Fuel injector retaining clips...
Old Jul 18, 2005 | 12:56 PM
iroczz89's Avatar
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
While replacing my stock 19 lb injectors with my new 30 lb ones 2 of my retaining clips broke!! I have tried chevy, all of the comercial parts houses and some friends with parts cars. Is there anyone out there that knows where i can get the original c type reataining clip for the top of the injector into the fuel rail??
Old Jul 18, 2005 | 02:22 PM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
I'm no TPI guru, but I'm thinking they aren't needed. Once the injectors are in the manifold and the rail is installed and bolted down, those clips are doing nothing.
-Dave
Old Jul 18, 2005 | 04:05 PM
brutalform's Avatar
Old Jul 19, 2005 | 01:24 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
They are needed.
The part number you seek is 17111267 for the injector retaining clips. They're expensive, GmPartsDirect lists them at $3.34 each before shipping.
Old Jul 19, 2005 | 03:09 PM
91Z28-350's Avatar
MSD #2110. 8-pack $5 at summit.
Old Jul 19, 2005 | 06:03 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
the dealership I went to had 1 pack in stock(they sell them it a pack of 5) and it was a little over $7.00
Old Jul 19, 2005 | 10:54 PM
iroczz89's Avatar
Engine: 383 tpi
Originally posted by Jade Grey
They are needed.
I did get them from a chevy dealer but they said it was not a gm part. Some antique replacement warehouse--pack of 5..$7. the gm parts guy said they were not a replacement part that wears out??
WHatever..i am glad i found them..time to get this iroc z purring again and call out a few mustangs!!
Old Jul 20, 2005 | 01:11 PM
Jade Grey's Avatar
Engine: 305TPI
GM originally packaged them in fives. GmPartsDirect often breaks mulitples into singles for pricing.
After some searching, KEM makes replacement fuel injector clips too. The style used in the TPI motors is part number 148-022.
Old Jul 20, 2005 | 04:28 PM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
the injector clips are not needed, I am not running them and know a lot of people who are not as well. the clips just make installation of the injectors into the manifold easier. pop the injectors into the fuel rail, set the rail in place, then pull the injectors down all the way into the manifold. they will be right where they need to be.
Old Aug 10, 2005 | 12:04 AM
plowboy77's Avatar
Car: 1976 Chevrolet Blazer
Engine: 383 TPI
Transmission: SM465
Axle/Gears: Dana 44 front, 12bolt rear. 3.73
Injector Clips
I've read several people say they aren't necessary and I'll let other people argue that. I got a set just to make myself feel better and here is what I found in my search.
These are all different part numbers for the same clip and prices are current as of 08/09/05:
Borg-Warner #28417 = $1.29 each @ O'Reilly Auto
AC Delco #17111267 = $6.67 each @ GM dealer
GP-Sorensen #800-9417 = $3.99 each @ Auto Zone
Summit #MSD-2110 = $4.88 for 8 @ Summit ($9.00 shipping)
I ended up going with the Borg-Warner clips since they were the cheapest and easiest to get. I could have gone to a bone-yard and scrounged them up but I just don't have the time to do that as much as I'd like.
Hope this helps someone in their search!
Russ
Old Aug 10, 2005 | 11:07 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
No clips here. My injectors wont have the provisions for them, plus mine are a tad shorter.
Old Aug 10, 2005 | 11:12 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Don't have any clips on mine, only problem i have ever had is when i am pulling the fuel rail and injectors one has popped out and relieved the rail of pressure. Gm put those in for assembly purposes theyre a pia to take out anyway run without um.
Old Aug 23, 2005 | 06:02 PM
Ragtop89's Avatar
A-HA!!! There's all the info I've been looking for!
Old Oct 10, 2010 | 01:32 PM
KTMAC's Avatar
Re: Injector Clips
Russ
Great JOB Russ! I searched "all over HELL" and finally saw your response!
Old Oct 11, 2010 | 08:33 AM
plowboy77's Avatar
Engine: 383 TPI
Transmission: SM465
Re: Fuel injector retaining clips...
As much time as it took me to figure out part numbers and sources of those things, I figured I just as well help some other folks out! Glad I could help!
Russ
Old Oct 11, 2010 | 08:41 AM
InjectorsPlus's Avatar
Former Sponsor
You don't need the clips.
Old Oct 11, 2010 | 10:40 AM
KTMAC's Avatar
I ordered the BW part number - but I think what I really wanted was those small, wire-type spring clips that hold the electrical connector to the injector!
lol!
Old Oct 11, 2010 | 12:56 PM
Former Sponsor
OH OK, I thought you meant the fuel rail clips.
Old Oct 11, 2010 | 09:31 PM
Guest
Guest
Posts: n/a
Actually everyone should be using those as well. I've seen more than one member have an issue and I have a fuel rail/manifold set (both GM) that you can unseat the injector from the rail without the clip. All it takes is not being seated right, or someone to move your injector while working on the car and you've got a fuel leak. Bad idea to advise not using them.
Old Apr 8, 2016 | 05:03 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
This is why this board is great! Thanks Russ, I bought eight today from oreilly
Old Aug 11, 2017 | 05:38 PM
kfairshon's Avatar
From: Maple Falls, WA (5 miles south of Canadian border)
Car: Yellow 85 IROC [Rare 1 of 205 GU6]
Engine: 5.0 TPI(30-over w/forged internals)
Transmission: 700R4 (NASCAR built)
Axle/Gears: GU6 3.42
Just a quick update... Anyone looking for these injector clips, they are still available through O'Reily's under the Borg-Warner #28417. They are currently going for $1.39 each. However, I discovered some of the parts guys had trouble finding them because there is a database error. They are erroneously listed as "spark plug retainers." Go figure. Anyway, hope this helps.
Old Aug 11, 2017 | 09:01 PM
GeneralDisorder's Avatar
You don't need them. The rail is bolted down. The clips were only there to assist assembly at the factory. Most modern systems employ no such clips.
GD
Old Jan 1, 2019 | 10:01 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: Injector Clips
Russ
An update to the list above. picked up the clips in an 8 pack from Auto Zone for $0.95. They were in-stock at the local store, contrary to the website. They also had the o-rings for the fuel lines.
Part # 800-9411
Old Jan 3, 2019 | 12:00 PM
southbay08's Avatar
you do not need the injector clips. Once the rail is bolted down you have at least 40psi holding them in place. They aren't going anywhere
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
