HELP!!!!I did a no-no atleast i think i did with my trans..Put Dexron V and not III
Old Apr 21, 2004 | 06:06 PM
91NiteRida''s Avatar
Car: 1991 Camaro
I just changed my trans filter and gasket....Then i was buying trans fluid and saw dexron....Didnt cross my mind but i bought 5 quarts of dexron V and not III....The time i noticed i was using the wrong dexron,i poured 2 bottles of dexron V in my trans.....So i went to the store to buy 3 more bottles of dexron III.....Am i in deep shi!t?Trans has 126K miles on it...Do i really have to drain the pan AGAIN????SOMEONE PLEASE HELP...I need to drive my car....3 quarts of Dexron III and 2 quarts of dexron V...Did i do a no no???Also its a 91 camaro with the 700r4...PLEASE HELP ME!!!!Camaro Gods please save me
Old Apr 21, 2004 | 07:06 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Didnt know that that stuff was even out yet. Usually you can put newer version of fluid in a trans that requires the older stuff just not the other way around. Most likly the two are also compatible.
Old Apr 21, 2004 | 07:08 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
I believe Dextron V is just a better version of 3 like Dextron 3 is better than Dextron 2.
Old Apr 21, 2004 | 07:33 PM
Car: 1991 Camaro
man i did a typo...its actually mercon V that i put in
Old Apr 21, 2004 | 07:43 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I don't know, but start the car until you are sure it wouldn't harm anything.
If anything, its not hard to drain the pan and refill. Better safe than sorry till you find different.
Old Apr 22, 2004 | 07:35 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
no, it wont hurt it.
but it may effect the where the shift points are.
Old Apr 22, 2004 | 09:07 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
Mercon V is just synthetic fluid. it's like running mobil 1 instead of valvoline. you'll be fine. however, they are right: you can go up, just not down. but dexron III/Mercon v are ok for GM trannies.
Old Apr 22, 2004 | 11:43 AM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I don't think it would do any damage at all, but I would drain it and go with dexron III, better safe than sorry.
Old Apr 22, 2004 | 02:11 PM
Car: 1991 Camaro
thanks for the help fella's....I played it safe and drained all the fluid again...Runs 10 times better and shifts 10 times better.:hail:
Old Apr 23, 2004 | 12:00 AM
Car: 1982 Trans Am
Engine: 383 chevy
glad to here it. did you change the filter, too? you'll notice a big change afer that too if it hasn't been done before.
Old Apr 23, 2004 | 12:06 AM
Car: 1991 Camaro
yes i did change the filter...it was a night and day difference.....Thanks for all the help...i was scared crapless
Old Apr 23, 2004 | 01:35 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Mercon and Dextron are the same thing, dont confuse that. The only different fNord fluid would be older fluids like Type F. Mercon Type V (5) is a newer semi synthitic blend of fluid that would probably work much better then conventinal Type 3 fluid.
Old Apr 23, 2004 | 02:37 PM
Car: 1991 Camaro
thanks for the late reply...you couldve told me after i took the old fluid out jk jk jk jk This is me ------->
Old Apr 24, 2004 | 12:50 AM
Car: 1982 Trans Am
Engine: 383 chevy
i DID tell you that. I'm running merc 5 when i pull my pan off again
Old Apr 26, 2004 | 04:47 PM
Marc 85Z28's Avatar
Due to the fact that I work for a Ford dealer, and I get the Mercon V for free, I put it in my new trans years ago. Works great! Just flushed it for the first time several months ago. Came out nice and red... and I drive this thing pretty hard. The switch to synthetic fluid aids in TC clutch engagement and eliminates chatter in most of the older cars I service.
If you change over, you need to FLUSH it. Dropping the pan and adding the new fluid doesn't do squat. You're only doing 1/3 the job. The 700 takes about 12qts. So dropping the pan and putting in 5 qts is no different than putting in 2 qts
92-Formula
Dec 12, 2015 10:34 PM
New2Chevy
Oct 4, 2015 11:27 PM
JHX
Sep 21, 2015 08:53 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
