29c256
Old Jan 29, 2004 | 11:27 PM
51 chevy's Avatar
29c256
hello im using a willem programmer I can copy my stock aujp chip and erase burn and verify my 29c256 chip but when I put it in my car the aldl will not go into diagnostic mode aldl will not blink and the computer will not connect to gmecm diagnostic .I also have a hyper chip that does the same thing but the aujp chip works.one question is the amel29c256 a replacement for the 27c256?is there anything in the programming that has to be changed like on maf eprom?the hyper chip is a 27c256
thank you
:lala:
Old Jan 30, 2004 | 10:22 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: 29c256
It should be a drop in.
Try *cleaning* it, by programming it with a .bin file of all FF's. Then try again.
The 29xxxx series seem to need that from time to time.
Also, when you turn the key off give the ecm a couple secs before pulling the prom off. It resets the IAC and might be reading it, if you pull it out too quick, that could pop it.
92GTA
DIY PROM
Jul 13, 2004 02:36 PM
BOWTYE8
DIY PROM
Jul 9, 2001 04:34 PM
87IROC350
DIY PROM
May 15, 2001 01:17 PM
Steves ZZ5
DIY PROM
May 13, 2001 08:23 AM
xtronics
DIY PROM
Apr 11, 2001 03:35 PM
