8D code for shift light
Old Jun 24, 2005 | 09:06 PM
91L98Z28's Avatar
Car: Z28
I'm posting this while it's fresh in my memory in case it's useful to anyone.
I wanted a shift light based in the factory computer, to do one and only one thing: turn on above RPM (X), and turn off below RPM (X).
I studied ANHT a bit, and came to the conclusion that the code between 5F7D and 6003 (as seen in a hex editor when directly editing my AXXD .BIN - keep in mind ANHT is offset!!), all dealt with the factory shift light code. I didn't want any of that crud, so I 01'd the whole section ("no op"), and replaced it as follows:
Code:
5F7D	LDAA L0085
5F7F	LDX #$835B ; RPM FOR SHIFT LITE
5F82	CMPA 0,X
5F84	BLS +05
5F86	BSET L0038,#$80 ; SET b7, SHIFT LIGHT ON
5F89	BRA +03
5F8B	BCLR L0038,#$80 ; CLR b7, SHFT LIGHT *OFF*
I reused the value at 035B (835B to the ecm) to control the shift light RPM, which I then entered into tunercat's TDF editor in my custom TDF.
So far, I've tested it on the bench and it seems to work exactly as designed....
the plan from here is to get a bright LED (or multiple LEDs), run them through the appropriate current limiting resistor, then hang them off the shift light pin of my '730. Last time I was at summit, autometer (I think?) had a fairly nice, thin shift light which could also be used, but I think I want to stealth in some LED's somewhere so that they are inconspicous until they light up. Will be using some sort of ultrabright LED so that the thing is plainly visible even under noon sunlight (what good is it if ya can't see it?)
next up is going to be code to handle the t56 reverse lockout solenoid.
Old Jun 24, 2005 | 09:31 PM
91L98Z28's Avatar
Car: Z28
Old Jun 25, 2005 | 09:23 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Neat little setup you got there, I did a similar setup on my fiance' car only using the neanderthaw methode. We just hacked up a proform shift light. We hid the dial in the ashtray and hid three little LED's in the dash. We used super bright blue LEDs from radio shack and man are those things bright. We actually had to wire in a resistor on a switch to tone them down at night. You can't see the road when they kick on!
Old Jun 26, 2005 | 07:58 AM
Craig Moates's Avatar
Car: 87 T/A
I'd be interested to hear about your reverse lockout accomplishments as well when you get there.
By the way, how about RPM resolution up top for the 730? What if you wanted to shift at 7000?
Old Jun 26, 2005 | 09:45 AM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Reverse lockout should be easy enough. Just check current MPH against a max. value (say 5 or so) and enable reverse when below that threshold. That's how the 4th gens do it stock, IIRC. Finding a good place to put it in the current code will be harder than writing the algorythm, although it looks like you opened up plenty of space when you pulled the stock shiftlight stuff.
This is something I had in mind to play with when I get my "test bed" car converted back to EFI.
I had some ideas about the shiftlight too.....I know a few guys who like to shift 1-2 at a different RPM than the rest of the gears for traction reasons....you could set the code up for that as well. Use the NV ratio to determine what gear it's in, and then lookup the shiftlight threshold based on that. Just a simple "if NV > X then use A threshold, if NV < X use B threshold." If you like the same RPM all the time just use the same value for A and B.
Old Jun 26, 2005 | 11:33 AM
91L98Z28's Avatar
Car: Z28
Well, I'm just using the RPM value that the rest of the code (as well as the original shift light code) uses. I believe it's only good for 6400.
Old Jun 26, 2005 | 11:39 AM
91L98Z28's Avatar
Car: Z28
Yep. The code is certainly easy enough, I just have to get around to doing it. I'm not using ASM or compiling, i'm just using a 68hc11 opcode chart and hacking the hex values directly into Hedit one byte at a time. It's a little slow going.
The multi-rpm shift light code would be pretty straightforward as you described. Heck, an adventerous person could set it up easily enough to have a different shift light rpm in every gear.
Old Jun 26, 2005 | 08:05 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
I have wanted a shift light in my car for awhile even though it's automatic. I also think it would look nice to put LED's in the stock shift light location.
Will this work with the AUJP code?
Old Jun 26, 2005 | 08:25 PM
TheGreatJ's Avatar
The output wire that runs the factory shiftlight is used to control the torque converter clutch in an automatic car IIRC. You could write the code to operate the shiftlight on another ECM pin, but that would take more work, and a bit of research to find an appropriate output channel.
Old Jun 26, 2005 | 08:53 PM
91L98Z28's Avatar
Car: Z28
Actually, according to the information I had (and my memory), they are on different pins.
I believe F1 is the shift light pin, and F(5? 6? 7? 8?) was the TCC pin.
I'll double check later when i get home.
Old Jun 26, 2005 | 10:51 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
The shift light pin is on pin GF1 and the TCC solenoid is on pin GF6. So the pins are not shared.
Old Jun 26, 2005 | 11:44 PM
JP86SS's Avatar
Might be able to use the PWM output from 3FCC
Chip "U2" pin 52 connects at 10-U20-11, ECM Pin "F5"
Write 7000 = OFF
Write D000 = 0% DC
Write DFFF = 100% DC
The output is shown as not used but keep reading.
That leaves all the other outputs alone so emmisions aren't sacrificed. makes agood candidate.
There may be a problem using that output in that I show it being used AS the CARS light already. not sure why that is.
Has anyone played with this on a bench to see if the output can be made to work on pin F5 ?
Everything I see at the moment indicates it should be there and not on F1.
Address $0196, bit 4 enables the PWM output.
3FCC sets the duty cycle.
How is F1 turned on? Its late and i'm just not seeing it.
I was thinking of doing a knock light from there but never got to it.
Allot of 730 guys have been looking for that to be implemented.
My original thought was to use the "knock" flag bit ($003A, b0)and the "no knock" ($003A, b1) bit to select the value that was loaded.
Old Jun 27, 2005 | 12:22 AM
91L98Z28's Avatar
Car: Z28
GF1 is bit 4 of 0038.
Old Jun 27, 2005 | 12:48 AM
JP86SS's Avatar
Bit 7 (like it shows in your code)
Could've slapped me with trout on that one!
Old Jun 27, 2005 | 01:07 AM
91L98Z28's Avatar
Car: Z28
yikes. it must be too late. yes, bit 7. don't know where I got the idea for bit 4 from.....
Old Jun 29, 2005 | 04:29 AM
Z69's Avatar
Z69
I was going to get to this eventually, glad someone beat me to it.
$8D 7K stuff....
You have to use FDB L00B3 which = DRP
So you'll have to use LDD 00B3 etc
Or since the only time your interested is when
accB is < FF. Not sure it's accB, I think it might be inverted.
Can't remember right now. Swapping back to day shift so
I'm in a fog...
I believe there are spare non PWN pins available. F3 is one after a quick look.
To get the constant-
983040/DRP=RPM
Note DRP is inverse, so the lower the number, the higher the rpm and vice versa. Rbob posted similar in a few places, but if you're just a hair low on the knowledge curve you'll miss it. I did the first few times I read those posts.
You can stick L00B3 in your aldl and use the above constant in TP to log rpm >6375 too.
I haven't modded my bench yet to go there. But it looks fine when compared to RPM/25 with an occasional variance due to the different method of calculating the #.
The light code mod from above will work on AUJP too I'm pretty sure. Just not as posted.
You'll have to get JP86SS's hac and see what the offsets are between the various bins. While working on my WB patch I found AXXD, ANHT, AUJP are all a little bit offset from each other so you just have to figure out where the referenced code is and change it. Some of the values will be different from the listed code string due to AUJP being an AT bin. IIRC, the shift light is disabled in the code by have a temp? qualifier set to FF. JP might remember since he was the one who told me.
I don't think JP has posted this hac update yet...
Code:
;This section info provided by Scott Lopez (Z69) and many thanks for the head start there :)
;              AUJP   7730 OUTPUTS
; Terminal         Chip         pin #      ECM    Function               $58     $60
; Description       &           chip       Conn                                  version
;                  pin#         pin #                                            Specific
;    PWM 3FD8      U2-3      10-U19-11      F1    Shift Light             A/C     N/A
;    PWM 3FDA      U2-2      14-U19-13      F2    EGR Port Sol            WG
;       Out 2     U2-49       6-U19-5       F3    Blank-Same as SES?     Blank
;     Port 24      U1-6       2-U19-3       F4    Air Divert              TCC
;    PWM 3FCC     U2-52      10-U20-11      F5    Blank                  Blank    N/A
;       Out 3     U10-17      6-U20-5       F6    TCC                    Blank
;    PWM 3FD4      U2-5      14-U18-13      F7    CCP Sol                Blank    N/A
;     Port 41     U1-17       2-U20-3       F8    Blank-Same as MUXA?    Blank
;                             9-U21-1       E3    IAC A Hi
;     Port 20     U1-10       9-U21-2       E4    IAC A Lo               Same
;                             9-U21-5       E5    IAC B Hi
;     Port 21      U1-9       9-U21-4       E6    IAC B Lo
;         SES     U2-48       2-U18-3       E7    SES                     SES
;    PWM 3FEA     U2-51     9-U13-U10-25    E8    FAN1                    CAC     N/A
;    PWM 3FD6      U1-4      10-U18-11      E9    EGR Sol                 EVRV    N/A
;       Out 1     U10-19      5-U16-2       A2    Relay 2-Same as TCC?    Blank
; All values from code itself.
;   7000 = OFF
;   D000 = O% DC
;   D134 = 30% DC
;   D200 = 50% DC
;   DFFF = 100% DC
; $0066 Increments DC by 10%
;F1    Shift Light
;F2    EGR Port Sol
;F3    Blank-Same as SES?
;F4    Air Divert
;F5    Blank
;F6    TCC
;F7    CCP Sol
;F8    Blank Same as MUXA?
;E7    SES
;E8    FAN1
;E9    EGR Sol
;A2    Relay 2 Same as TCC?
Old Jun 29, 2005 | 11:50 AM
JP86SS's Avatar
I've not posted the update yet, cause still trying to fill in some blanks. The list was provided by Z' and didn't want to put it out until I discussed it first. (but there it is.)
Have found a bunch of the bits that control if the PWMs are enabled at the output pin but have a "bit" more to do in understanding the whole thing.
Code:
            AUJP   7730 OUTPUTS
; Terminal         Chip         pin #      ECM    Function               $58         AUJP Address
;                  pin#         pin #
;    PWM 3FD8      U2-3      10-U19-11      F1    Shift Light             A/C	PWM 3FD8  0196, b2 enables
;    PWM 3FDA      U2-2      14-U19-13      F2    EGR Port Sol            WG	PWM 3FDA
;     Port 24      U1-6       2-U19-3       F4    Air Divert              TCC	003F, b2,  $60 = 0027, b7
;    PWM 3FCC     U2-52      10-U20-11      F5    Blank                  Blank	PWM 3FCC
;    PWM 3FD4      U2-5      14-U18-13      F7    CCP Sol                Blank	PWM 3FD4
;                             9-U21-1       E3    IAC A Hi			4002, b0
;     Port 20     U1-10       9-U21-2       E4    IAC A Lo               Same	4002, b0
;                             9-U21-5       E5    IAC B Hi			4002, b1
;     Port 21      U1-9       9-U21-4       E6    IAC B Lo		 Same	4002, b1
;         SES     U2-48       2-U18-3       E7    SES                     SES	3FFC, b3  0196, b4 enables
;    PWM 3FEA     U2-51     9-U13-U10-25    E8    FAN1                    CAC	PWM 3FEA, 0193, b2 enables
;    PWM 3FD6      U1-4      10-U18-11      E9    EGR Sol                 EVRV	PWM 3FD6
;						  A/C Clutch Sol		3FFC, b2
I've added control info at the end of the rows. (more to follow)
I am going to put up another thread concerning just the outputs and the sequence of events required to operate them.
So this was just a taste of being able to swap code without repinning, which WILL eventually happen
Jp
GouldyGTR
Aug 21, 2015 10:43 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
