View Poll Results: What Cam should I use?
Crane CompuCam 2030 - .423 / .423
46.15%
Blue Racer - .420 / .442
7.69%
Crower Level 4 - .435 / .443
7.69%
Edelbrock Performer Plus - .420 / .442
7.69%
Lunati #06315 - .441 / .441
7.69%
ARI Pro Builder Phase 3 - .433 / .466
7.69%
Lazer Cams #2600122 - .447 / .456
0%
Other - Please specify
15.38%
Voters: 13. You may not vote on this poll
chevy 60* v6 camshafts
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
i have been looking around for a cam to use in my engine build.. here is a list of 7 and some specs that i have for them.. please vote on which one u THINK i should use on 3.4 carbed w/ no comp.. if u have any suggestions for a cam that not listed please post the info u know about it.. thanx
http://www.geocities.com/valleyfbody/60cams.htm
- edit - i updated the specs on the link w/ the info TomP posted..
- edit - here are links for each individual cam..
1 - Crane CompuCam 2030
2 - Blue Racer
3 - Crower Ultra Performance Compu-Pro / Performance Level 4
4 - Edelbrock Performer-Plus #3790
5 - Lunati High Efficiency Grind #06315
6 - ARI Pro Builder Phase 3
7 - Lazer Hydraulic #2600122
2 - Blue Racer
Car: 1986 Firebird
Engine: 2.8 V6
Here's the price for the Crower, Summit wants $130. The "kit" that crower recommends, 84008, goes for $160 at Summit... I wonder what's in that kit? I couldn't find a description. Oh; wait, just did a search on the crower site, looks like it comes with lifters, valvesprings, pushrods, pushrod guide plates, and spring retainers. The lobe separation for that cam is 108 degrees.
The ARI ProBuilder 3 cam goes for $169.56, and comes with lifters... but I got the price thru http://www.engine-parts.com/GMV6/28strokergpl.html , not Summit Racing. They don't list an exact lobe center, just 107(I) 117(E), so I guess if you go in the middle, lobe sep is 112. That cam has good vacuum, though, 16-18" Hg.
I would suggest emailing each cam manufacturer to see what they think of their cams in your application. I voted on the CompuCam before I noticed you were running a carb; I wouldn't use the CompuCam 2030 on a carb'd motor. You can have increased lobe sep (lower vacuum) on a non computer controlled car, which translates into a more lopey idle.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
before Karl answers " What's wrong w/the stock 3.4 cam?"
Voted for other: GM 3.4 crate motor cam kit . $120 or so fromGM
Duration @ .050........lift.....................lobe centerline
int.....exh.............int......exh
204....216...........427.....454...............112
TomP, you sure that more centerline increases lope?
Car: 91 RS
Engine: 3.4L
ok I know that the 3.4 and 3.1 are kinda a like here. What would you recommend for the 3.1L cam wise? A 3.1 is what I have in mine . I lookin into building another and putting heads and cam on it.
Car: 82 Camaro Z28
1 = i may be getting a bare 3.4 block.. and there for no stock cam..
2 = im actually looking for something that will give me more power than the stock cam..
the 2030 sure is a popular choice here.. i thought that would happen tho..
Car: 82 Camaro Z28
Car: 1986 Firebird
Engine: 2.8 V6
They're probably choosing it for the same reason I did, we thought the car was computer controlled.
Another thing I thought of last night; when you email the companies, make sure you tell them in the email what yo'ure doing as far as headwork, fuel, rear gears, etc... the crower website seemed to think a ton of work should be done to the motor in order to take full advantage of a level 4 cam. The higher lift you go, I think the higher pound valvesprings you need, etc... what kind of rockers will you run? Stock?
Another thing I thought of last night; when you email the companies, make sure you tell them in the email what yo'ure doing as far as headwork, fuel, rear gears, etc... the crower website seemed to think a ton of work should be done to the motor in order to take full advantage of a level 4 cam. The higher lift you go, I think the higher pound valvesprings you need, etc... what kind of rockers will you run? Stock? Thread Starter
Car: 82 Camaro Z28
im not sure what kind of rockers im gonna use.. comp cams roller tip 1.52 or 1.6.. probably use the 1.52.. w/ stock 3.4 heads (donno bout macine work yet)..
rite now im thinking.. stock bottom end, edelbrock 2bbl intake, holly 390 cfm 2bbl carb, stock 3.4 heads, 1.52 roller tip rocker, edelbrock performer-plus cam.. that seems to be the most cost efficent build at this time..
vortec makes sc for carbed engines.. ill probably get the carb enclosure to see if i can get it to work w/ my carb/intake setup
Engine: 5.7 / 7.4
if you're gonna sc, get forged pistons, thermal coating for piston & heads, & full roller rocker arms. May cost more $$$ than you planned, but will help utilize full benifits.
blackroc68
Sep 1, 2015 08:01 PM
Dan87IROC-Z
Dec 31, 2000 12:26 AM
