A few vacuum line problems *pics*
Old Aug 28, 2004 | 11:45 PM
pyrokilla's Avatar
Car: 88 formula
Engine: 305 tpi
Transmission: M5
Hey guys, I searched and came up with a bunch of diagrams but I must be an idiot cause I can't figure out where this goes
also the heater control valve snapped on me , is there any work around for this as coolent pours out of it now
Old Aug 29, 2004 | 04:26 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
One hose should feed through the firewall for the A/C control head, the other should return from the A/C control head to the heater control valve.
The shorter of the two connects to the plenum vacuum port nearest the Distributor.
Old Aug 30, 2004 | 08:17 AM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
the part u circled goes under the plenum then up to the throttle body.
Old Aug 30, 2004 | 08:55 AM
pyrokilla's Avatar
Car: 88 formula
Engine: 305 tpi
Transmission: M5
ok, then connects to what?
Old Aug 31, 2004 | 04:17 PM
Syxx613's Avatar
ok how can i say this..... its like right by the distributor on the pass side, its low in there and its a little black thing with 2 openings on the top. one little hose goes in one and the other little hose goes in the other. it just fits right in. i dont know how else to explain it and i dont know what its called off the top of my head.
Old Aug 31, 2004 | 08:03 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
The part of the hose with the 90* end on it goes to a port under the bottom of the driver's side of the throttle body. The straight end sticks out the passerger side of the thorttle body and is 1 of 2 hoses that goes to the charcoal canister.
That should help some.
Old Aug 31, 2004 | 08:53 PM
pyrokilla's Avatar
Car: 88 formula
Engine: 305 tpi
Transmission: M5
thanks! I have a terrible idle right now, even the engine dies sometimes at a stop, could vacuum lines connected incorrectly do this?
Old Aug 31, 2004 | 09:26 PM
slowTA's Avatar
Car: '88 Formula
Sure I don't see why fixing that wont hurt. You should have a vacuum leak now at idle/low throttle. Once the blades open up there is less vacumm on that port so less of a leak. At least thats how it was explained to me.
Old Sep 1, 2004 | 10:37 PM
Syxx613's Avatar
yes the disconnected hoses would cause that. it happened to me before.
Old Sep 2, 2004 | 03:18 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
The diagram show at the following link is identical to my 88' TPI.
Vacuum Hose Routing Diagram
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
