Why can't I get the motor mounts off?
Old Oct 29, 2002 | 10:21 AM
TBI305Camaro's Avatar
I bought a new set of motor mounts because I was gonna go ahead and swap them when I swapped motors just for good measure. I tried to unbolt them and the bolt just spins...whats up?
Old Oct 29, 2002 | 10:49 AM
ede's Avatar
ede
you need to hold the nut on the other side to keep it from spinning. have fun or lots a luck
Old Oct 29, 2002 | 11:30 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Exactly, the mounts have both a nut and a bolt for every contact. Sucks and its a big PITA.
Have fun.
Old Oct 29, 2002 | 03:31 PM
mine arent broken so I guess I wont change them then. I wanna get the motor in anyways Im tired of all the setbacks.
Old Oct 30, 2002 | 10:23 AM
cdogc350's Avatar
they are a b*tch. GM forgot to make a small hole in the crossmember to put a socket on the bolt. you have to shove a wrench in an opening on the member..and try to reach the bottom bolts while trying not to lose the nut in the hole (that doesnt sound right, exuse my gutter mind?). its tuff
Old Oct 30, 2002 | 10:28 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Did you take the motor out first.
Old Oct 30, 2002 | 10:39 AM
cdogc350's Avatar
damn mark??? i commented on your posts about 3 weeks ago...AT 10,500 OR SOMETHING... your at 12,000+ holy sh*t..
somebody award this guy!!!!...hes a machine. there has to be a spot for this on the guiness book of records.serously!!:rockon: :rockon:
Old Oct 30, 2002 | 11:03 AM
Car: 99 Formula
Axle/Gears: 342
It has to have been more than 3 weeks.
Old Oct 30, 2002 | 03:10 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I did it. Took 2 people and 6 hours. Was it worth it? Hell yeah.
I replaced mine with Energy suspension P.U. (because I cant spell poly Uerethane) motor mounts...
The difference? Now my engine doesnt hit the hood when I gun it. and now i can really feel the engine. and now it sits where it should. In my opinion, The stock rubber is crap, it sags, breaks easy, cant take torque, its micshy, and lets your engine move around too much. 'nuff said.
Old Oct 30, 2002 | 03:24 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Haven't looked too much at mine on how exactly they work, but if you are replacing them, can't you just cut these bolts off?
Old Nov 1, 2002 | 07:12 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Not sure that's a good thing...
You can get to the nuts at the control arm attachment point with a 15mm swivel socket and a 3/8" extention. Keep a magnet on a stick to fish the nuts out when they fall into the crossmember. Do it when you are fresh (AM after a cup of coffee) because it requires a certain degree of patitence, not all of us have.
Old Nov 1, 2002 | 02:11 PM
Marc 85Z28's Avatar
Agreed. I replaced both of mine in about an hour and a half. I don't see why everyone has so much trouble with these.
Old Nov 1, 2002 | 11:06 PM
laiky's Avatar
i removed my control arms while doing my springs and just welded the nuts to the chassis. Before that i replaced them with the aformentioned swivels and magnets..
please note an impact gun makes tightening them easier!
Old Nov 2, 2002 | 01:33 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Ah memories. In all honesty you should go ahead and change them now while the motor is out, because if your motor is tapping on the hood in a year from now, you'll be sorry. First time I changed one of mine, it took near two hours of fumbling around with swivel sockets and extensions and such. I can now change them in about 10 minutes per side. My secret? Being a girl, I've got tiny little hands and wrists, and I just crammed my hand, with a wrench, through that tiny gap between the A-arm and the k-member. Of course that's not really an option for most of you guys. I've also heard that you can buy a cheapo wrench and bend it to a certain angle so you can get at that one PITA nut.
Old Nov 2, 2002 | 08:29 AM
radiateu2's Avatar
mounts
looking at viciousz photo it looks like you could jack the wheel up on the side your changing for more room where she is placing her hand. Did anyone else notice this.
Old Nov 3, 2002 | 12:30 AM
i went ahead and didnt change them yet. I plan on having the motor out this summer to swap the cam and heads so ill get the good ones then
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
