Orange Radio Wire...
Okay, I screwed up my car somehow while soldering a few wires and there is no power going through the orange wire off the radio. I need to know if anyone knows where that ends up so i can either find the problem or run a new wire. Thanks.
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
uh. the fuse box would be a good idea!
Car: 89 formula 350
Engine: L98(350)
there is another fuse panel above the gas pedal if all the fuses are good in the other fuse panel check the one above the gas pedal. it is a small fuse panel that snaps up and is not visable unless you drop it down. had a gta come in that had no power to the orange wire at the radio and there was a fuse blown in there. replaced fuse and had power then(orange wire).
Okay, took some time to finally get the answer and since then i have spliced in a new wire but the there is a fuse labeled "arc radio" or "arc" In 85-89 the arc radio fuse is on the convience center. In 90-92 this is on the fuse box itself labeled arc, it's at the bottom. Both are 20 AMP fuses. Thanks to acescarrsRS for the help!
Car: 89 RS
Engine: 383 in building process
No prob man. Glad to help. And for all you 85-89 Camaros here's the pic of the fuse. I circled it. Hard to read but it does say 20 arc radio
Gunner242
Dec 25, 2015 04:49 PM
