A fix for that window rattle
Old Aug 27, 2005 | 11:26 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
You know how that window rattles when you shut the door, big problem with our cars. Figured out a fix for it, darn near free. There is a stop on the regulator that bottoms out on the bottom of the door. Rubber gets hard and falls apart, window goes down too far and gets loose all over. See in the picture where it's located with the window about half way up. Take a Dremel and cut off the rivet, ream out the hole a bit for the stud on the pad. See next post.
Old Aug 27, 2005 | 11:31 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
The pad I used is just a brake pad off a bicycle, get at WalMart for a buck or so. I use those brake cables for everything and the kit is really cheap so I had a bunch of those pads. Bolt the pad so the rubber is angled right and the new rubber stop will limit the window travel so the top of the glass is right at the weatherstripping and the bottom is held tight on the door frame. Pretty simple once you get the door panel off.
Old Aug 27, 2005 | 12:36 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
does that really work , i may have to try that , i use sound deadener on one door and its a little better but when you close it , it doesnt sound soild like a new car. It pisses me off.
Old Aug 27, 2005 | 12:56 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
I'm going to have to give this a try... anything to make the door sound more solid when it closes. Nice fix!
Old Aug 27, 2005 | 02:20 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
This is in the FAQ section:
https://www.thirdgen.org/techbb2/sho...hreadid=124084
JamesC
Old Oct 9, 2007 | 09:53 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: A fix for that window rattle
Sorry to bring up such an old post, but I just did this today and it works great, perfect hight, and only cost $3.99 for a pair at Wall Mart.
Old Jun 27, 2009 | 04:44 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
thanks awesome info here
Old Jun 30, 2009 | 01:25 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Im trying not to be confounded by a $3 solution. Does this help with the horizontal play in the window ?
Old Jun 30, 2009 | 07:57 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Not sure what you're actually referring to, but if your felts are good and the window is down and seated on the rubber stops, it doesn't rattle or shake when you shut the door. Pretty common problem with our cars.
Old Sep 2, 2013 | 09:10 PM
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
Bicycle brake pads worked great!
Old Sep 5, 2013 | 05:28 AM
KR81's Avatar
Can someone post a photo of the brake pad in place ?
Old Oct 18, 2013 | 09:41 AM
fyrebird68's Avatar
Bump to the top. I'd like to see a picture, too.
Old Oct 18, 2013 | 03:23 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Whoa, this thread is still alive. Can't really see the pad in place without cutting a hole through the outer door skin. See second post at red arrow for the location with new pad in place. When you get in there it's pretty obvious what the deal is. Mine is still working fine. Can't believe I still even have this car. Still looking good and running strong though.
Old Dec 16, 2017 | 08:29 PM
88guy's Avatar
When you install the brake pad do you install it vertical or horazontal
Old Dec 17, 2017 | 12:53 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
This old post is still around? The rubber part of the pad goes down with the stud sticking up though the window mechanism. Rotate the pad so the rubber makes good contact with the bottom of the door frame. Really have to get the door panel off and see how it's in there to understand the deal.
Old Dec 17, 2017 | 01:00 PM
88guy's Avatar
thanks i took a look last night after i asked the question and answered my own question thanks
Old Dec 17, 2017 | 07:53 PM
NoEmissions84TA's Avatar
Bicycle brake pads are a great solution.
I used Energy Suspension universal bump stops, similar to this:
And IIRC, I had to do some trimming to make them fit correctly.
Old May 14, 2019 | 10:37 PM
Brian Laycox's Avatar
Genius! I know it's an old post but I think you just solved my problem. The post is from 2005. Its 2019 now. Do you still have the car? How did your repair hold up over time? I've got my door panel off until I can fix it. Temporarily I stuck a self adhesive rubber foot to floor of the inner door, the kind that goes under small furniture. In the mean time I'm gonna go shopping and get me a bicycle brake pad! My temp fix will probably work itself loose with vibration in a couple days.
Old May 15, 2019 | 08:19 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Yep, still have the car. Just rolled over 200K miles and the window rattle is still fixed. Car is starting to draw too much attention to be a daily driver/commuter car though. Not a bad thing. Runs good and still gets 23 mpg - when I drive it right.
Old May 21, 2019 | 08:56 AM
krisb410's Avatar
I did this in 2007, still have the car, and the window hasn't rattled since
Old Jun 22, 2019 | 12:43 PM
88 TA's Avatar
Car: 88 T.A.
Thanks you so much for the info on the fix. Works awesome. No need to turn up radio anymore. Lol. It’s been driving me crazy for years.
Fronzizzle
Sep 8, 2015 12:10 PM
GouldyGTR
Sep 7, 2015 09:05 PM
scottmoyer
Sep 7, 2015 07:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
