whats the ultimate setup to handle high horsepower (600+)??
Car: too many ...
What would be the best setup for someone with something like 700 or 800 hp from a turbocharged 5.7ltr?? I was thinking T56 w/ centerforce dual 2 clutch, carbon fiber driveshaft, and a ford 9 inch rear?? or is there a better rear end (w/ disc brake) for high top speeds? I know the T56 is only rated at 500 something hp, but if the boost was turned down, you could drive around normal under 300 hp and just make the boost higher if u gotta go fast and push the tranny a little bit for a small period of time. is it all going to go boom???? heheh
thnx for the help!!
--- Current Daily Driver ---
Maroon 1989 Camaro RS - Crappy 305 TBI / Auto
Hypertech Stage 2 Chip (and 160/ThermoStat)
2.5" Pipes, No Cat, Flowmasters (Dual)
GT Grant Wheel, %5 Tint all around, 50% on windshield
--- Next Project ---
1992 Camaro z28 - 5.7ltr / Auto
6 speed swap, engine internals, turbocharge, SCCA!!!!
thnx for the help!!
Car: 1983 Z28
Engine: 6.6L 406
I could be wrong but isn't a buit up version of the T-56 used in the Venom Viper and Lingenfelter Corvette? Those have like well over 600hp don't they?
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
future mods:
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
If your going with a t-56 trans. The first thing you wuold have too do is get rid of the t-56 clutch and bellhousing.Go with a lakewood or bob wier's bellhousing and then get a hydrolic throw out bearing. Forget centerforce and buy a ram or macloud clutch. Then get a 9" or a 12 bolt rear end. There are disc brake set ups for 9" rearends.Get a carbonfiber driveshaft.spohn torque arm and crossmember. Look at my website below.I don't have 600 HP yet but wait until I get a supercharger!
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
406
accel supper ram
afr heads
600 HP will need more than a drive train. Atleast good subframe connectors, LCA mount reinforcement (comes along with some SFCS). Not to mention replacing driveline mounts with polyurethane. The T-56 is probably up to the challenge of 600 HP, it's gotten a reputation as bullet proof but it does have it's limits.
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
1984 T-top Trans Am
13.98 @ 101
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
How do you figure that? I run a TH350 and I hope to have a 2 speed powerglide installed next year. TH400 is a big heavy tranny. It is the strongest automatic (also the 4L80E) but only for street use. When racing, it's not the tranny of choice.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Car: 84 Z28
Axle/Gears: 9-bolt, 3.27
I know I'll probably get some laughs, but look at all those 200-4R's running in the high horsepower modified Grand Nationals. I know the 700-R4 can also be built to handle some massive horsepower. It all depends on if you wanna shift gears or not, and also if overdrive is important to you. The T56 does sound appealing in your situation though!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads look good, (just sitting there doing nothing!LOL))
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Working on:
145 MPH IROC Speedo
Well, of course for track purposes the Glide is the best, but he'd get gallons per mile instead of MPG. The 200R4 is a good tranny but expensive and you should find a mechanic who knows GN's or else you could have some problems.
Linson
Sep 21, 2015 01:08 PM
