I can't find a home for this connector!
Old Jul 15, 2002 | 11:46 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
While just messing around with my car the other day I found a 2 prong weather-pack connector that isn't connected to anything. I found it dangeling at the back of the block on the drivers side. It is obviously part of the stock harness and has a black wire and a pink one with a black stripe. Does anyone know where this goes or at least what system it's for. Please see sig for app.
Please Help:hail:
Old Jul 15, 2002 | 12:23 PM
camaroguy99's Avatar
Does it look like it belongs behind the engine? The only thing I can think of is the canister purge or whindshield wiper fluid pump. But those are all the way in the front of the engine compartment. There is the distirbutor 2 wire connector but it's not pink/black and your car wouldn't run without it. HTH
Jim
Old Jul 15, 2002 | 01:36 PM
Car: I
Engine: Taunt
The reach isn't hardly long enough to even get it above the engine, let alone all the way around to the front. I think you may have something though, my windsheild washer doesn't work. There isn't a connection for this on the fire wall somewhere?
thanks
Old Jul 15, 2002 | 02:33 PM
Ok I went out and looked at the engine. The only pink/black and black combo I found was the A.I.R. pump control. Is it a green connector? This is on the pass. on mine and towards the front, but I bet thats what it is.
Old Jul 15, 2002 | 08:19 PM
Car: I
Engine: Taunt
I do have the A.I.R. disconnected on my car but I am familiar w/that connector and it isn't it, mine is in the front on pass side also by the way. I lthink you might have been right w/the washer fluid motor because it is in that general area and that doesn't work on my ride. Where is this motor and/or the connections for it? Anyone know?
thanks again
Old Jul 15, 2002 | 08:29 PM
The fluid pump is attached to the tank on the pass. side in front of the Strut tower. I has a solid red and a solid blue wire attched though. Ok, last one then I'm stumped. If it's behind the engine, what about the oil pressure switch right above the oil filter? Good luck
Jim
Old Jul 22, 2002 | 12:51 AM
SlickWillie's Avatar
I got the same thing disconnected on my car and cant figure out what it is and my windshield wiper motor works.
Old Jul 22, 2002 | 07:57 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Dustin, I have the same car as you and the same connector disconnected. ( same length, color and location ) If you ever find out what it goes to please post back, I'll do the same as well.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
TheJoeY88
Dec 31, 2016 07:30 PM
