Calling all wells SU-145 MAF users...
Old Nov 27, 2003 | 10:25 PM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
This problems has been plaguing me. Got this MAF sensor and replaced relays associated with MAF sensor and I still get code 33... I've reset the computer by disconnecting the battery and I've tried to test the TPS unsuccessfully with a multimeter (stuck probes in but got no reading, might have done it wrong). It could be my TPS but I somewhat doubt it as I've not adjusted it ever. Did any of you have a similar problem? What were your expiriences with this???
Old Nov 27, 2003 | 11:29 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
well everyone here knows the trouble ive had with them(any MAF sensor)...ive had brand names & off names & everything in between! nothing worked,took the car to different mechanics around town & they are replaced the MAF sensor with a new one,leaving me to replace them EVERY YEAR
this last mechanic i took it to,i HOPE fixed it cuz ive had no problems with it i cant remember whats in there now-lol...if you really wanna know i can look tomarrow & let you know,let me know...good luck with yours!!
Old Nov 27, 2003 | 11:54 PM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
Please do... Other than replacing the relays and the MAF sensor, what have you do in regard to this problem?
Old Nov 28, 2003 | 05:45 PM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
Anyone?
Old Nov 28, 2003 | 08:56 PM
Engine: 283
its an "AC MAF sensor" in there now
i dont think they replaced the relays...all of them replaced the other one with a new MAF sensor,thats all they done
Old Dec 4, 2003 | 02:03 AM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
I know more than 1 person uses the Wells unit... please speak up your input is very important to me. Is there anyone out that that uses the Wells unit that -DOESN'T- get an SES code?
Old Dec 4, 2003 | 07:22 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
When a repair shop gets a code 33 and they replace the MAF. That is not always the case, the relays on the firewall are most likely the problem. Been using the WELLS Maf for two years now without a problem. So if you want to spend $500 for a stock replacement go ahead. But in most cases itis the relays. Also how does the car run if you are getting a code 33 with a WELLS???
Old Dec 4, 2003 | 03:57 PM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
It doesn't run like it's supposed to. And I have already replaced the relays too.
Old Dec 6, 2003 | 06:14 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have the Wells unit and have had no problems with it. Have you tried it in someone elses car?
Old Dec 6, 2003 | 06:38 PM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
I have no friends with thirdgens. I have a buddy with a 4th and a buddy with a c4. Everyone else is useless
Old Dec 6, 2003 | 06:55 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Go to the regional boards and try to find someone near you who will test it for you. If you have replaced the relays and still no joy, it may be a faulty unit. I have heard of very few people having problems with the Wells unit.
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
maroe624
Apr 16, 2017 08:29 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Warlocksirix
Sep 3, 2015 12:26 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
