Any have pic of Megashifter installed in f-bird?
Old Feb 4, 2003 | 02:21 PM
Nitroburn's Avatar
Anybody have pic of Megashifter installed in f-bird?
As the title says. The reason why I'm asking is I'm in the middle of installing one myself. However, the template that is included with the B&M Megashifter to modify the console cover so that the B&M shifter cover/boot install is nowhere near the right template!
The directions are telling me to line up holes marked "B" with the two holes towards the back of the cover. But the hole's marked "B" on the template is too wide! WTF?!?!?
So, if someone has a good close up pic of their Megashifter installed in a Firebird that would be great!
Thanks all
-Mike
Old Feb 6, 2003 | 10:37 AM
Nitroburn's Avatar
You guys are killing me!!! Anybody? Thanks!
Old Feb 6, 2003 | 11:37 AM
deadtrend1's Avatar
Schultzy89GTA GTA has one .... here
Attached Thumbnails Any have pic of Megashifter installed in f-bird?-schultzy89gta.jpg
scauffiel's Avatar
This is the best that I can do for you brother! Hope it helps!
The semicircular hole you see peeking out from under the plate is from a gauge I had mounted there; just FYI.
S.
Old Feb 6, 2003 | 11:52 AM
Nitroburn's Avatar
deadtrend - Thanks! That give me an idea of what it'll actually look like with the grey console.
scauffiel - That's a perfect shot! It looks like you have the plate mounted just below the ashtrey level enough for it to clear (so that you can open it). Is that correct? Also, that white console cover really brings our the shifter!!! Nice work!
Thanks to both of you guys!
Mike
Old Feb 7, 2003 | 08:03 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
whats the point of those? just looks or does it serve some extra purpose?
Old Feb 7, 2003 | 08:11 PM
Nitroburn's Avatar
Huh... read the first post
Old Feb 7, 2003 | 08:15 PM
TekViper's Avatar
Engine: 3.1L v6
i did read it, what am i missing? is the shifter just asthetic or does it do something the stock shifter doesnt?
Old Feb 7, 2003 | 08:39 PM
deadtrend1's Avatar
both!
It looks a hella lot better than the stock auto one.
Look up in summit .... it tells you hwat it does. It enables you to start out in 1, slam it hard as you want forward into 2nd gear, but only goes one gear at a time. 1 ... bang ... 2.. bang ..... d..... bang .... lala.
Old Nov 20, 2003 | 01:26 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
You know exactly what gear its in and it will not go more than 1 gear at a time. Much better for racing.
Old Nov 20, 2003 | 08:54 AM
bigals87z28's Avatar
Car: Check The Sig
I like this one better.
Old Nov 20, 2003 | 06:22 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Originally posted by deadtrend1
both!
Yeah, and how long did it take us to figure out exactly how it worked?
Old Nov 20, 2003 | 09:15 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
and 3 bang...... "vroooooooooooom rattle, rattle, rattle.... dude I knew i should of got screw in studs" lmao I speak from experiacne.
Old Nov 21, 2003 | 08:29 AM
deadtrend1's Avatar
I know right, we must have spent 30 minutes holding it to the coffee table trying to figure it out.
Old Nov 21, 2003 | 08:52 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
This isn't that great of pics, but I installed mine without the brackets so it would fit under the stock trim plate. I have since replaced the rubber boot with a pleather made one from walmart I handmade myself... stiching and all.
Old Nov 21, 2003 | 03:25 PM
Dr G's Avatar
Nitroburn, here are a few threads with pics of the B+M Megashifter for you to look at, if you've not had enough of them!:-
https://www.thirdgen.org/techbb2/sho...ght=megashifter
Picture of Installed B&M Megashifter?
need pics of b&m megashifter PLZ
Vintageracer
Jan 10, 2020 05:33 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
aaron7
Aug 17, 2016 06:02 PM
mustangman65_79
Aug 13, 2015 07:36 AM
sonu1975
Aug 11, 2015 08:38 AM
