TV cable adj loss of power!??!?!
Old Apr 18, 2004 | 10:17 PM
A88GTANotchback's Avatar
hey guys i nees help. i adjusted the TV cable and was happy. it shifts alot harder and crisper. but i think i lost power cause i raced this sunfire( i race him all the time and ALWAYS win) and lost. so how can i bee that the car feels alot more powerful and hits nicer shifts loses to a car it always beats. he just edged me out but still whats up.....an sunfire shouldnt be any where near me! i need help and lots of it.
Old Apr 18, 2004 | 10:43 PM
90_WS6_Formula's Avatar
Car: 91 Z28
are you sure he didn't do something to his car?
Old Apr 18, 2004 | 10:51 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
is it shifting at a differnt rpm? its possible your now shifting out of its powerband (too late or too early).. what did it shift at before and now? what type of induction are you running?
Old Apr 18, 2004 | 10:57 PM
he has exhaust and K&N...no bs hes my best friend. but it shifts higher now i didnt really pay attention i just did it today. i like it alot more because before i got loose shifts. they were soft and didnt seem to hit well. its like a shift kit was installed. alot nice. so whats the other options. the cars a L98 700R4(obviously). it has higher mileage. 170000 km..not sure what that is in MIles
Old Apr 18, 2004 | 11:09 PM
89RsPower!'s Avatar
how much higher? remember TPI is pretty much done at around 4500 rpms or so
Old Apr 18, 2004 | 11:14 PM
hmmmm......i think it shifts right around there...is that my prob? should i back the TV cable off a wee bit to get the shifts a bit lower then
Old Apr 18, 2004 | 11:32 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Sunfire shouldn't be anywhere close to a decent running l98...even if it is shifting alittle late.
Old Apr 18, 2004 | 11:34 PM
i know that and he never was until tonihgt......its odd. i cant handle the embarrassment
Old Apr 18, 2004 | 11:35 PM
when i adjusted it it never clicked. whatd i do wrong. i found something saying it should click.....maybe this is why shes outta whack
Old Apr 19, 2004 | 08:54 AM
Car: 91 Z28
Could you please, in the best way you can, describe to us how you adjusted the cable?
Old Apr 19, 2004 | 10:23 AM
aight. i pushed in the metal d shaped thing and brought the slack of the cable tight to the mounting tab. i let go of the metal d and then pushed the throttle to WOT, and released it. it shifts good and i was happy but something must not be right if all the sudden sunfures are beaten me.
Old Apr 19, 2004 | 10:33 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Are you sure he didn't do anything to his car? If you always smoke him, then he comes back and smokes you, thats a huge difference. You should have been able to tell something was wrong just by flooring it. You'd have to lose alot of hp to lose to him.
If you go WOT and it pulls like it did before, I think your ok. The way you did your cable seems to be right, but I believe it should click
http://iroczone.com/techarttvadj.html
Old Apr 19, 2004 | 10:39 AM
the sunfires unmodded(well lightly modded, but nothing new since we last raced, hes a buddy of mine) soim dumbfounded and embarrassed beyond belief. i did a good tune up last year but am gona touch up on some things i think. thx for the fast replys guys.
Old Apr 19, 2004 | 10:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Of course it may just be that the adjustment moved your shift points up beyond your engine's optimum RPM range....ideal shift points for that engine should be at around 4600 out of 1st and around 4300-4400 out of 2nd & 3rd.... if it stays in low gear to a higher RPM than that, then it's reaching a point where the engine isn't producing as much power, so the RPMs cease to climb and instead just kind of hang there for a while without the car accelerating, so the car will go slower.
You might want to try gently pushing in the cable housing, the reverse of what you did to adjust it, until it clicks; that should lower the shift points slightly. See if that helps it go faster. Then try pushing it in one more click. In other words, carefully adjust it one click at a time, for best results.
But in no case should a Sunfire be able to beat your car, or even come anywhere close, unless it's had ALOT of work done to it. Even if your car was a 305 TBI. With your L98, you should be at least a second and a half faster than that car, maybe more like 2 seconds. Something doesn't pass the smell test.
170,000 km is about 110,000 miles. Not really a whole lot.
Old Apr 19, 2004 | 11:12 AM
Car: 91 Z28
I'm not trying to be a wise guy, but did you push the black plastic holder that the cable comes out of ALL the way back?
a trusted tranny builder in my area told me to adjust the TV cable according to spec and when I race to push it IN one notch. This is will increase line presure slightly and allow the tranny to hold a gear longer.
Old Apr 19, 2004 | 11:30 AM
Transmission: 4l60e
The way my trans-go kit video said do adjust the cable is like this.
Have someone hold your gas pedal to the floor
Push the D thing
Then slide the sleeve as far back as you can
and thats it. They called it MAX TV or something on the video.
Old Apr 19, 2004 | 12:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's the correct factory procedure for adjusting it.
But, like so many other things, you can "tune" it a little bit. Not much, but a little. Too much variation from factory spec will run the risk of burning up the trans. But, over a narrow range, you can vary the adjustment somewhat, to get the best results for your specific vehicle and driving needs and all that.
Old Apr 19, 2004 | 03:25 PM
Push the D thing
i did it this way and it shifts smooth again and not jerky and over revving. it has a nicer power band it seems so ill see. ill line up again against my friend as a reference. but oh welll i guess. now to find out weather or not i got a vaccuum leak. i guess this shows ya u can think the cars running good ...until a sunfire beats ya at least/
Old Apr 19, 2004 | 10:22 PM
Transmission: 4l60e
I had to "tune" mine a little. Basically I used one of those clamp down fishing sinkers to make the cable a hair longer. Because until I did that it shifted way to early (4000rpm). Now it shifts at 4500....not much better but oh well.
If I race it I manually shift it anyways. Supposedly the tranny I have has a trans-go shift kit but to be honest I have no idea.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
formula_novice
Sep 5, 2015 03:58 AM
sailtexas186548
Aug 24, 2015 10:11 PM
