CC Carb TPS
Old Jan 15, 2005 | 05:18 PM
ThommyDee's86Z's Avatar
Car: 86 Z28 w/ T Tops
Engine: 305 SB w/ Performer intake 3701
Transmission: 700 R4
Axle/Gears: stock
CC Carb TPS
I have the air horn off and 2 plungers fell out when I removed it.
Both look identical. about 1/2 inch long. I believe 1 goes on top of the TPS sensor plunger and sticks up thru the air horn.
Not sure where the second one goes...maybe behind the TPS adjusting screw?
BTW any tips for reinstalling the airhorn and getting everything to stay in place? (ie. plungers, tps, pump assembly etc.)
Old Jan 15, 2005 | 07:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
See if this helps.
http://www.carburetion.com/Quads/E4MC.htm
Old Jan 15, 2005 | 07:02 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Can you post a picture?
Old Jan 15, 2005 | 07:51 PM
Axle/Gears: stock
The plunger is circled with the smaller circle...this is right where it landed when the airhorn was pulled off.
There is a second one.
One of these sits on top of the TPS plunger...where does the 2nd one go? behind the TPS adj screw?
I did check out that site and actually already have that diagram but it does not list a 2nd plunger.
Old Jan 15, 2005 | 07:53 PM
Lo-tec's Avatar
Do you have pix of 2nd plunger? One in carb is for TPS.
Old Jan 15, 2005 | 07:57 PM
Lo-tec's Avatar
Does 2nd plunger have rubber seal at bottom?
Axle/Gears: stock
2nd one looks identical to the one lying there helplessly.
Fell in same area but I grabbed it so it would not fall in somewhere.
Old Jan 15, 2005 | 07:59 PM
Lo-tec's Avatar
I think someone change TPS and you have an extra!
Old Jan 15, 2005 | 08:04 PM
Axle/Gears: stock
Here it is next to the adjustment tool.
the reason I am checking is because I am trying to adjust the voltage to .48 volts on the TPS but it does not seem to make a difference when I turn the screw.
Old Jan 15, 2005 | 08:21 PM
Lo-tec's Avatar
Did the TPS vary with throttle input?
Does it vary now if you push in plunger with carb apart?
Old Jan 17, 2005 | 05:52 AM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
I'd suggest just to replace that TPS if you couldn't get a voltage variation out of it. I've had to change mine 3 times in the last 4 years, they seem to die a lot. Judging by the yellowed plastic plug socket, it's probably quite old (white when new). Also, i've seen a bunch of reman'd cc QJets come out of the box with an old or non-functioning TPS. Wells p/n TPS-100, about $25. There should be only one plunger for it, I think Lo-tech got it right with his response. I use a little bit of lithium grease to make the TPS plunger stay put in the airhorn when re-assembling. Also make sure that the little "hook" in the airhorn for the TPS setting stays up, and contacts that little **** on the edge of the TPS body when you're setting the airhorn back on.
Old Jan 17, 2005 | 07:32 AM
Axle/Gears: stock
Thanks 84TA, sounds like you know exactly what I am talking about.
looks like a new tps will be on order.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
