power door lock trouble
Old Dec 7, 2004 | 08:14 PM
black84z28-4spd's Avatar
ok....my power door locks were weak...so i figured they were just old and going bad...today i changed the driver side and now it dont work...the passenger side works but slowly
the relay clicks!...i made sure but i am still gonna replace that also...wtf do i do?
Old Dec 7, 2004 | 08:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you clean, lube, and put the rods back in correctly. Also make sure that you have a good charge on the battery. It may have gotten weak if you had the door open with the battery still connected while you worked.
Old Dec 7, 2004 | 09:09 PM
new battery,i added the double clip for both rods, added lube
Old Dec 7, 2004 | 09:17 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
How about the relay under the left kick panel. I don't what year yours is but some of them grounded the relay to the car frame.
Old Dec 8, 2004 | 12:56 AM
my car is an 84...i checked the relay and i here clicking...could it be that the driverside part was on its way out?...
there is two connectors going into one relay
Old Dec 9, 2004 | 10:57 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i have the same prolbem with my power locks. i changed the relay and i am getting power to the actuators but they dont work still, i am waiting to get a wiring diagram, my relay also clicks. drives me crazy. btw mine is an 86
Old Dec 10, 2004 | 07:55 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Both of you check your e-mail, you have a christmas package there.:lala:
Old Dec 11, 2004 | 04:50 PM
smokefan's Avatar
Thanks trickster
thanks alot brother. the prints sure are going to come in handy. cant wait until i get to the garage and to check it out...thanks again..
Old Dec 12, 2004 | 03:10 PM
damn relay is $40
Old Dec 13, 2004 | 02:01 PM
Buck89RS's Avatar
Car: 1989 RS
Engine: 2.8L MPFI Bored 30 over (Rebuilt DEC 2004)
Transmission: 5 - SPD With 3.42 open rear end
To Trickster:
Do you have a wiring diagram for a 1989 Camaro V6 car with power door locks. The people I got the car from said they unhooked them because they would lock and unlock by themselves with the ignition on and off and during the night it would drain the battery. I have no idea how they did it, but i would like for them to work again. Thanks
-Buck
Old Dec 23, 2004 | 11:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Buck,
I have the schematic that you are asking about, unfortunately I am recovering from a harddrive crash and don't have it readily available at the moment. However it has been posted on the board and you will find it if you do a search for power locks.
Old Dec 24, 2004 | 01:51 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
i had the same prob with lock and unlock only when it rain and snow the way they prob disconected was at the relay wich is located at the driver kick panal under a black stickey pad, it is grounded to the car metal (if it is not grounded it will not work) they may have disconected it there or unpluged it there.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
