
Old Jul 14, 2002 | 05:47 PM
91blkta's Avatar
I have more facts to go on now the car will start sometime and not others when the car does start the left fan is on if your looking in front of the car then the other fan will kick on shortly after no keep in mind the car is not hot yet When the second fan kicks on the engine stumbles like it wants to stall sometimes it will. Also when i turn the air on it clicks like its trying to work but is not. I know the air has something to do with the fan switchs so i am thinking a sensor is out of wack. what is funny is i had the car started heated it up to temp then shut it down it would not restart any help is great thanks in advance
please help me
Old Jul 14, 2002 | 09:06 PM
91blkta's Avatar
come on guys please
Old Jul 17, 2002 | 07:24 PM
91blkta's Avatar
up to the top again
Old Jul 17, 2002 | 07:45 PM
WaynesRS's Avatar
Don't laugh , but it could be your altenator not charging the battery like it should . Test it with a multimeter . Could be your battery to . My Dad was just having hot start problems recently , ended up being his battery , test that also with a multimeter . Or if you dont have a mutlitmeter or dont know how to use one , take it to the parts store around you and they usually test altenators and batterys for free .
Old Jul 19, 2002 | 09:47 AM
Vader's Avatar
91 Blk,
The fact that the cooling fans start is a good hint. The primary fan is controlled by the ECM, based on input from the CTS. If the CTS is reporting a higher temperature than it should, the fan will operate. This may not be apparent on the dash temperature gauge, since the sensor for the gauge is separate from the ECM input.
A CTS reporting too high will also prevent the cold start cycle - the additional fuel required to start a cold engine. It would also tend to lean out the mixture overall and retard spark. You can test the CTS with an ohmmeter, and compare it to the table:
If the resistance is not within ± 50 ohms at a specified temperature, the CTS may be bad or there may be a CTS circuit problem.
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
apo_bailon15
Mar 28, 2016 05:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
