electronic VSS on Manual tailhousing
Old Jan 3, 2005 | 11:03 AM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
If I have a trans with a mechanincal vss cable, will the electronic VSS slide in or will I need a differnt tailshaft housing?
Old Jan 3, 2005 | 02:16 PM
Engine: LB9/383
I guess I should re-phrase that. Will the Electronic VSS for a T5 fit on an older tranny that has a cable-driven VSS?
Old Jan 3, 2005 | 08:45 PM
Engine: LB9/383
ttt
Old Jan 3, 2005 | 09:31 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
If both tranny's are T-5's they will swap. The sleeve where the cable screws onto comes out and the new VSS goes in. Just yank the little shaft off the small mechanical speedo gear and put it on your VSS.
Old Jan 4, 2005 | 11:24 AM
Engine: LB9/383
So the electronic sender is the same size as the cable driven one? The reason I ask is because the only electronic ones I'm farmiliar with are larger diameter ones like in the 700R that definitely wont fit into the t5
Old Jan 4, 2005 | 03:06 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You'll need to get one to fit the T5, along with the proper driven gear for the speedo.
For your other question concerning a flywheel, you'll need one to fit the engine in the car; if it's the stock engine, you need one for a one-piece rear seal.
Pete
Old Jan 4, 2005 | 03:09 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Correct, the electronic VSS fits into the same hole where the mechanical speed pickup is.
And correct, the T-5 VSS is different from automatics (don't ask me why), it's smaller and much pricier. The part # is 10456087.
If you tell me what gears you got in the back, I can also post part #'s for the drive and driven gears for the VSS.
Hope this helps.
Lou
Old Jan 5, 2005 | 08:53 AM
Engine: LB9/383
Great! Thanks for your help. The rear has 3.42's. Thx!
Old Jan 5, 2005 | 10:09 AM
BigBadLou's Avatar
Engine: TPI
For 3.42's, you will need these VSS gears:
drive gear: PURPLE - 7 teeth - part # 14071731
driven gear: WHITE - 19 teeth - part #14090592
Hope this helps.
Lou
P.S.: Don't be surprised if you have to pay $25 for the driven gear, GM is milking it as much as they can.
Old Jan 5, 2005 | 08:04 PM
Engine: LB9/383
Thanks again for your help. I've got a hookup for GM parts through AC Delco
Old Nov 30, 2005 | 09:29 PM
Dan86Z28's Avatar
Hate to ressurect a dead thread, but can someone tell me the part #'s I'd need for my 89 GTA with 3.27's and 245/50/16's?
thanks a lot.
Also, anyone have a good place to get a T5 VSS?
Old Dec 1, 2005 | 08:44 AM
BigBadLou's Avatar
Engine: TPI
For an auto or manual? Cuz your signature says 700r4 but then you're asking for a T5 VSS. So I'm not sure.
Well, for 700r4, you'd need the 17/44 combination, as my book says:
drive gear - 17 teeth - red - #8640517
driven gear - 44 teeth - dk grey - #25513051
For T5, it's a small problem, there's no gear combination for 3.27's. The closest thing is the 9/22 combo for 3.08's:
drive gear - 9 teeth - red - #14053347
drivern gear - 22 teeth - grey - #14090595
The T5 VSS can be found at Advance Autoparts with no problems. Just make sure it's the "skinny" one, not the fat one (for auto's).
Hope this helps.
Lou
Old Dec 1, 2005 | 09:22 PM
Dan86Z28's Avatar
I'm converting to a 5 speed.
And there's nothing closer for the 3.23 than the one for the 3.08?
that sucks :P
Old Dec 2, 2005 | 08:10 AM
BigBadLou's Avatar
Engine: TPI
The T-5 trannys have VSS gears only for the following rear end gearing (as specified by GM):
2.73
3.08
3.42
4.10
The 3.08's would be the closest, with a 5% error. Meaning that at 60mph, the speedometer would be 3 mph off.
Sorry, that's the best we can do.
Lou
Old Dec 17, 2005 | 07:36 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Ok, I dont mean to hijack any thread but, I got my car with the speedo not doing anything.
This is basically what the person did to the car, It was a V6 Automatic and not sure of the gears, they arent the same as they are now.
Now it has a 350 and a T5 from an 84 (the 350 isnt I know) The rear end is a 3.73 posi.
From what I have read from numerous threads I am more confused then when I didnt read any in the first place, could someone please start off easy for me.
I understand this is going to take work to get going but I feel that this is more of a safety thing for the car rather then a "want"
It seems that you guys know what you are doing, can someone please write something up like a "how to" on something like this.
Dennis
Old Dec 17, 2005 | 11:41 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
that sucks :P
There is an 18 tooth gear you can get that works with the 7 tooth driven gear for 3.23's/3.27's, but I have no idea what its color is or what the part number is. Good luck!
Perhaps a search on this board will get you that info.
Old Dec 21, 2005 | 02:48 PM
goose21's Avatar
Car: 85 Monte Carlo, 93 C1500, 98 Neon
Engine: 355, 4.3L, 2.0 DOHC
Transmission: T5, 4L60E, T350
Axle/Gears: 2.73, 3.42, 3.94
My situation is the contrapositive: I want to swap my 700's electronic VSS to a mechanical VSS.
If I'm reading this correctly, it seems that I need to remove the innards of the electronic unit and insert the shaft/gear combo from a cable drive unit???
I tried to throw in the entire mechanical unit into the tailshaft of in place of the electronic unit, but that didn't work. Is a tailshaft swap in order?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
