Floorboard repairs, mostly step by step
Old Jun 20, 2004 | 06:33 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I also posted this on 3rdgen.org, so you may or may not have seen it. My '90 Firebird has bad T top seals, and subsequently, the water that got inside nearly destroyed my floor. I didn't really notice it at first, until one day I noticed the floor felt kind of soft, and out came the carpet to inspect:
Attached Thumbnails Floorboard repairs, mostly step by step-floorboard-1.jpg
Old Jun 20, 2004 | 06:34 PM
Not only was the floorboard itself rotted, but a good chunk of the inner rocker as well, which can (and did, unbeknownst to me) affect the structural strength of the car.
Attached Thumbnails Floorboard repairs, mostly step by step-floorboard-2.jpg
Old Jun 20, 2004 | 06:35 PM
Yesterday, we took on the task of replacing the floor. After much cutting and grinding, all the rotted metal is removed (except for the inner rocker) :
Attached Thumbnails Floorboard repairs, mostly step by step-floorboard-3.jpg
Old Jun 20, 2004 | 06:36 PM
WIIIIILLLLLLMMAAAAA!!!! (cheap fred flintstone shot ):
Attached Thumbnails Floorboard repairs, mostly step by step-floorboard-4.jpg
Old Jun 20, 2004 | 06:37 PM
I'm skipping a couple steps, for sake of keeping the thread a little shorter. here's a shot with the new board in place:
Attached Thumbnails Floorboard repairs, mostly step by step-floorboard-5.jpg
Lyle (a fellow mechanic) stitch welds the new board to the flanges:
Attached Thumbnails Floorboard repairs, mostly step by step-floorboard-6.jpg
Old Jun 20, 2004 | 06:38 PM
Here's a shot of the completed underside, with a fresh coat of POR 15:
Attached Thumbnails Floorboard repairs, mostly step by step-floorboard-7.jpg
Old Jun 20, 2004 | 06:39 PM
Lyle stitches the upper side of the board, and welds the seat rails back in to place:
Attached Thumbnails Floorboard repairs, mostly step by step-floorboard-9.jpg
Old Jun 20, 2004 | 06:40 PM
Here's the completed board, partially coated with POR 15, and the rebuilt inner rocker:
Attached Thumbnails Floorboard repairs, mostly step by step-floorboard-10.jpg
Old Jun 20, 2004 | 06:43 PM
6 hours total, the floor is as good as new! Changing the subject slightly, I've always had a problem with the driver door "dragging" against the rocker sideskirt when it opened and closed. To my surprise (and happiness), the door now works PERFECTLY! . I attribute that to the strength it regained from rebuilding the inner rocker.
My next investment:
New T Top seals!
Old Jun 20, 2004 | 06:58 PM
123jon321's Avatar
Car: '86 iroc
Engine: lb9 305
The work looks great. Thanx for posting pics, I've always been interested in what that whole operation looked like.
Old Jun 20, 2004 | 07:09 PM
Thanks, It really wasn't that bad with a stamped piece to match. Originally, we were going to fabricate everything we needed, but realized it would be a WHOLE lot easier to just get a complete replacement, and it was
Old Jun 20, 2004 | 07:51 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Awesome! I really need to do that on my IROC.
Kevin
Old Jun 20, 2004 | 10:19 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
wow i thought my floor boards were bad but damn those take the cake. thanx for the step by step. was it alot of hard work at doing the floor pans? i look at mine alot and dont feel like i can get it done even though i am mechanicly able to do it.
Old Jun 21, 2004 | 05:50 AM
It's time consuming, but you would be surprised at how easy it is if you have a pre formed piece. It's not very visible in the pic, but we left part of the old board attached, where there was good metal, and used it as a flange for welding the new board. That made it a lot easier. We trimmed the new board to match the old, so it was a good fit. After that, it was just a matter of welding and sealing.
Old Jun 21, 2004 | 10:53 AM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
you think you got a bad rotted floorboard.. you should see mine... i don't have any pics, but mine has a hole from in front of the driver seat up to behind the gas pedal and brake pedal, going the length of that area across... its baaaad... i'm probably going to need someone to weld it in for me since i can't weld
Old Jun 21, 2004 | 05:33 PM
Brock's91RS's Avatar
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
I wish I had some digital pic's from when I replaced my 91's floorpans(just insta-matics is all I have)
My son took one of me sitting on the ground with my upper body and head sticking through the drivers side floor(car was on jack-stands)
It was great for doing some re-wiring under the dash!!!
The job was time consuming,but not all that bad....Wheelwells and the spare tire area were a different story,not as much wiggle room!Good luck
Steve
I bought my stampings from Shermans and assoc.,nice parts in my opinion
Old Jun 21, 2004 | 05:45 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Hmmmm, I look at these pictures and feel the nice smell of hot, fresh, welded floorpan!
Old Jun 21, 2004 | 05:48 PM
jay92,85,79's Avatar
Car: 85z28,
Looks good man.Don't just love doing floor boards?Only thing i would add for anyone else thats going to do this or any other welding is use some welding primer. But just my 2 cents.
Old Jun 23, 2004 | 02:08 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
I'm really afraid of lifting up my carpet in my 85 T/A and finding something similar to what you had before.
I POR15'ed the underside of the floorpans just recently but I have yet to check the top of them. I hope that it isn't bad, but knowing my luck it probably will be almost completely rusted through.
Old Jul 9, 2004 | 04:01 PM
nick418's Avatar
Engine: L98, Hemi 6.2
Wow! My Bro needs that kinda work on his 92Z. Wish u could help him Good job must of bee a pain in the ***
Gunner242
Dec 25, 2015 04:49 PM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
