Idiots guide to timing
Old Apr 19, 2005 | 01:09 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
can somebody direct me to or basically tell me exactly how to time in a non CC carburated 350. I know on some motors you have to unplug stuff and such to set base timing. and what about keeping it at 3000 rpm and such?how exactly do you tell how many degrees of timing you are running. Base is 36 right?
Old Apr 19, 2005 | 02:49 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
first, get a timing light.
second, I don't know how much easier it could be... pull the EST(?) wire, the tan one, and turn the distributor until your car doesn't like it anymore.
Old Apr 19, 2005 | 03:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
He said non-CCC, so there's no EST wire.
To measure the initial timing, disconnect and plug the vacuum advance hose and connect your timing light. Let the engine warm up and idle normally and aim the light at the timing comb on the balancer. The timing light flashes when the #1 cylinder fires, and you look at where the balancer mark is "frozen" when it flashes. You can see up to 12 degrees of advance or so on the stock timing comb.
If you haven't modified the timing curve, there's not much more you'd be interested in than the initial timing.
Old Apr 19, 2005 | 06:02 PM
kevinc's Avatar
Car: 1982 Z28
You gotta love watching one idiot try to talk down to another idiot...
Old Apr 19, 2005 | 09:03 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Hostility, man. Watch it.
Old Apr 19, 2005 | 09:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Crane kit. 'nuff said.
Crane adjustable vacuum advance kit, use it with instructions on the main page of TGO (How to tune for performance on non CC HEI ignition...)
And get an MSD timing tape, $4 or so.
If you need a little help on timing, here is a picture I've stolen from another website, an invaluable picture:
Old Apr 19, 2005 | 09:15 PM
Car: 83 Camaro
Transmission: th350
alright so jsut keep it at idle and plug the vaccum advance going to the dist? now what about the other timing figures, do those come when you modify the curves from the distributer weights adn springs? how do they work exactly
Old Apr 19, 2005 | 09:31 PM
Apeiron's Avatar
Engine: 383 Carb
Unless you've modified the distributor with something like the Crane kit that Sonix mentioned, there's nothing you can do about the other values, so you might as well ignore them.
The actual advance you have at any time is called total advance, or total timing. It's a combination of the initial timing, plus the advance you get from the centrifugal advance mechanism, plus the advance from the vacuum advance mechanism.
The centrifugal advance mechanism uses a pair of weights the fly out against the tension of a couple of springs, which advances the timing as engine speed increases. By varying the weight and shape of the weights, and the tension of the springs, you can change how much centrifugal advance there is, and how soon it comes in. Usually there should be able 34 degrees or so of centrifugal advance plus initial advance by around 2800 RPM or so. That's why some people set their timing with the engine spinning at 3000 RPM.
Vacuum advance increases when the load on the engine is low at part throttle (since manifold vacuum is somewhat related to engine load) and disappears completely at WOT. The amount and rate of vacuum advance needed varies depending on the car, and so it's usually set experimentally.
Old Apr 19, 2005 | 09:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Aperion: Out of curiosity, when setting total timing, should I put on my springs of desired strength, then get a buddy to hold it at 3k rpm say, and set timing to 34-ish say.. Is that with vacuum disconnected ?
Right now I'm using manifold vacuum and it's working awesome, finally figured out I need to turn out my mixture screws 2 turns just wasn't cutting it...
Beenyboop or whatever, check out :
https://www.thirdgen.org/newdesign/tech/hei.shtml
That'll get you started. The "recurving" deal is all explained in there, and remember: the crane kit (or whatever brand you prefer, crane is preferred by some here for a reason tho...)
is about $30, pretty cheap considering it's benefits... -J
Old Apr 19, 2005 | 10:51 PM
Apeiron's Avatar
Engine: 383 Carb
That's pretty much it. Take it for a few WOT passes and listen for detonation afterwards, you might need to adjust it a few degrees in either direction.
Old Apr 19, 2005 | 11:01 PM
Sonix's Avatar
Car: 1982 Trans-Am
yea, that's about what I thought..
I just figured with about 15* centrifigual (sp?), i'd end up with loads of initial timing... I was thinking about grinding out my stops in the HEI to allow more centrifigual advance...
And I hopefully will not have too much timing after vacuum kicks in... I can just figure out how to lock out more if that's the case.
Old Apr 19, 2005 | 11:10 PM
Apeiron's Avatar
Engine: 383 Carb
On a stock HEI you should have about 20 degrees of centrifugal advance available.
Old Apr 20, 2005 | 01:08 AM
Sonix's Avatar
Car: 1982 Trans-Am
should yes.
but I put about 10* initial, then revved it and made 25* and no more. With no vacuum...
err, wait, my crane setup (heavy and medium spring), started at 800RPM... I think I was at 900 or so.... maybe i'll put in two heavy and reset the base...
Anyway, bennyboopy, is this helping you
as a side note, with stock HEI, do we have much choice with weights? Or is it just spring adjustments?
Old Apr 20, 2005 | 05:04 AM
kevinc's Avatar
Car: 1982 Z28
Honesty, man. "And ye shall know the truth...and the truth shall set ye free..."
Old Apr 20, 2005 | 06:07 AM
Car: 83 Camaro
Transmission: th350
yes very much so...i actually knew most of the basics before but there was jsut a few little things i needed some clearification on...which was accomplished already
Old Apr 20, 2005 | 02:52 PM
Apeiron's Avatar
Engine: 383 Carb
Replacement weight sets are available, but not really anything that would give you a whole lot of selection. Changing springs is easier anyway.
Cameeeero
Sep 18, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
BrianI
Aug 9, 2015 11:52 AM
