TOTW: The proof is in the puddin'. Post your 1/4 mile info and mods.
Old Jun 2, 2002 | 10:26 PM
Tas's Avatar
Tas
Welcome to the next installment of the
Topic of the Week
to run from 6/3/2002 to 6/10/2002
No bench racing. Post what has worked what you did to get there. If you don't have TBI 1/4 mile times and E.T., maybe you have some dyno information to share.
Old Jun 3, 2002 | 07:01 AM
91Firecrow305TBI's Avatar
Spun a bit
60': 2.418
330': 6.441
1/8m: 9.728
MPH: 75.01
1000': 12.561
1/4m: 14.970
MPH: 94.09
My best 60' is a 2.25 but the car was backfiring after 4.5k (weak valve springs) I have since added poly trans/motor mounts, a new poly torque arm bushing, fixed my exhaust problems, and added new valve springs.
I am hoping for a 2.1 60ft with my stock convertor. When I get it, hopefully I can be in the mid 14's.
Old Jun 3, 2002 | 08:20 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
60': 2.102
330': 6.241
1/8m: 9.688
MPH: 71.33
1000': 12.689
1/4m: 15.219
MPH: 89.12
http://home.columbus.rr.com/billsgar...%200205010.gif
L03 w/ T5 and street tires.
Mods: 3.42 gears, Hooker shorty headers, Hooker Super Comp Cat-back, 3" Cat, K&N filter, 180 thermostat.
I was shifting at 4500 rpm, after dynoing the next day I should have been shifting a 5500 rpm. 165rwhp/260rwtq
Old Jun 3, 2002 | 08:54 AM
Sounds like you really know how to drive the car.
Old Jun 3, 2002 | 11:35 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
See sig. I think the car has more in it, but Im very happy for my time with what little mods I did.
Old Jun 3, 2002 | 12:57 PM
dreamsbird's Avatar
r/t .873
60' 2.107
330 6.297
1/8 9.795
mph 71.14
1000 12.846
1/4 15.386
mph 88.56
removed subwoofer box and ran a tcc lockup switch
Old Jun 3, 2002 | 08:19 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
14.88@93.66
2.34 60 foot
lots of mods the combo has alot more in it just didnt have money to do it right (tuning etc)
havent really touched it in a year and wont till summer of 2003
Old Jun 4, 2002 | 01:11 AM
HrdRockA4305's Avatar
Last year: 16.8@81 MPH
Mods at the time: flowmaster 80 and open element
Milage at the time: 121,000
This year: Best '60 2.36
Best 1/8 10.44
1/4 16.24
Best Trap Speed 85.63
Mods I didn't have last year: New plugs/wires/cap/rotor, different open el, hedman shorties+y-pipe, cat replaced by a pipe
Is a 2.36 a pretty good '60 for an auto car with a 2.73 rear and BFG Radial T/As at stock pressure? (235/55/15)
Blown 305 TBI's Avatar
Times in the sig.
Currently doing the LT1 cam, and soon to have a rebuild (beefed up) trans with a 2800 stall.
Then next year the 355 I'm building now goes in!
Old Jun 4, 2002 | 06:16 AM
Did that paxton include larger injectors? Or are you using stock injectors? How well tuned in is your setup?
Old Jun 4, 2002 | 12:50 PM
Stock injectors, but the kit did come with a higher volume fuel pump (unknown gph), and an FMU. So as the boost goes up so does the fuel pressure, at 7lbs of boost I see about 17-18psi of fuel. And I've also done the ultimate TBI mods except the AFPR part, since I have the FMU.
I own a Holley 670TBI, but it doesn't work with the pressurizing plate that goes under the TBI which stops the fuel from being forced out from in between the the TBI and intake, and it also pressurizes the throttle blade shaft. So I'm going to buy a 454 TBI and see if that can be used with my set-up.
Old Jun 4, 2002 | 01:10 PM
How much did the paxton cost with all of that?
Old Jun 4, 2002 | 03:59 PM
dmair5_0's Avatar
Car: 91 Firebird
I wasn't even aware Paxton had a blower for a TBI! Where did you get it? How much? Do you have a part # from where you got it? Or is it not even offered anymore? Thanks a lot for the help. A blower on TBI is damn cool!!
Old Jun 4, 2002 | 05:57 PM
ChevalierSS's Avatar
r/t .661
60' 2.377
1/8 10.196@68.28 mph
1/4 15.89@86.71 mph
Near stock...Flowmaster cat-back, k&n, functional formula cowl, Jet stage II chip, 5 speed, and 3.08 open differential. I'd like to run again with the posi and 3.42 gears I've got.
Old Jun 4, 2002 | 08:06 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
15.501@87.xx
2.1xx 60'
street tires
4160# with me
other mods in sig.
Old Jun 5, 2002 | 12:43 AM
BahamutRS's Avatar
I know it's not really FAIR, but...
I need to learn how to launch a manual car better; I know I can muster a 2.0 60' on street tires..but...it was my first time down the track with a 'fast' car, and nontheless a stick one...time is in my sig.
Old Jun 5, 2002 | 06:32 AM
My friend with a near stock 2002 pulled a 1.91 on street tires. Are you burning out right? Are you spinning or bogging the car?
Old Jun 5, 2002 | 02:07 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
actually no its not, it sucks.. .wet flow manifolds arent suited to blow through forced induction. As pressure builds suspended fuel has this tendency to condense. The only saving grace is that youd definately wanna run one non intercooled so the heat can keep it vaporized but then you displace more oxygen and power drops. If you are gonna spend money on a blow through blower, get port injection pretty please so you dont make tbi look worse than it allready does because of poor ets on bad combos. Id only run a roots style blower on TBI mainly cuz they are cheap and its not blow through allthough its sort of a moot point because their efficiency sucks. Cheap power though.
a whipple would also work very well but they are a ripoff
Old Jun 5, 2002 | 02:27 PM
Your a pretty knowledge fellow, for a Marine
Old Jun 5, 2002 | 03:56 PM
evil t/a's Avatar
This is what jesse83cfi told me: With these mods he runs a 14.5 @ 3800 (about 13.7 at sea level) oh and this is with Crossfire. So anyone looking for a 13 second 305 tbi recipe should look no further.
83 cfi runs stock 17.0 supposibly at a low altitude
well i live in utah with over 3800 feet above sea level and i am pulling 14.5 at Rocky Mountain Raceway
"slightly" modified.....
hooker headers 1 5/8
cusotm y pipe
high flow cat 3 inch
3 inch exhaust
80 series muffler 3 inch in 2 1/2 out
3.73 richmond gears and new eaton posi
700 r4 with vette servo
trans go shift kit
advanced timing
removed all smog crap
removed a/c compressor and all that stuff
moroso blue max wires
bosch plat 4
kand n filter of course
accel super coil
accel cap and rotor
180 degree stat
stage 2 jet chip
a brand new 305 with 18 k on it
and a 210 degree cam in it with 9.6 compression ratio
thats what i mean when i say slighty modded T/A!
Old Jun 5, 2002 | 11:20 PM
Don't worry Pablo
Pablo is correct, my setup isn't efficient at all. When I bought the kit back in 1999 ($2450, and they no longer make the kit), I didn't know much about modifying cars. All I knew is that superchargers made cars go faster (my thinking at the time LOL). Now since I have it, i'm working with what I have. The 355 I'm building will most likely be N/A, for a little while at least, then it'll be Stealth Ram/Paxton time!
Old Jun 5, 2002 | 11:32 PM
BahamutRS's Avatar
I just suck at driving. I know I can pull a better 60'; it was my first time down the track.
Old Jun 6, 2002 | 10:44 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
13.25 @105 mph is my best. 1.98 60' is my best launch on real street tires.
See Sig for mods.
BTW, this car is for sale. email me at tkendrick@thecanyons.com for pics and more info.
Old Jun 6, 2002 | 02:18 PM
My305camaro's Avatar
in the sig...
Old Jun 6, 2002 | 09:24 PM
mattRS's Avatar
r/t .785
60' 2.302
330 6.544
1/8 10.091
mph 69.27
1000 13.163
1/4 15.767
mph 86.82
3" high flow cat
3" pipies catbck
cutout before crossflow flowmaster
K&N
accell cap and rotor
MSD coil
ram air from TPI car (changing to open element in a half hour)
160 stat
manual fan switch
4"cowl for a little better cooling
monroe shocks and struts
Old Jun 7, 2002 | 05:30 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
I guess it is time to go to the track huh?? I got an pain in my foot now after readin' all that.
Old Jun 7, 2002 | 08:04 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
See my sig for my best.
For reference, I weighed in at a hefty 4400lbs with me in it, so take that into consideration
The launch was on street tires, at street PSI, 3.42 open diff, NO traction problems. Basically nailed it at the green, car squatted and I was off.
Old Jun 7, 2002 | 11:33 PM
Marin's Avatar
0-60MPH in 7.6 secs; with me and my 220# friend in the car and three cases of tools. My car is auto, power windows, power locks and all that bullsh!t (no radio, though)
will measure 1/4 mile after I pass emissions.
Old Jun 8, 2002 | 10:53 AM
rsc350's Avatar
Car: 92 Camaro RS
Old Jun 8, 2002 | 02:23 PM
Marin's Avatar
No , made a run several times with G-Tech Pro. Straight wide road verified no inclines/declines. I guess cowl induction and porting do help. Time before porting the TB and putting different injectors was 8.9, again on the same place.
Old Jun 8, 2002 | 02:40 PM
Marin's Avatar
Here is what I think made all the difference -- the "ultimated tbi". Notice the ghettoness of the job. My motor skills are not the best (pun?).
Attached Thumbnails TOTW: The proof is in the puddin'. Post your 1/4 mile info and mods.-ported_tb_1.jpg
Old Jun 8, 2002 | 02:47 PM
Marin's Avatar
I dremelled it some more after this picture was taken and I also set the whole throttle body on fire the next day (not fun, not cool). Notice that I didn't shave those thingies off completely, like the Ultimate series says I should. Some might say this is more restrictive, but I somehow thought that past 50 or so mph when the air enters it will generate a little turbulence but in general force the air down and prevent the air cushion from forming. I looked at the way the air enters when you have a cowl hood and thought this would be better.. I might be wrong but I don't think so. The spacer that came in Borg-Warner rebuild kit is also a little thicker than the stock one.
So, again:
0-60MPH
before: 8.9 secs (w/ 1 leaky injector), suboptimal weight
after: 7.6 secs (different injectors, still GM stock), suboptimal weight
G-Tech Pro'ed several times
Attached Thumbnails TOTW: The proof is in the puddin'. Post your 1/4 mile info and mods.-ported_tb_2.jpg
Old Jun 9, 2002 | 11:39 PM
RSFreak's Avatar
Transmission: TH700R4
Best:
16.57@80mph
Open element w/ K&N, high flow cat.
No new mods so I haven't been back to the track.
Old Jun 19, 2002 | 12:44 AM
Mr300's Avatar
see sig...
2.247 60' on that run (seems good to everyone elses 60' and 1/4 mile)
Old Jun 19, 2002 | 12:48 AM
Mr300's Avatar
well for some reason my sig didn't show up...
1991 Firebird 5.0 TBI
all stock
best run - 16.403 @ 81.75 MPH
Old Jun 19, 2002 | 04:42 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
91RS 700R4 2.73 REAR (OPEN) I DONT REMEMBER MY WHOLE SLIP BUT I REMEMBER I RAN A 16 FLAT BUT I AVERAGED LIKE 16.1'S ALL THAT NIGHT HAD LIKE 95,XXX ON IT THEN
MODS: FLOWMASTER MUFFLER (FACTORY PIPES FRONT TO REAR)
Old Jun 19, 2002 | 07:21 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
That must be one helluva motor then.
All I remember about mine, is that by best time ever is a 16.5 at like 80.2 MPH with a 2.4 60'. soon to be a lot quicker, just got the SLP headers ordered today MUAHAHAHAHA.
Old Jun 20, 2002 | 12:33 AM
esmartuek's Avatar
Car: 87 Camaro LT
Engine: 305 4BBL
dude, that guy in Utah, I gotta check out that car...
At least give me an idea of how bad my car will do this next wednesday during the test'n'tune over at Rocky Mountain Raceway.
-ET
'87 Sport Coupe LT T-Top
Automatic 2.73 posi
305ci TBI
crappy tires (good as slicks, though)
57,000 miles
Mostly Stock
only changes done to my knowledge are that I added some engine restore and slick 50.. and gave it an all around good tuning. (hey, it beats the rice rockets on State St.... but so does my mom's Buick [which I envy so much!])
Old Jun 24, 2002 | 11:28 AM
14.88 @ 91.7mph
2.23 60'
Old Jun 24, 2002 | 02:29 PM
Just put down my fastest time ever on Fri...
14.733 @92.87 :lala:
Old Jun 25, 2002 | 06:52 AM
Makes me sick. We have pretty similar mods, and I have 3.42 posi, and you are cutting better 60's. I bet you could cut a 2.1 in my car, it's probably the driver .
It was nice to meet you though dude. Are you going to the Fbody cruise? It should be a lot of fun.
Old Jun 25, 2002 | 01:29 PM
I have not heard about it...when/where is it?
I don't know why you don't have better 60ft. times...do you spin off the line?
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
69 Six Pack
Oct 5, 2015 07:51 PM
z28_AJ
Aug 27, 2015 08:59 PM
NBrehm
Aug 5, 2015 07:57 PM
