Where is a hole in the firewall to run cable
Old Oct 23, 2002 | 06:31 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I'm installing a sound system and I can't find a hole in the firewall to run the power cable to the amp. There is a big black ridged hose that runs from the left side at the back of the engine bay which seems to go inside the car but I can't find where it ends up. Are there any other holes where I could run the power cable?
Old Oct 23, 2002 | 07:26 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you have cruise, there is a grommet just under the carpet behind the brake pedal where the vacuum line runs thru it to the cruise unit. If there's no hole, drill one and put your own grommet there, it will come out under the brake booster & just above the frame rail.
Attached Thumbnails Where is a hole in the firewall to run cable-dcp_0034.jpg
Old Oct 24, 2002 | 11:52 AM
Nate1's Avatar
Car: 88 IROC-Z, 71 SS 454 Chevelle
Engine: 305 TPI, 454
Transmission: 5spd, th400
I ran a wire through the grommet that my speedometer cable went through the firewall.
Old Oct 25, 2002 | 07:25 AM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
find an empty space
drill a hole
don't forget the grommet
done
Old Oct 28, 2002 | 10:54 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
freeze, that engine bay looks clean enough to eat off of. how did you get it so clean?..and also guys do you have to do ne prep work to paint parts?
Old Oct 29, 2002 | 12:38 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
OMG... that is the cleanest looking engine bay I've seen.... very nice Freeze!
cheers
Old Oct 29, 2002 | 06:11 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
freeze, when u drill the hole in that area where is the hole inside?
where i circled on the pic is that the grommit that u put in?
thanks bub
Attached Thumbnails Where is a hole in the firewall to run cable-fbdfbdfbd.jpg
Old Oct 29, 2002 | 08:52 PM
iggy1991's Avatar
Those pictures didn't help cause on the 1991 the battery is on the other side of the car, the passenger side.
Old Oct 29, 2002 | 09:06 PM
deadbird's Avatar
Engine: TPI 305/ v6
There's always the transmission tunnel....
Old Oct 30, 2002 | 01:12 PM
bubbakutz's Avatar
Engine: LG4
where is that hole located? is it easy to get to?
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
