Porting Vortec heads
Old Sep 24, 2005 | 05:34 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Just thought I'd post a few good pics that show what to do to a Vortec head When switching to a larger 2.02x 1.60 valve.
These are not my heads but mine are just the same.
There is a lot of disinformantion floating around on what can and should be done to a vortec head for increased performance.
A picture says a thousand words. Not just a truck head anymore. The nice thing is you don't have to be a porting guru to do this.
Old Sep 24, 2005 | 05:36 PM
F-BIRD'88's Avatar
Here is a shot of the intake port before and after.
No need to make a huge port. Just finetune what is already there.
Old Sep 24, 2005 | 06:08 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Kewl. Can you also show the exhaust ports?
Old Sep 24, 2005 | 06:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Do you have flow numbers?
Old Sep 24, 2005 | 06:32 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I can show mine.
I'm far from done (working 65 hrs/week put a damper on my plans), but I'm getting there.
Old Sep 24, 2005 | 07:11 PM
F-BIRD'88's Avatar
they are not my heads. Just a nice clear picture of a simular job. No other pics right now.
Can only tell ya that my heads flowed 245+ intake and 180 ex
Was hard to get a flow reading on the intake side cause there was so much air velocity that it keep sucking in the inlet radius puddy. We gave up at 245+. (Free flow bench test.) After playing with it 6 times we got a good test so good enough. Kinda knew how they were going to turn out cause others have done the same thing. Just wanted to verify what was expected from the mods done.
The radiused inlet (puddy or fixture) on the intake ports are critial to getting accurate flow test numbers. Especially on a small high velocity port like a SBC vortec.
Without the radius on the port opening the tests are meaningless.
No track testing yet, but can tell ya the engine is a goer for sure.
Hold on Newt!! We're headed for the alfalfa!!!
Old Sep 24, 2005 | 09:47 PM
11 Flat's Avatar
Those were a 2.05 valve. Heads had more in them
Lift----Intake----Exhaust
.200----143.9-----119.5
.300----192.2-----169.9
.400----235.7-----195.5
.450----252.3----------
.500----264.1-----207.0
.550----258.6----------
.600----265.1-----212.6
.650----271.0----------
.700----271.1-----215.6
.750----272.0----------
Old Sep 24, 2005 | 10:22 PM
AJ_92RS's Avatar
WOW!!!
Those heads really suck.... I mean blow... errr... flow!!!
Was that at 28 in/Hg?
Old Sep 25, 2005 | 12:01 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Okay, so why no profiling on the intake guides? Do the ports/runner/CC allow so much swirl it's not needed?
I took a similar approach on a set of 083's a few years back, but thought after taking down the intake guides I messed up and haven't run them yet.
I left a slight "bevel", more than I can see on the pics above, but curious if it's an apple to apple comparison?
Old Sep 25, 2005 | 12:26 AM
11 Flat's Avatar
28 in....no pipe on the exhaust. I did not port these heads but I know the guy that did. [very good porter] They were not maxed out either. More flow to be had.
If I can dig up the sheet from a set I did. [more work then the ones above] I'll put the numbers up. Those went low 280's
Good to see people at home are trying to port vortec
But so and so meet a guy who knows a guy thats friends with a guy that says they cant be ported
Old Sep 25, 2005 | 12:36 AM
11 Flat's Avatar
Which pic are you talking about the ones F-BIRD'88 posted or the ones AJ_92RS posted?
Old Sep 25, 2005 | 12:45 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
F-Bird pic in his first post. Actually what I see as a profile, is on the wrong end, or have I had one too many?
Theres just a slight "point" on the intake guide, unless the pic isn't doing it justice? AJ needs to hit the hotank before getting into things
Old Jan 13, 2009 | 11:40 PM
davtracy's Avatar
Car: 89 camaro rs
Engine: 406sbc
Transmission: 700r4 2800 stall
Axle/Gears: 4.56
Re: Porting Vortec heads
Hey, I'm new to the sight. Your heads look great. I run vortecs on my 91 bracket car. Set up for added lift. People call these truck heads, but they work great. Run consistent 8.40's with a voodoo 256 hydraulic flat tappet. Can't go wrong with ported vortecs.
That's in the 8th at 83mph
Old Jan 14, 2009 | 02:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
F-bird - how did you/they decide the size of the ports? I see the scribe marks... That from a Vortec intake port gasket? a specific one?
Old Jan 14, 2009 | 02:23 PM
Stephen's Avatar
Car: 87 GTA
No flow comparison #s from before & after porting?
Just curious, because bigger is not always better. Put a 1050 double pumper carb on a 305, & you've got a real dog......
Old Jan 14, 2009 | 02:39 PM
F-BIRD'88's Avatar
Sonix I don't know what of if they were ported to any specific off the shelf gasket.
I believe these heads were ported for a Super Vic manifold that had also been ported. Used on a 10.5:1 406 it made over 500hp.
You don;t nessessairy have to make the port opening quite that big. EG: on 350 or 383 with a dual plane manifold.
But just wanted to show some good pics of nicely done vortecs.
Again these are not my heads. Mine are simular but theses pics are very good at showing what they are suposed to look like in finished form.
Old Jan 16, 2009 | 11:48 PM
davtracy's Avatar
Car: 89 camaro rs
Engine: 406sbc
Axle/Gears: 4.56
Hey f-bird. I was curious as to what cam, compression, and times you are getting out of your vortec 406. I am working on building one. So far professional products single plain, 10.5:1, 800 holley, I run 456 gears. Looking for 6000-6500 rpm. Any suggestions?
Old May 19, 2009 | 11:15 PM
jevonniespapi's Avatar
Wow, would love to see some more pics. im getting into the vortec game and want to get some good power!
Old Aug 22, 2009 | 12:30 AM
bob442's Avatar
just doing my research on these heads, thought i would bump up this topic and see if theres any track testing and any pictures of the exhaust ports yet. As we all know the intake ports are rather large, the exhaust ports are rather mediocre, and theres alot of metal to shave away to match up to the exhaust gasket.
Old Aug 29, 2009 | 11:53 AM
levisnteeshirt's Avatar
first time post, long time lurker , what gasket did you use to outline the intake port, and whats your opinion of the Patriot vortec head , it already has the 2.02 valve and a 185cc runner ,,, building a bracket engine , 4.030 x 3.625 stroke , 7500 max rpm
Old Aug 29, 2009 | 11:54 PM
F-BIRD'88's Avatar
Check out my VB garage page. The info is there. Still a work in progress.
While you'll see vortec heads pro ported for full race application with a very high lift cam.
.600"+ my head were ported to optimize flow from seat to .500" lift for a engine that uses a relatively moderate street cam and rpm. Optimum port/bowl size/shape is a bit different for a (street) engine where the valve stays relativley close to the seat (.500" or less) as compared to a full race effort port job for a higher lift race roller cam where the valve is further from the seat. (longer duration and higher average valve lift.)
I ported my vortecs to match the felpro #1255 vortec gasket. I did not touch the intake manifold.
As I posted earlier the pics I posted are not my cylinder heads. They are someone elses.
They are nice clear pics of a very good porting job on vortec heads. I did not open up the intake port at the inlet quite as much as these pics show. These were done for for a super vic vortec single plane manifold that also was tweeked a bit. My intake manifold was/is untouched.
Old Sep 16, 2019 | 05:10 PM
Art_H's Avatar
FBird'88
I think I saw your handle over on SpeedTalk, where they were chatting about the new DV Vortec Porting Video.
Not knocking your porting job from 2005, but it's amazing that good info can do. Too bad DV held back on the exhaust side, and the main port. But I don't suspect that I will ever go down for his Porting Lectures. Seems he's at a crossroads for monetizing his knowledge and info. The seminar thing just doesn't work, compared to the online options available.
Glad to be back on Thirdgen...been too long.
Old Sep 16, 2019 | 10:42 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Originally Posted by cuisinartvette
BTW these are NOT VORTECS like YT says.
Herer is what I have on Dart KO...NKB basucally
Pics are untouhced so take away 3-10cfm? no pipe on exh!!!
2.02 v fkiwed on 4.125 bore int and exh first pass....2nd I wont even bother with too many bs callers.
.200 160 125
.400 250 186
.700 265.219
AFTER
.200164 141
.400 270/201
.700 .299/.234
Not sure why mine were so bad before but this is what Lloyd Elliot said mine did before and after. I believe him although my 350 ran great with a different set of the same heads on it.
BEFORE
LIFT------INTAKE-----EXHAUST
.200----------135-------103
.300----------183-------131
.400----------225-------150
.500----------244-------164
.600----------241-------175
.700----------241-------177
AFTER
.200----------138-------107
.300----------192-------138
.400----------241-------164
.500----------274-------183
.600----------291-------193
.700----------295-------199
Old Sep 25, 2019 | 01:11 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Those arent factory seats valves etc please dont mislead guys into thinking they can take a dremel to those lousy heads lap them and make good power not gonna happen.
Fast355 those should run good .I get slammed a lot for going after more exh percenetage usually by guys who are trying to make $ doing it though. Screw em..lol
If it was bad AFR wouldnt be doing it. Anyways I posted in the wrong thread.
Seems he's at a crossroads for monetizing his knowledge and info. The seminar thing just doesn't work, compared to the online options available.]
Problem is people for some reason take what they read as gospel
DV has been at it for decades and knows his stuff. Noone wants to pay for good info even if they know what they are reading off the web or YT is bs they still convince themselves free or cheap is right. Nothing good is free.
Old Jan 8, 2020 | 09:18 PM
Cary I. Fowler's Avatar
no need for fowl potty mouth
Old Jan 8, 2020 | 09:19 PM
nice
birdman_29
Oct 17, 2010 07:24 AM
ineeedmorespeed
Aftermarket Product Review
Aug 2, 2006 12:37 PM
fin170703
Dec 4, 2005 03:26 PM
MrNova
Dec 27, 2002 04:30 PM
need4speed
Jul 17, 2001 12:42 AM
