what is teh difference from a ls1 and ls6?
Old Dec 24, 2002 | 03:59 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Hey,
Just wondering what the differences are.
I know the ls6 as less ci then the ls1. I know it has a differen intake manifold then the ls1 even though they look the same.
What is different about the blocks?
thanks
Old Dec 24, 2002 | 07:04 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Here I believe the LS6 has a different cam, the flow better, and the valvetrain is different.
Old Dec 24, 2002 | 09:49 PM
Nasty_Bird_'90's Avatar
The intake manifold is a little different. It flows a little bit more and has no EGR. The cam is also slightly larger. The valvetrain is the same as an LS1.
Old Dec 24, 2002 | 11:35 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
The manifold on the LS6 is the same as the 01-present LS1's. The valvetrain is different too. I believe the valves in the heads are different.
Old Dec 24, 2002 | 11:59 PM
TexasLT1's Avatar
Car: '92 RS
First, LS6 does not have less c.i., they are the exact same block. Only differences are intake, cam, and heads. As derfrank said, Ls1's from 01 up have the LS6 manifold.
Old Dec 25, 2002 | 09:12 AM
Trux's Avatar
Transmission: t-56
ummm..
if you read the specs on teh ls6 in the z06 it has something like 337 or something around there for ic. I am not saying the block is a smaller block. It is probably a different crank shaft that is destroked.
Old Dec 25, 2002 | 09:43 AM
The whole short block is the same as an LS1 (that means the crank too). The 98-00 f-bodies had a different intake but 01- present LS1's have the LS6 intake. The LS6 heads and cam are slightly bigger.
Old Dec 25, 2002 | 10:47 AM
Trux's Avatar
Transmission: t-56
Umm...
I am pretty sure the ls6 has less ci. I know I have read it a bunch of places. Can't seem to find them online though.
Old Dec 25, 2002 | 10:48 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
LS1 vs LS6
There are minor differences in the oiling systems, and the block actually has some minor inprovements over the LS1 for reliablity, but none are really power producive. Bore and stroke are identical, there must have been a typo on your resource.
The LS6 heads are different, ports and combustion chambers are slightly upgraded. Cam is a little bigger in LS6, and as stated correctly, all LS1's from 01-on have the LS6 style intake.
The exhaust and intake was also changed on the later Z06 cars, as was the MAF sensor. Many minor changes resulted in a major power improvement. Naturally, the computer was recalibrated for this, too.
To answer your question, as I think it relates here, primarily heads, cam MAF and intake.
Old Dec 25, 2002 | 02:39 PM
Guest
Guest
Posts: n/a
Yes, the LS1 and LS6 have the same CI of displacement, 346.
Here's a little info from GM themselves (down to the bottom)
http://www.gm.com/automotive/gmpower...ews/press5.htm
Old Dec 25, 2002 | 03:10 PM
Trux's Avatar
Transmission: t-56
oops
me bad
I know what I was thinking now. I must have said 346 and I automaticlly thought the ls1 was 350.
someitmes I think too much. sorry.:hail: :hail: :hail:
Old Jan 2, 2003 | 04:43 PM
Drakar's Avatar
Also I believe the new vette LS1's 02?03? have hollow stem valves for a lighter valvetrain helps make the 400hp
Old Jan 2, 2003 | 07:43 PM
TexasLT1's Avatar
Car: '92 RS
I thought only the LS6 had the hollow valve stems...I may be wrong, however.
Old Jan 4, 2003 | 12:48 AM
Drakar's Avatar
LS6
my mistake
that is right only on the Z06 so yes it would be the LS6
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BAMiller
Sep 14, 2015 06:38 PM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
greenyone
Sep 2, 2015 03:39 PM
