Anyone have a 219 cam card??
Old May 19, 2003 | 11:58 PM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
I'm going to be degreeing in a Accell 219 cam. I've had the cam for a while and since misplaced the cam card. Does anyone have one handy? If so, I'd like all the information on it. This would help a lot.
thanks,
Tom M
Old May 20, 2003 | 04:19 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I'll look for mine when I get home.
Old May 20, 2003 | 11:07 AM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
Ok, that would be cool.
Old May 20, 2003 | 08:50 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
219 cam specs are:
centerline is 112 on a 108 lobe sep.
Dur.@.050 lift is 219int./219exh.
liftt w/1.6 .560int/.560exh. lift w1.5 .525/.525
Intake@.050 Exhaust@.050
1.5 BTDC opening 45.5 BBDC
37.5 ABDC closing 6.5 BTDC
4 degrees advance built-in
Old May 20, 2003 | 08:56 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
The one I got from accel was 218@.050 and was on a 112 centerline with a 112 lobe sep. I'll see if I can find it.
Old May 20, 2003 | 09:01 PM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
89gta383,
That's interesting that your lobe seperation is different.
Camarojoe,
37.5 ABDC closing -6.5 ATDC
I'm assuming the - symbol is a typo. It should just be 6.5 degrees ATDC?
Old May 20, 2003 | 09:03 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
383,
Oops, yeah I can't read my own writing, I meant 112 lobe seperation. Wow, 218degs. duration are you sure you're talking about the 219 cam??? J/K I'm using info. I got from a vette guy a long time ago.
ps, I edited the post with the specs. -6.5 ATDC is the same as 6 BTDC, but yeah it's stupid to talk in terms of neg. specs even though that's what the card said.
Old May 21, 2003 | 09:29 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Sorry about that. I forgot about it.
P/N 74219
INTAKE EXHAUST
Valve Lash Adjustment .000 HOT .000 HOT
Gross Valve Lift: .525 .525
(1.5:1 Rocker arms)
Cam Lobe Lift .350 .350
Duration @ .050" 218 218
Cam Lobe Center 112 112
Valve Timing
@.050" Tapper Lift Opens/BTDC Closes/ABDC
INTAKE -3 41
Opens/BTDC Closes/ATDC
EXHAUST 41 -3
Old May 21, 2003 | 01:25 PM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
Hey Firebird90 and Camarojoe,
Did you notice you're valve timing specs are different? Wonder what's up with that?
Tom
Old May 21, 2003 | 01:34 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
here.
Old May 21, 2003 | 01:39 PM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
Sweet, I was hoping someone would scan in a picture.
Thanks!!
Tom
Old May 24, 2003 | 04:54 PM
REDZ28's Avatar
My accel cam card says 218 also.
Magman
Aug 2, 2016 08:32 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
