Anyone try different brands / types of oil to reduce "smokey start-up"?
Old Jun 2, 2002 | 07:23 PM
pauls's Avatar
I have a 85 IROC, 305 TPI, 50,000 actual miles, summer driven only. I change oil every 3000 miles with virtually no consumption between changes. However, mine has the classic 3rd gen era small block "smokey start-up", due to bad valve seals. I recently switched from regular Valvoline oil to Valvoline Max Life, both 10-W-30, in hope of MINIMIZING this condition. I've seen no improvement, but I felt it was worth a shot. Has anyome else out there with this condition tried anything that seemed to help? I know replacing the seals is the ultimate answer, but its possible that with todays improved lubricants ( synthetics, high mileage oils, etc) that there is something out there that could at least IMPROVE, if not cure, this problem. I realize its not damaging anything mechanically, but my ego does not dig it too much . Anyone? Thanks in advance.
Old Jun 2, 2002 | 07:29 PM
89WS-6's Avatar
when your friends are around start up your car and say, LOK OVER THERE, then after it starts, they can look back.
Old Jun 2, 2002 | 07:36 PM
RJR99SS's Avatar
yeah, with the seal being bad i dont think any kind of oil is going to help you much.
If it was the rings that were bad you could try heavier oils to reduce the oil consumption....
Old Jun 2, 2002 | 08:47 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Since its summer you could get away with plain 30W oil. It will reduce the amount of smoke but nothing except valve guide seals will cure the problem. "pray its just the seals"
GO KINGS!!
Old Jun 2, 2002 | 09:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If the seals are old, dried out, cracked or completely missing then no grade or type of oil will help. It's a mechanical problem that can't be fixed with a band-aid. Pull the valve covers and change the valve seals.
Old Jun 2, 2002 | 11:07 PM
Jza's Avatar
Jza
Synthetic supposedly burns clearer. I did smoke less when I made the switch years ago. Also a bottle of Lucas helps out. But like ^^^ said, you'll have to do the work eventually if you want it gone.
Old Jun 3, 2002 | 06:15 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
check out this thread....https://www.thirdgen.org/techbb2/sho...hreadid=110714
Old Jun 3, 2002 | 11:57 AM
George Khawahie's Avatar
Car: 1988 Camaro IROC-Z 'Vert
LOL... I remember this one time I couldn't find my IROC in a huge parking lot at the mall. Being that I have remote start in alarm, I raise my and up high and press the button to start the car. I could hear it start in the distance, but it wasn't loud enough to guide me.
What actually guided me? The smokey start-up!
Old Jun 4, 2002 | 06:17 PM
1991 RS 305's Avatar
......" Synthetic supposedly burns clearer. I did smoke less when I made the switch years ago. Also a bottle of Lucas helps out. But like ^^^ said, you'll have to do the work eventually if you want it gone"......
Alright, what the heck is Lucas? Is this like STP, or some other treatment?
Derick15
Sep 17, 2016 05:28 PM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
