Thirdgen outhandling a Ferarri...CHP Article
Anyone have that article of CHP where they do some suspension mods to a Thirdgen Camaro and compares it with the slalom and skidpad figures of the cars it'll toast? A link, or could someone scan it?
I can't seem to find the mag.
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
no kiddin'....
Really Ferraris and Porsches are style, if you have the money, but for those of you who know....A stock fully optioned IROC-Z with 245/50's will pull .89g's on the skidpad. That's not messin' around! There have been reported measurements of the mid .90's with larger wheels and tires!
I wanna see the article!
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I too just heard of some article in some chevy mag stating that a base 91 RS with I forget what tires on a 16x9(.5?) inch rim pulled .95g's on the skidpad... no other suspension mods added. See if i Can get the article tomorrow and give actual fact
the 91 rs you're talking about is in the magazine article section on this site. It was a comparison between the rs camaro and the ls mustang. the camaro whooped it in the handeling department
Car: 91' RS
Engine: Built 355
No he's not...
Re: No he's not...
Originally posted by 330hp_91RS
Esentially the latest model of the RS and Z-28 are almost the same, except for the springs I believe. The sway bars are the same and the wheel are the same. I am pretty arn sure I saw the article he's talking about and also in The Camaro Performance handbook by David Shelby, he talks about outhandling High end car no problem in the suspension section.
https://www.thirdgen.org/newdesign/a...shootout.shtml
thats the one about the 91 rs, i dunno about the ferrari one though
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The '91 & '92 RS got the 34 mm hollow front sway bar and 21 mm solid rear IF it came with the 16" wheels from the factory.
The springs (both F&R) were the same on all cars, regardless of sway bars, wheels, or whether it was a Z28 or RS.
Car: 91' RS
Engine: Built 355
yup.
so my 92 rs, which came with the 16 inch wheels has the same suspension as the z28's?
All of the rear springs are the same, you'll figure this out if you ever try to order stock springs.
I have IROC springs on my 91' RS and they are way, way, way different than stock. I don't know if the 91 and 92 Z's had the same springs as the IROCs though.
Car: 91' RS
Engine: Built 355
are there any other differences other than the springs?
OK, I hate to bum your stone.
I'm just as all about value as the rest of you, but the mid engine 355 Ferrari smokes even a heavily modded LS1 Z28 in the corners.
Now the Camaro is faster down the front straight and I laugh at the ferraris on the straights at Laguna Seca. and Thunderhill, but they are still faster around the track.
Even 308s outhandle the camaro, slow as they are
It's a 2700 lb mid engine V8.
Sorry to rain on the parade.
And...
at the end of the day, a Camaro is still a Cheby, and he's driiving a Ferrari
And...
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I'm goin to watch the race today with the guy who told me about the article where a '91 RS pulled .95g's so if it actually exists I'll have it posted/scanned on here sunday evening.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
And...
And...
Since the Third gens make a mockery out of the 4th gen LT1/LS1 cars in handling, don't compare apples to oranges. And you don't see too many Ferraris out on the track in the first place, at least not around here.
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
In my book- any comparison testing of vehicles should be done with the same exact tire brand/ style. Size should not have to be the same but rubber compound and sidewall strength should be consistent.
example: one car on Goodyear Eagles 245/50/16-the other one running Pirelli's 275/40/17 is not a fair comparison.
(cars should run their factory size tires yes but both should run Eagles or both should run BFG kd's or what ever... they should just match.
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
OK, the article I just read said a 91 RS with 1" drop springs, moog poly bushings, z28 sway bars, 12:1 steering box on 17x9.5 wheels with 255/40/17 BFG's pulled .95g's on the skidpad... so not exactly stock but not far from either really. Basically just stock with some meats... they said the car did .88g's before they touched it. Figure a '02 vette does .91g's ... still very very impressive.
Car: 91' RS
Engine: Built 355
Ok....
z-28 Sway bars? RS and Z-28 have the same sway bars for 91 + 92 providing the Rs came with 16 inch wheels from the factory, if not then they just put the upgraded RS sway bars on.
Does it say what kind of drop springs they used?
They should have used 275/40/17's on those 9.5 inch wide wheels. They might have gotten a better G reading.
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I just said Z28 sway bars cause, yes, there is a diff if you didn't get an RS with 16" wheels and that's the version they had. Also the there's more than one article being spoken for in this thread... mine didn't have anything to do with competing against any other cars... that was another supposed article... on another note I forgot to post the slalom time... stock 61.X mph and modified it was 66.7 mph. Doesn't say which kind of springs were used.
275's getting better grip than 255's on a 17x9.5 wheel might be a good arguement... more tread but also more sidewall... what do ya'll think is a optimal size for 17x9.5 wheels in a 40 series tire?
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
To compare some unofficial specs I found on a '94 Ferrari 355 are .98's skidpad and 64.3mph in the slalom.
seen a couple other specs of .96g's also for different years but no other slalom times. Stock sized tires on a 355 are 225/40/18(19) fronts and 255/40/18(19) rears.
One MAJOR thing to remember is that the 355 has alot of power and braking performane over an RS also which would be a big deal in the slalom.
Ok, I'm gonna throw in another 2 cents here.
I have an old article (I am the UNDISPUTED King of old Third Gen articles) of a TA that pulled .996g average with Bridgestone 245-50-16 street tires (Car Craft Dec 1990). The car had Bilstein struts/shock, suspension techniques sway bars, and suspesnion techniques lowering springs. There were no subframes, torque arm, rear control arms, panhrd rod, or STB, those pieces were all dead stock. Now if you were to optimize the combo with 275-40-17 rubber, subframes, control arms, TQ arm, and panhrad rod, it would handle even better (around 1.05g), which would probably be enough to competitively race against the turn-key ferrari race cars (street models meant for racing, anyway). I am not saying you would have the power, but you sure would have the handling. It would only take about 5 minutes to call Baer and order a $1,100 kit to destroy the Brembo brakes adavantage too (actually it wouldn't even be fair). Then you install a ZZ430 crate motor and say good bye. Oh yeah, did I mention that you can do this work in your driveway?
Car: 1985 Camaro Z28
Engine: Caprice LT1
Interesting thread, I was wondering how they measure these cornering G's?
Use an accelerometer similar to a G-Tech on a skid pad or something?
From what I understand wouldn't the speed through the slalom cones be a better indication of a car's handling ability rather than the sustained or peak g-force?
The limiting factor on a skid pad would most likely be the tires.
I did say the 355 has us in the turns, but they can't pull a basicly stock LS1 on the straights
Actually There is a 355 and a 308 in one of the local track clubs I run with.
I usually have about 2 or 3 car lengths on the 355 going into turn to at Laguna in my 4th gen.
We have to be polite to other drivers as a matter of sportsmanship. He hasn't passed me yet on his car or driving ability, I usually lift for him going into turn 5. he's all over me in t2, 3,and 4, but still can't get by me without my throttle lift, even in open passing.
I do enjoy it.
Just for the heck of saying so, I regularly smoke NSXs, Lotus V8s, (must be the driver) and everything but vipers and new vettes in club driving, turns and straights.
The Dinan M3s and M5s can hang pretty good on the straights, but it comes down to driving ability with all these cars, and I rank basically good in club open tracks and slow among equal racers.
I was depressed to see how fast the L98 vettes (84-91) are in the turns and how slow they are in the straights,
I had one all over me from t5 down to 11 one time, and I had to lift in 3rd to let him by on the front straight.
This was all in my LS1 Camaro.
There is only a couple of super fast GT350 guys that are faster then my 84 racecar at the Shelby club events
I do enjoy it.
The Article
here is a portion of the article you were asking about. It is from CHP and not motor trend. The photo is compliments of Motor Trend.
The Camaro does not beat them all in the skid pad but is way faster on the Slalom.
Ric
Ric
Re: The Article
Ric
Ric
The Z28 got stiffer springs in the front, as well as harder rubber bushings all around, different front control arms, thicker sway bars, etc.
The F41 RS isn't far off from the Z28 in handling but they definitely do not use the same springs all around, and the sway bars are not the only difference.
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Don't quote me here but I imagine the only difference between V8 models of the RS and Z28 are:
engine
swaybars(optional if RS came with 16" wheels)
wheels(optional 16" for RS, otherwise 15")
tires(215/something/something, optional 245/50/something with 16" wheel option)
Now if the RS model were a V6 then yes I'd assume it will have different front springs, transmission as well as the above mentioned.
I've never heard/read anything about different bushings... can anyone back this up or give some hard evidence?
engine
Car: 91' RS
Engine: Built 355
What!!!
Originally posted by Drew
Bull****.
Bull****.
The REAR springs on ALL thirdgens with a V-8 are the same.
As far as harder rubber bushings and different front control arms...I am not sure, but I can tell you that I Highly doubt that the front control arms are different. If anything they are a bit thicker because the springs have a much stiffer rate.
Are you trying to say that the 91-92 Z-28's came with a 36mm sway bar? You said they are thicker than the RS which has a 34mm. The only 36mm sway bars that came on thirdgens were in IROCS and GTA's which also had the stiffest front springs on the planet, stiffer than the 91-92 Z.
Do the research folks. None of this is highly classified information. All you have to do is pickup a sales brochure for the 91 Camaro and you'll have most of the information you need.
I also cataloged spring codes for 40+ thirdgens, and to say that every V8 thirdgen has the same rear springs is incorrect.
If you want to argue with me you better back up your findings with printed material. Check the sales brochures check the parts and illustration catalogs, check a Z28 side by side with an RS and then post your findings.
You can either take my word for this or you can research it. I've got more printed material on these cars then most people know exists and I've read it all from cover to cover.
Bull****.
Bull****.
I never said anything about rubber, control arms, or anything like that, but when I went to replace my stock springs, I asked the parts guy at the local Chevy dealer (whose been there 12 yrs). According to his part numbers, the springs for the '91-92 RS (with 16" factory wheels) and '91-'92 Z28 are the same springs. I was both surprised and upset at the same time because I thought it was a prime opportunity to change over to the Z28 springs.
As far as the rest, I don't know. I didn't need to replace those so I didn't look into it. I only posted what I was told (and shown) from someone who had GM part numbers right there in front of him. They may just be universal replacement numbers now due to the age of the cars? I dunno.
I didn't mean to offend anyone (never thought I'd have to worry about it
). Is it time for someone's "happy pills"? Supreme Member
BTW, I did just remember that I asked him while he was looking up the rears. I figured he meant the fronts also, but he may have only been referring to the rears.
Cuff me, frisk me, call me Shirley.
Car: 91' RS
Engine: Built 355
How's a trans am....2 Z-28's ...and a 91' RS do for comparisons??
BTW, rear springs... are you checking part#'s or do they list the rates of the springs...cause if you are checking the rates then you must be correct..if there is a diff. part # that mean absolutely squat.
Why get annoyed about it? The best springs for all out handling from the factory for the Thirdgen was the IROC springs. If you go to napa...autozone...Kragen..pretty much any auto parts store that has accesibility to springs, you will find a universal Rear spring set.
I don't want to set off any tempers but I hope you are not one of those guys who has the issues with RS's just cause they were produced cheaper than the Z's. You can mod both cars equally and as far as suspension goes they aqre pretty darn equal so you should get over it. What I mean is don't be one of those guys who is being pissed because you don't want to hear that your almighty Z-28 has the same suspension as a crappy RS.
Car: '87 Chev
Engine: 60*V6
Re: ...
... your almighty Z-28 has the same suspension as a crappy RS.
(Street car- no skins allowed)Edit: Oh yes I do have a pocket full of cash to back that. ( Mine doesn't have to be stock does it
) Last edited by AGood2.8; Feb 20, 2003 at 12:43 AM.
Car: 91' RS
Engine: Built 355
Re: Re: ...
Originally posted by AGood2.8
I'll put my crappy RS heads up in slolam to anyones z28 on this board.
) I was saying in term of that he thinks an RS is crappy, not me.
I'll put my RS heads to anyone on this board myself, IROC springs are definately the stiffest on the block!
Car: '87 Chev
Engine: 60*V6
I know your kidding, I'm just boasting a little fun. Iroc springs are no match to my 800 # springs on a light V6 car. No V8 is going to out handle me in slalom- that part I wasn't kidding.
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
hey rachet and mikeD? Where did you get the article from? Month and publisher please.
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i think its funny that an 11 year old car will out handle a new one....yea stock for stock the 4th gen will pull u a little on the straits..
i love the way my GTA drives...and the gta springs are stiffer (cuz that what i have
) Supreme Member
Car: Yes...
Transmission: See "Engine"...
Re: The Article
Ric
Ric
His car was frequently used for articles in CHP and as a result had some very nice "goodies" added to it. He eventually sold the car on eBay.
CHP Article
The Article is in Chevy High Performance October 1999 issue.
This is the second part of a two part article and unfortunately I do not have the previous issue however they tell you everything in this concluding article
Ric
Ric
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
found it. june 2000 CHP 91 Z28 pulled 1.01g's and 62.3 mph 275/40-17 BFG g-force KD on 17x9.5 wheels. before adjusting the panhard rod to center the rear, it was .96g and 59.2mph.
