what is this pice its just about gone need to be replaced pics in side
Old Aug 16, 2004 | 10:14 AM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
what is this part and anyone else got this problem? where can i get a replacement part whats a good price for it?
Attached Thumbnails what is this pice its just about gone need to be replaced pics in side-under-my-bumper-1.jpg
Old Aug 16, 2004 | 10:39 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
That is (or was) your rear impact bar. I wouldn't go getting rear-ended with that thing.
Old Aug 16, 2004 | 10:57 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Yup, that's what it is. You can usually find them at bone yards for fairly cheap. Since your car is a 91, you may have to get one speciffically from another 91-92. I know that the front impact beam is different on the firebirds for those years, just not sure about the rear.
If you can't find one at the bone yards, then any body shop would be able to get you one. I bought a new front impact beam from a private seller for around $30 shipped, so I think you might be able to get the rear for close to the same.
Let me see if I can still find the page....
http://webpages.charter.net/van.parys/cars.html
Click on 82-92 3rd gen parts, and then...
Looks like the 7th one is what you may need. Email him with your specifics, and he may be able to help you out.
Good Luck
Old Aug 16, 2004 | 03:41 PM
Car: 1997 S10
is this a common problem? will i have to remove the hole bumper to replace it?
Old Aug 16, 2004 | 05:11 PM
Brock's91RS's Avatar
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
From what I've seen, its VERY common,good place for salt and crap to clog up and stay!
I bought one from a guy on the classified on this board,paid 40 shipped,I believe
i see them on E-Bay at times,if you cant find locally
Watch shipping charges tho!
Later
Steve
Old Aug 16, 2004 | 05:19 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You'll have to remove the cover, it's not overly difficult. Remove the taillights and there will be six or seven plastic pushpins to remove, similar to the ones on the bottom; and three nuts on each side down in the wells behind the rear wheels.
The metal piece of the brace should be somewhat universal among thirdgen Camaro's; you should be able to swap the plastic 'eggcrate' onto a replacement piece.
Old Aug 17, 2004 | 06:57 AM
craashmann's Avatar
Car: 1991 Camaro Z28
heh, ohio.. It looks like you took a picture of my car (PA) I guess its really common... Does this peice bolt on or what?
Old Aug 17, 2004 | 07:22 AM
aerosmithr0cker's Avatar
Car: 1991 Z28 clone & 1985 Fiero 2M4
Engine: 305 TPI (In Progress, Camaro) & 2.5L 4 cyl soon to be 3.4
Transmission: 700R4 (Camaro) & Isuzu 5 speed (Fiero)
it bolts on from the backsidce of the bar.
Old Jun 20, 2005 | 09:34 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
Yeah i had to replace mine too. Take off your tail lights, take off your bumper skin, then there will be this Honey-comb type looking thing that runs between your impact bar and your bumper skin. Its harder replacing the impact bar then the other guys lead on to..... If yours is that rusted, like mine, yourll probably end up hack sawing off the bolts because they just continue to spin, very easy way to do it. Your gona have to have someone hold the impact bar while you bolt the new one on. Just becareful not to cut yourself when removing the old one.
wruiz
Aug 11, 2015 02:59 PM
sonu1975
Aug 11, 2015 08:38 AM
89FormulaMan
Aug 10, 2015 10:01 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
