wonder bar ?
Old Oct 23, 2005 | 06:28 PM
w1964bgta's Avatar
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
wonder bar ?
will a g.m IROC wonder bar fit my 89 t/a? picture I have looks like one end goes to the frame on the passenger side and the other looks as if would go onto the top of the steering box is this true? and do I have to buy any lengthened bolts to accomplish the task or is there a kit?
Old Oct 23, 2005 | 06:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There are many after market "Wonderbars." All are a direct bolt-in. Here's the Global West version.
JamesC
Old Oct 23, 2005 | 09:22 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i have a stocker from an IROC on my formula and it bolted right in with the stock bolts. it also made a diff in my steering feel. nice and tight.
Old Oct 24, 2005 | 04:16 PM
w1964bgta's Avatar
thanks for responding gents but do they attach to the steering box? And where do I get the global west version
Old Oct 24, 2005 | 04:39 PM
JamesC's Avatar
The Global West p/n is TS-14. Check the following web site:
http://www.globalwestsuspension.com/
As you may be able to see in the above pic, the steering box brace slides under the front sway bar tying the front end together.
JamesC
Old Oct 24, 2005 | 09:15 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Transmission: 700-R4
on a related note, the installation of the wonderbar looks and appears to be relatively simple...is it something a relatively ameture person could do?...I've installed LCA and a panhard rod, but nothing much more complicated than that?...is it just a basic bolt on?
Old Oct 24, 2005 | 09:31 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
if you have done LCAs and a PHB you can EASILY do this. just loosen the sway bushings and tehn drop the sway, pop it under , and then start putting things back together.
Old Oct 26, 2005 | 05:26 PM
w1964bgta's Avatar
wonder bar
You guys are too much, thanks a lot If I ever need anything I know where to go. Just bought one from TDS for $64.94 to my door can't wait till summer. Are those grease fittings on the bottom clamp of the sway bar in the picture above?
Old Oct 26, 2005 | 08:12 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: wonder bar
i was kinda curious about that myself. 1964 you outta see top pics of James car. VERY clean.
Old Oct 27, 2005 | 12:27 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: wonder bar
...Are those grease fittings on the bottom clamp of the sway bar in the picture above?
Yes. It is more than just a grease fitting though. There is also a groove cut into the ID of the bushing for grease to flow around the sway bar. The greasable front sway bar bushing kit is available from my web site under the Chassis & Suspension category.
Lon Salgren
Top-Down Solutions
Old Oct 27, 2005 | 02:12 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
of all the wonderbars i have seen in person or in photos, the TDS is the only one to have the bracket wrap around the end of the rod. also one of the few to have three mount points, as aposed to two on the stock unit and other aftermarket ones i have seen. looks trick too. i advise going with the red one. i got the black one. regret it every time i am under the car.
Old Oct 29, 2005 | 12:29 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
The red one is nice, and the extra mounting holes are a plus. Took like ten minutes to install...
Old Oct 30, 2005 | 01:05 PM
88IROCARMY's Avatar
I got a Spohn one , might be an early version. It would not fit my 88IROC, hit the dual fans. Was on a 86 Firebird (single fan), no issues.
Old Oct 30, 2005 | 03:29 PM
JamesC's Avatar
No problems with the Global West version and dual fans.
JamesC
Old Oct 31, 2005 | 01:02 AM
83 Crossfire TA's Avatar
same here with my GW...
Old Oct 31, 2005 | 09:52 AM
V6#22's Avatar
GW here also
I did have problems with a GW unit hitting the lower radiator hose on the stock V6 radiator. It was a very tight fit and caused a tight bend in the hose. Every application is different.
Now same car, GW unit still on there, Becool Aluminum radiator and everything has plenty of room due to the better routings of the BeCool
Old Nov 2, 2005 | 12:48 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Nothing looks dumber than one aftermarket bright red bar when the rest of the suspension is stock and rusted. Either do it all red or don't do it at all.
Old Nov 2, 2005 | 01:50 AM
V6#23's Avatar
Jezzz... Chrome it, polish it, or paint it black. Colors under a car look like crap unless its a $300,000 showcar with the entire undercarraige painted to match the body.
Anybody that knows what to look for will see anything you have even if it is painted black. Those that don't won't be looking under your car anyways.
ps- I happen to be the head judge of one the most prestigious carshows and exibit in So Calif. Trust me. I know what people laugh at.
Old Nov 3, 2005 | 11:05 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
The stock one or the aftermarket ones is better than no wonder bar! Between the two it wouldn't matter. Wonder bars rule!!! Prevents the crack!!!
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
