TQ arm bushing..look at the difference
Old Apr 7, 2004 | 08:23 PM
Wishmaster's87IROC's Avatar
Engine: 385 HSR.....LS1
Check out the difference in the stocker vs the ES bushing. I cant belive it. Im putting speedo gears in my tranny tailshaft and now is a great time to replace the TQ arm bushing. You can get to the bolts real easy and also grind the tabs off and drill the holes so the old stokcer comes off with no problem. Real easy!
Old Apr 7, 2004 | 08:24 PM
bushings
Old Apr 7, 2004 | 08:26 PM
other
Old Apr 7, 2004 | 10:58 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
man you got red
all i got was boring black.
Old Apr 7, 2004 | 11:31 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Originally posted by xpndbl3
man you got red
there should have been two options when you ordered under the part number with an r at the end for red and i think b for black. at least that is how it was when i ordered that pos hyperflex kit.
Old Apr 8, 2004 | 12:36 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
hmmmm might have to get me one of those!!
Old Apr 8, 2004 | 06:14 AM
ebmiller88's Avatar
I have them on both my cars and they make a world of difference and in my case, stopped a "clunk" I would hear when I put the car in gear. The clunk sound was from the torque arm hitting metal in the mount. Do it now, don't wait. The only better upgrade here would be going to a tubular T/A from Spohn or the like.
Ed
Old Apr 8, 2004 | 06:38 AM
nolanr0413's Avatar
Car: Trans am
where can i get one of those from?
Old Apr 8, 2004 | 08:02 AM
ebmiller88's Avatar
Summit, Jeg's, whoever carries ES products. They're about $12-14 each.
Ed
Old Apr 8, 2004 | 08:38 AM
yep! 11.99 at Summit
Old Apr 8, 2004 | 08:42 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i would assume so, but i'll ask anyway..
does the 3rdgen one fit in the 4thgen T56 holder?
or do i need to order a bushing for a LT1 car?
Old Apr 8, 2004 | 08:47 AM
CaysE's Avatar
Boring black? Don't you mean Sleeper black?
Old Apr 8, 2004 | 08:51 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol, yea.. i dont like showing off my bushings either. :lala:
Old Apr 8, 2004 | 12:16 PM
xpndbl3's Avatar
Car: 1984 Z28
that was my point
Old Apr 9, 2004 | 02:03 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
Yup.
Just make sure to have a look underneath the car before you order your bushing, there are two types. You need to check which way the "lips" of your torque arm are facing. They will either be towards the driveshaft or towards the driver's side of your car. Just order your corresponsing part and go at it.
Good luck, Efrain.
Old Apr 9, 2004 | 02:52 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Ed
Also you can check some of the local chains. Some AutoZones around here carry ES bushings.
Old Apr 9, 2004 | 03:39 PM
Yeah but they dont carry the TQ arm bushing, I checked! They dont even carry the 33mm sway bar bushing, I checked on that too. They do carry ES bushing but not all of them or what your looking for...
Old Apr 11, 2004 | 12:43 AM
Ovrclck350's Avatar
Ha, getting the thicker one back on is the fun part. I used every word in the book I think.
Old Apr 11, 2004 | 11:51 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
Old Apr 12, 2004 | 12:53 AM
Pat Hall's Avatar
I got the same red TA bushing on mine along with the ES poly trans mount. Both pieces are worth their weight in gold! One of the cheaper and in my opinion absolutely necessary modifications you can do to your ride. Just the other day, a buddy of mine with a 90 Iroc was debating whether to spend $20 for the ES tranny mount, or buy the stock rubber piece of trash for $7. I told him he will have paid for the ES mount by the time he buys three of the stock POS mounts and spends the time to replace them every time they break. I also told him I managed to break the stock mount with a measly 305 TBI instead of a 5.7 TPI.
Old Apr 13, 2004 | 05:02 PM
383 rocket bird's Avatar
I did both mounts when i rebuilt my tranny and it was money well spent. -John
morrow
Jan 13, 2024 12:29 PM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
greenyone
Sep 2, 2015 03:39 PM
