Cubic feet in well area
Old Jun 4, 2004 | 12:32 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I have searched for this subject with no results, but if you can get me a link, it will be much appreciated.
I want to put a system into my bird, but first comes the motor. So I've got some time to figure out what I want to do. I was wondering if anyone knows how many cubic feet are availble for a box. I haven't decided what speakers to go with, but I'm looking along the lines of 10's. I think that I want to build a box that holds two, at about 1 cubic foot each.
Before anyone tells me to measure, I have to let you know that my struts are out, and I have a bad back, and no one to hold the hatch.
Thanks in advance, Stingerssx
Old Jun 4, 2004 | 08:13 AM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
Use a hockey stick, broom handel, or something to hold the hatch up.
I'll do some measuring when I get a chance to see what you have to work with.
Generally, the box you want to build is easily done, people have put 12's and 15's even in the hatch area.
Do a search for custom boxes for some pics.
:lala:
Old Jun 5, 2004 | 02:45 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
You can even fit 18's in the well if you really try. There is a box on here somewhere it's a black background picture that gives the measurements for famous hatch well box. I would try to find the link for you but my crappy dialup would take awhile for searching.
Old Jun 8, 2004 | 11:59 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
you have about .85 cuft of air space in there using a q-logic box so assuming symilar set up id say thats ur lucky number
Old Jun 9, 2004 | 12:15 AM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
0.85 CF IN THE WELL?!?!? i got 1.3 cf just out of the bottom part of the well. i must of missed something
Old Jun 9, 2004 | 02:14 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
i also said assuming the materials and design of teh q-logic box... did you take into accout the "Shelf" thing in the bottem of the dip along the side
Old Jun 10, 2004 | 02:23 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
there is tones of space back there, especially if you use fiberglass. I think I got like 3.5 cu ft and the box comes up flush with the over axle hump. there is a guy on cardomain with 4 12's and he made the box go up even higher, right to the seal, and he had like 5 cu ft, also went half way up the axle hump
Old Jun 10, 2004 | 07:30 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Blake what 406ci??!!? block code?
Old Jun 11, 2004 | 11:02 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
its a 400 bored .30 over
Old Jun 12, 2004 | 12:28 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I agree with OP, that's a heavy hatch! If you have a bad back, there is no need to mess around with that beast!
Spend the $65 and get new struts, it's worth every penny. Using a hockey stick or whatever isn't worth risking being slapped in the head by that 1 ton glass.....at least it feels that heavy when I carried mine from my car to the shed!
When I parted out my T/A, I sold the rear struts for something really cheap, like $25 or something, new parts too! Peek in the classifieds here and there. You might luck out.
I feel bad about parting out that car, but at the time I was paying my rent with the profits from parts sales....what a life!
Old Jun 14, 2004 | 07:39 PM
DISTURBthePEACE's Avatar
Car: 89 Camaro RS
Engine: 2.8L V-6
I got a box from our distributor at work and it has (had, I chopped off the bottom) 1.6 per side, w/ a divider. So we chopped off the bottom, which put it resting on the ledges, and gave me about 1 cu. ft. per side. so figure it is at least 3 cu. ft. here is a pic of the box...if you make it flush w/ the gas tank hump, you'll prolly cut off .4 or so.
Old Jun 14, 2004 | 08:06 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i was able to get around 1.0 cu ft from the bottom well alone. there's much to be had if you're good at cutting angles or fiberglassing
Old Jun 14, 2004 | 09:16 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
You can cheat though. You can just make the box taller then the well to get more Cubic feet. My subs needed 1.15' of air for optimum performance. All we did was make the box stick out higher and put some support along the flat part and a board on top to make it look clean. Came out nice actually.
Old Jun 14, 2004 | 09:58 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
Hey thraxx, nice avatar....mmmm badger badger badger badger badger badger badger badger badger badger badger badger mushroom mushroom!!!!
Old Jun 18, 2004 | 06:05 PM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
Oh Nooooo its the snake..badger badger badger
Old Jun 18, 2004 | 11:05 PM
Car: 89 Camaro RS
Engine: 2.8L V-6
LFAO, that is hilarous
Old Oct 1, 2005 | 07:29 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
no ****, you've got the fireturd? i remember reading about that thing from when they first got it. how did it come into your possession?
Old Oct 3, 2005 | 07:27 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
DISTURBthePEACE Nice Clarion amp, is that the 400.4?
Old Oct 3, 2005 | 08:00 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My boxes are just about 1.5 cubes per side, for a total of 3 cubes. If you lower them so that they're flush with the well, you can still squeeze out almost 1 cube per sub.
The box on the left had about 1.25 cubic feet per side, the one on the right had 1.5:
Fireslash
Apr 11, 2016 06:43 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
loud91rs
Oct 5, 2015 10:05 PM
ironbmt
Sep 27, 2015 06:00 AM
