Side Exhaust in GFX
Old Feb 27, 2003 | 05:44 AM
Z28Clone's Avatar
Side Exhaust in GFX
Has anyone tried this. I have a 91 Z and thought about having side exhaust come out in front of back tires through a "nicely" cut hole in my GFX. Any suggestions, pics?
Old Feb 27, 2003 | 05:48 AM
LarsZ28's Avatar
Yeah, I suggest you use 85-90 side GFX to "nicely" cut a hole in
Old Feb 27, 2003 | 06:57 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
it_will_not_work_w/o_extensive rocker_panel_mods
Old Feb 27, 2003 | 11:02 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Yes im on it. Im trying to make new gfx because the stock ones wouldnt survive that . Well i cant say its going well but someday they will be finished.
Old Feb 27, 2003 | 01:09 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
here was my idea for side exhaust... i think it's better there than the side graphics....
Old Feb 27, 2003 | 04:07 PM
Redliner's Avatar
Car: Tahoe
That graphics theme looks a bit to much like the theme on the Supra in "The Fast and The Furious"
I DON'T suggest you try and get away with it.
Old Feb 27, 2003 | 04:10 PM
redraif's Avatar
Transmission: Th700R4
Well by October I'm going to have to figure it out for the 82! As far as cutting up 91-92 Camaro gfx...I vote no. I have a set on my 87 and I considered then for the 82 till we discussed side exhaust. I got 85-90 bird gfx to cut up instead. If you mount them lower then factory it sould give to some more playing room. they are way longer then the Camaro gfx!
here is a pic of side exhaust from the TA nats in Dayton, OH!
Old Feb 27, 2003 | 04:12 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
here is another pic-
Old Feb 27, 2003 | 04:19 PM
Redliner's Avatar
Car: Tahoe
To tell the truth I really like the way side exhaust looks.
Living with it every day could be a pain. I drive everywhere with my windows down and unfortunatly My side of town has doubled in density for the past 5 yrs. More stop and go traffic, more exhaust getting in the car.
Old Feb 27, 2003 | 09:07 PM
fb305svs's Avatar
i dont even think its a matter of it getting in the car- its more the fact that you are sacrificing everybit of ground clearence. Lets face it- side pipes and duals on a 3rdgen will basically take away all ground clearence....
duals are ok, they can be tucked up pretty well.
Steve
Old Feb 28, 2003 | 12:40 PM
BOTTLEDZ28's Avatar
Transmission: A4
Side exhaust is fine on a car that is driven in a city or town thathas no bumps, even raods and no pot holes. Now tell me where this place is so I can move there please. New England roads are destroyed from this winter weather and my nice random tech cats are nothing pretty anymore
Old Feb 28, 2003 | 01:06 PM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
i think it looks good on a camaro but i don't know so much about putting them on a trans-am if i were to do somthing like that i'd put a different GFX kit on my car with a larger back bumper peice and cut like oval/square holes in the bumper and run them our like that maybe round i don't know but i think that would look kinda sweet.
Old Feb 28, 2003 | 07:04 PM
89firechicken's Avatar
if you use the oval pipes with the spin tech mufflers you shouldnt have as much of a problem with ground clearance
Old Mar 2, 2003 | 09:07 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I don't know if you could do that without killing your ground clearance. I'm planning on mounting my exhaust a little high, so that I can cut little grooves into the rear bumper, so that the exhaust will look more stock. Redraif, from the looks of your concept car, you're building a car similiar to mine, with the Knight Rider nose. How is that working out?
Old Mar 2, 2003 | 09:55 PM
i_alex's Avatar
Car: vistacruisa
Engine: 532
Transmission: mousburgg
Axle/Gears: 4x4
i need help
ok i got shorty headers and i cut off all my exhaust and i'm running a flow master 40 off the Y-pipe and on the pic up there on the camaro how the hell did they fit that other flow master on the driver side....... i have asked every muffler shop if i can run true dual dumps under it and they all tell my i'm crazy and it won't fit
i want to know if it's possible with out hammering the floor pan.
Old Mar 3, 2003 | 08:30 AM
transam305's Avatar
you might have to hammer because of clearence i think GM should have put that into the design. like once you bought the car and wanted to put true duals on it because they should have known that we would want it... they could have at least made it an option. IMO anyway.
Old Mar 3, 2003 | 09:43 AM
redraif's Avatar
Its slow going right now...parts procurement stage ($)...Still trying to get the rollcage, so we can turn it into a Targa. As soon as we get the cage and it arrives, things will start to pic up...Yeah its the KITT nose. I always thought it was a cool nose!
I'm not sure how we will work out the side exhaust, but we will probably have to run with oval pipes under the body...I plan to run a short retagular tip...Hopefully it will work!
Old Mar 4, 2003 | 01:00 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
I was going to do a Rousch-style side-pipe set-up on my GTA, incorporating the tip into the GFX in front of the wheel. But you can't do it because the trailing arms are in the way.
Old Mar 4, 2003 | 08:06 AM
transam305's Avatar
did you try right behind the wheel?
Old Apr 15, 2003 | 04:42 PM
txhotRS's Avatar
Z-28 side exhause
I DID IT... YES I DID IT.. Well, I'm doing it.. I'm experimenting with fitting the exhaust... I got a pair of STAINLESS rectangle Z-28 tips from a buddy and thought about how SWEET they would be INFRONT OF THE REAR WHEELS... I used the theory behind CORVETTE exhaust, and straight side pipes... where if the curve is mandrell and slight enough .. YOU CAN have an exhaust pipe going "backwards" (relatively towards the engine) the muffler and cat-back is in the STOCK location .. but the exit pipes (in my experiment) don't curve toward the rear.. instead they curve slight forward... over the rear axle and DOWN to infront of the REAR WHEELS.. Ground clearance would only change about 2" and only RIGHT infront of the rear wheels (so the wheel is a buffer and they wont bottom out) I PLAN to document the DYNO results from regular pipes.. and MY EXPERIMENT.. if IT's EQUAL or higher.. I'LL POST PICS and INSTRUCTIONS... ANY QUESTIONS OR IDEAS ... I'm open
Old Apr 15, 2003 | 06:57 PM
MILT's Avatar
That's probably the best idea so far. You could easily modify the floor pan a little to add some extra clearance as well.
As an aside, I was thinking about looking into the setup that is used on the '99 (???) Cobra R Mustangs. Anyone know anything about that setup?
MILT
Old Apr 16, 2003 | 08:23 AM
transam305's Avatar
i don't but i'm sure somebody does and if they do, do they have pics of it?
Old Apr 16, 2003 | 12:06 PM
LT1guy's Avatar
Car: 1987 Trans Am
There are mufflers available from Dynomax and Borla, possibly others, that have the inlet and outlet on the same end, specifically for the purpose of side exhaust. I think the Spintechs may be set up like this too. This is what is used in the Mustang side exhaust kits. A similar setup was used on AAR Cudas. They do hurt performance slightly though over a conventional catback.
My 87 TA is getting duals with either side exhaust or turndowns, depending on clearances. I'm not lowering the car (its being setup for street/strip) intentionally, but the V6 springs that work best for dragracing are going to lower it some. As Redraif mentioned, oval pipe will probably be the way to go. I'm going to try to go by a NASCAR used parts place next week (going to Charlotte on business), and may grab a couple "seasoned" exhaust pipes while I'm there.
Old Apr 16, 2003 | 12:09 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Better find room for a crossover/x/h pipe..........
I wouldnt/couldnt run them. I have other needs for sacrificed ride hieght
Old Apr 16, 2003 | 02:31 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
UGH. Being able to see the exhuast hanging down underneath the car looks cheap and tacky. That, and it looks rather ridiculous on a car with ground effects.
Old Apr 17, 2003 | 08:34 AM
transam305's Avatar
that's true exhaust hangage looks sort of hillbillish if you ask me. you almost want to give them a coat hanger or something to tie that stuff up there lol.
Old Apr 17, 2003 | 11:38 AM
redraif's Avatar
Well if mine works out the way I plan...some creativity should mask any low hanging typical side exhaust look. I hope I can do it so the exhaust comes thru the gfx. Not sure if I can pull it off though!
Old Apr 17, 2003 | 10:07 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
i dunno where u are in mass but over here in the valley all the roads suck
Reddeath210
Oct 6, 2015 08:20 AM
transaero
Aug 31, 2015 01:14 AM
db057
Aug 22, 2015 08:17 PM
LittleFranks
Aug 20, 2015 03:55 PM
timonator
Aug 11, 2015 09:56 PM
