Need additional advice for polishing 91-92 rims.
Old Jun 16, 2002 | 05:42 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I am in the process of polishing 91-92 Camaro rims. I am at 800 grit sandpaper. This is what's happening. Some spokes are silver appearing and dull and some on the same rim are reflective. Then some spots are this way at different angles. Will this go away as I progress further or do I need to start over again? I have all the way up to 2000 grit. What size do you go to to see your reflection in? Thanks
Old Jun 16, 2002 | 06:27 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Anything above 400 won't remove scratches. If I recall 800 removes orange peel, I skipped that grit on one wheel. I couldn't see reflection until I actually put the polish on. I found the 3M Aluminum Restorer before polishing works very well.
Be sure to wetsand with 1500 that helps a lot. I used WD-40 to make sure the surface was completely lubricated.
Attached Thumbnails Need additional advice for polishing 91-92 rims.-irocwheelpolish4thone-006small.jpg
Old Jun 16, 2002 | 09:12 PM
Camrs89's Avatar
Thanks Mark. I just started on 800 so I will see what it will do. Did you apply the polish by hand or buffer? I am just running the hose over the rim while I am sanding it. Is it easier with the wd40?
Old Jun 16, 2002 | 09:43 PM
David Culpepper's Avatar
Yeah, I would follow through with all the grits recommended in the tech articles and not skip any. Even though it may seem like it is not helping, it is getting some of the fine scratches and marks left by the previous grits. Definitely apply the aluminium restorer it helps a lot. Apply it by hand because using a buffer may "burn" the metal. It is better in my opinion to use wd-40 when wetsanding because it provides better lubrication, but if as long as you have steady flow of water that works perfectly fine also.
Old Jun 16, 2002 | 09:53 PM
87transam5.7tpi's Avatar
I dont' think there is any point in going over 400grit wet. I just doesn't work as well in my opoinion.
Old Jun 16, 2002 | 10:56 PM
BT305TA's Avatar
polishing wheels
I have a 91 camaro z28 and i polished all of my wheels. and yes it takes a long time. I first started out with aircraft remover and removed all of the clearcoat finish. Then i used 400 grit to get all the factory machine lines out. then go to 600, 1000, and finally, 2000 grit. then i usually polish and then go over with 2000 again. then polish a few more times and everything should be fine. the polish i use is blue magic for like 5 buks at pep boys. good luck!
email me at Mackatallica@yahoo.com
sincerely,
Mackenzie P.
Old Jun 16, 2002 | 11:53 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Re: polishing wheels
sincerely,
Mackenzie P.
You started with 400 to ge the machined grooves out? That must have taken forever! I started at 80 and that took a while.
Any pics of your rims?
Old Jun 17, 2002 | 02:47 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Where did you find it ?
Where did you find that 3m Restorer ? I cant find it anywhere.
Old Jun 17, 2002 | 02:56 AM
Car: 99 Formula
Axle/Gears: 342
I got it at Wal-Mart, Autozone also has it.
Old Jun 17, 2002 | 08:07 AM
Car: 1989 IROC-Z
Engine: 383 stroker
Maybe not all of them carry it... I tried Wal-Mart, Autozone, and Pep Boys and never found it. I didn't use it and my rims came out pretty good. I still want to go over them with 1500 wet and maybe 2000 wet though.
Old Jun 17, 2002 | 11:25 AM
Did you try Wal-Mart in the boating supplies? That is where it will be if they have it. I know that seems like an odd place, but that is because it is used primarily on marinbe applications.
Old Jun 17, 2002 | 12:28 PM
Nazzz28's Avatar
Car: 91 z28
Transmission: 700 R4
I did notice the papers over 600 grit taking out the
remaining scratches. I also noticed that if you sand in one
direction on one spoke and the other direction on another
one can look dull and the other can look shiny. I would continue
going through the grits then polish and the whole wheel should
be reflective. My rims didn't look reflective even after 2000 grit,
until I polished and then they looked like a mirror. By the way I
polished by hand for the best results.
Old Jun 19, 2002 | 11:12 PM
Camrs89's Avatar
I just started using 1000 grit today. So i will see what happens next. It should turn out good. Just time consuming.
Old Jun 21, 2002 | 01:30 AM
Car: 1987 IROC Z
I live in texas
I live in El Paso Texas,( a desert town) I don't think the walmart here sells boating supplies... Sadly, I cannot even find any sand paper over 450 grit !!! Not at Walmart, nor autozone, nor any of the places you would expect to find it... not even at freakin hardware stores. If anyone knows where I could get these things online, I would be most grateful.
Old Jun 21, 2002 | 02:14 AM
Nazzz28's Avatar
Car: 91 z28
I know that Advanced Auto Parts sells up to 1500 grit 3M paper,
because that is where I got mine. I think they have a web site
where they sell stuff on line. I found the 2000 grit paper at a small
local shop so you could try there if you have a shop in town. Also,
if you know any body shops in town you could ask them where
they get theirs or if you can purchase some through them. They
should have some up to 2000 grit for wet sanding. Good luck
finding what you need.
Old Jun 21, 2002 | 01:47 PM
Camrs89's Avatar
I got all but 2000 at advanced auto parts and got the 2000 at autozone. Try that place too.
Old Jun 21, 2002 | 08:32 PM
Car: 1987 IROC Z
don't have any advanced auto parts here... guess i'll have to hit the body shops..
Hotrodboba400
Dec 10, 2019 07:07 PM
fasteddi
Sep 10, 2015 09:32 AM
scottmoyer
Sep 7, 2015 07:06 PM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
