How to tell a T5
Old Jan 2, 2004 | 07:49 AM
Farfire70's Avatar
How to tell a T5
I'm going up to a boneyard today and plan on looking around for a T5, but won't purchase it today, probably next week if i find a good one. But i want to know how i will know one from another transmission. Also, what years were those available in?
Old Jan 2, 2004 | 10:00 AM
ede's Avatar
ede
i'm guessing you have a f body. you'd want one from a f body and really should try to be same year. the parts yard can look it up in an interchange book and tell you exactily what years will fit your application.
Old Jan 2, 2004 | 10:20 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Trans
Here is a picture of the w/c T-5 front:
Old Jan 2, 2004 | 04:18 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Get the newest one you can find. Some of the older ones aren't WC and are significantly weaker. Also, get one from a V8, because the V6 one won't bolt in due to a different input shaft.
If it's in an F-body and it has an aluminum case, it's a T5.
Old Jan 2, 2004 | 06:35 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
hate to break in but what's the first year of the wc t5?
Old Jan 2, 2004 | 07:54 PM
JOHN MERCER's Avatar
88 for camaro and 85 for ford.
Old Jan 2, 2004 | 09:37 PM
Farfire70's Avatar
excuse my lack of knowledge but what does wc stand for?
Old Jan 2, 2004 | 10:57 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
World class.
Old Jan 3, 2004 | 11:09 AM
The world class T5s are the ones to use. They switched from individual roller bearings to caged roller bearings, and tappered roller bearings, which are much stronger.
Old Jan 3, 2004 | 06:33 PM
Farfire70's Avatar
thanks for the understand.
