side exit question
Old Jan 23, 2003 | 10:33 PM
scrawnywhiteguy's Avatar
side exit question
I have a quick question about dual exhaust. I wanna put duals on with it exiting right in front of the rear tires with the mufflers right under the front floor boards if you know what I mean. Does anyone here have this setup or have a pic of a setup like this so I can see how much ground clearance it'll have. Thanks.
Tim:rockon:
Old Jan 24, 2003 | 01:43 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: side exit question
Tim:rockon:
Ground clearance will be non existant. There is room on the passenger side, but not on the driver's side. There are a lot of people who put down dual exhaust on our cars, but honestly if you dont have to run cats its not hard to do. I am getting my dual exhaust welded up tomorrow. People just need to understand that you cant fit two full size mufflers (flowmasters, super turbos, etc) under our cars without a decent amount of pipe bends or fab work to the car. What you need to do (what i am doing) is to run a smaller muffler. Spintech, Dynomax bullet mufflers and car chemistry inserts will allow you to do a dual exhaust setup with decent ground clearance. I will try to get pics up tomorrow.
Old Jan 24, 2003 | 12:08 PM
Schwantz's Avatar
Spintech also sells oval tubing to help increase ground clearence. I doubt this would be sufficent ground clearence but its something you can look into.
Old Jan 24, 2003 | 06:00 PM
What about glasspacks?? I don't now how they sound on small blocks...all I ever heard 'em on is a olds 425, and a Chev 396. Would that be a better idea??? Also does anyone know where I can fing sound clips of a thirdgen with packs online. the one in the sound clips on this site distorts my speakers when I try to play it.
Tim:rockon:
Old Jan 24, 2003 | 09:52 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
theres a pic floating around (actually i havent seen it in months) or a blue Z that had side exhaust. ground clearence, lets just say he had none!
Old Jan 25, 2003 | 02:00 AM
Tim:rockon:
Bullet mufflers are similar to glasspacks but sound a whole lot better. They are 31 bucks from www.summitracing.com I got my dual exhaust hung today and it consists of 2 1/2" pipe, an X pipe behind the tranny and dual 2 1/2" bullet mufflers to turndowns at the axle. not a ton of ground clearance, but i can go over everything except steep driveways.
Old Jan 25, 2003 | 10:55 PM
No problems with speed bumps???
Tim:rockon:
Old Jan 26, 2003 | 03:18 AM
Tim:rockon:
Nope I have been careful over every speed bump i have gone over so far and havent bottomed the exhaust out yet
84z96L31vortec
Aug 20, 2017 12:16 AM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
