Pics, Cam Swap is Done
Old Aug 6, 2002 | 07:37 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Finally finished the cam swap. Also added the Weiand Stealth intake, Summit roller rockers and Pete Jackson Gear drive. I need to buy a shorter KN filter now my 4" don't fit. And I need to get new wires so I can't really drive it right now. But it sounds awesome, I'll get a soundclip in a few days. Here are some pics.
Some Junk that was cluttering things.
Old Aug 6, 2002 | 07:39 PM
Car: 99 Formula
Axle/Gears: 342
Engine Pic 2
Old Aug 6, 2002 | 07:41 PM
Car: 99 Formula
Axle/Gears: 342
Valve Covers Say Bad Bowtie
Old Aug 6, 2002 | 07:42 PM
Car: 99 Formula
Axle/Gears: 342
Cleared out some wires from the back.
Old Aug 6, 2002 | 07:49 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Definately get some sound files from in front and behind your car. I'd really like to hear the gear drive and the lope of a cam through hooker aero-chambers (something I've yet to experience ...but soon! few more weeks)
Old Aug 6, 2002 | 07:51 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
That's one of those engine bays that makes it sad to have a hood
:rockon:
Old Aug 6, 2002 | 08:29 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
Looking really good. Now I know you will be showing off at the next meet.
Old Aug 6, 2002 | 09:40 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
that looks freakin nice Mark.
Brian
Old Aug 6, 2002 | 10:05 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
i noticed in your pile of EXTRA things, you had the charcoal canister, what did you do with the vent line from the fuel tank?
i also notice that there are no wires at all coming from the passenger side fender, are they all completely unnessecary?
i want to do some of this clean up on my car, but i can't tell much from wiring diagrams(i hate those things), and people give me conflicting stories,
i also noticed that you apparently just cut most of the ac box off, will the heater still function properly, or are you going to construct some sort of duct ?
Old Aug 6, 2002 | 10:13 PM
Car: 99 Formula
Axle/Gears: 342
To answer your questions.
1. The wires from the pass fender are routed under the heater box now.
2. the charcoal canister line is plugged off now
3. the heater box, will have a custom made air duct made from sheet metal so the heat still works. Do a search on this board for custom made box, I posted pics of it, but it's not complete.
Old Aug 6, 2002 | 10:48 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Very nice, Mark!
You have done an excellent job and it looks pretty impressive
Old Aug 6, 2002 | 10:52 PM
Hg's Avatar
Hg
Car: '87 Z
So you don't even need the charcoal canister? it's not dangerous not having it or nething? hrm....
also thought of something, you need to clean your engine bay with some simple green or something... it's not looking right with a nice shiney engine and dirty engine bay... although it does make the engine look like a diamond in the ruff.
Old Aug 6, 2002 | 10:55 PM
Car: 99 Formula
Axle/Gears: 342
I thought Vader said we did. But my brother took it out neways. Some lines weren't even hooked up.
I plan on taping the engine off sometime and sprayin the bay a flat black.
Old Aug 6, 2002 | 11:07 PM
MdFormula350's Avatar
great job Mark, looking nice :hail:
Old Aug 7, 2002 | 06:38 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Lookin' good man
Old Aug 7, 2002 | 06:46 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Hey mark this is a totally off the wall question, but I notice you're running a 600 edlebrock on that thign. I've got a similar 350 in my GF's camaro with that carb........having a hard time getting it jetted right. Is yours jetted stock or what? How's it run? Engine looks great. And where did you get that heater box thing?
Old Aug 7, 2002 | 07:04 AM
Car: 99 Formula
Axle/Gears: 342
I'm using the factory jets, we'll see how it goes.
The heater box thing, my brother made out of sheet metal.
Old Aug 7, 2002 | 07:41 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
nice job.
Im planning on getting rid of my TPI, and going carb. What filter are you going to run. I am worried about clearance with the hood.
I may have to get a cowl hood to run the intake I want.
Old Aug 8, 2002 | 12:38 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Lookin GOOD!!!!!
I hate Edelbrock carbs though. I had one on my 72 Charger with a 360, and the thing never ran worth a sh*t till I got a Holley.
It was a more expensive carb back then too.
Not say'in they totally suck, but I've never had luck with them.
Again - everything else:
Old Aug 8, 2002 | 02:25 AM
TBI305Camaro's Avatar
Damn looks good. I bet the car runs ALOT better without that tiny cam it had on it. What intake was on it? Id say you should have some good times if your tranny is up to it (isnt it slipping or something)?
Old Aug 8, 2002 | 03:32 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Looks great Mark...one of those lines to your cannister is your fuel tank vent line, you need to keep it open.
Old Aug 8, 2002 | 08:24 AM
Car: 99 Formula
Axle/Gears: 342
I had the stock LG4 aluminum intake on it. Yes, my tranny is slipping still I plan by winter to have that fixed.
Riley??? Which line do I need to keep open? If I take a pic could you circle the line for me?
Old Aug 8, 2002 | 08:45 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Mark,
Engine looks really nice, but when you took off the charcoal canister there is a hard line from the gas tank that went to the canister, this needs to open not blocked.
Old Aug 8, 2002 | 08:55 AM
onebad82z's Avatar
Car: 1982 Z28
Axle/Gears: 12 Bolt
On your car you had the two fuel lines on the passenger side frame rail to connect to the pump,one feed and one return for the factory pump,now look on the driver side frame rail.There is a metal line that should run right next to the strut tower/fenderwell,and about 4 inches from the end of that hard line it kicks up into the air in the direction of the fender...that is your fuel vent line that went to your charcoal canister..this line must stay open to the atmosphere to allow your tank to vent.On my Z I removed that entire hard line (to clean things up further) all the way back to the sending unit hard line back at the tank,where all the lines splice to be able to remove the tank.It has been that way for 6 years now with no problems.
Old Aug 8, 2002 | 09:49 AM
Car: 1984 Firebird
Axle/Gears: 4.10
so that vent line can be completely removed from the engine bay area?, and just leave it open back near the tank?, do i need to put any kind of a vent cap or something on it to keep the crud out of it?
Old Aug 8, 2002 | 10:05 AM
onebad82z's Avatar
Car: 1982 Z28
Axle/Gears: 12 Bolt
Yeah..remove it totally,unless you plan to put emissions back in one day..imagine that lol.I left mine open for the last 6 years and no crud or crap has gotten into it yet.
Old Aug 8, 2002 | 12:45 PM
IwantanFbody's Avatar
shorter air filter??? I say get a cowl hood!
Old Aug 8, 2002 | 02:02 PM
Nasty_Bird_'90's Avatar
I still have the Fuel Injection on my car, but have removed my emissions. Can i pull out my canister? Some say yes, others say no. Which is it? Will it kill my mileage or make the car run different?
Looks good Mark. Can't wait to see it next weekend. Hope the weather is good though
Old Aug 8, 2002 | 04:39 PM
MouseCamaro305's Avatar
when l swapped the 350 into my camaro l pulled the canister and l took a vacuum T cap and slipped it over the hard line, after running it, l removed the cap and it took in a lot of vacuum. l just left the line wide open, no problems with it yet.
excellent work mark.
Old Aug 8, 2002 | 05:22 PM
Car: 99 Formula
Axle/Gears: 342
You do realize it's on the 24th not the 17th right. Remember I had to change it cause of Twist gettin married. I hope no one else has gotten confused.
Old Aug 8, 2002 | 05:53 PM
Engine: 406
Looks like its been covered pretty well, Mark. Let me know if you need more help.
Old Aug 8, 2002 | 06:32 PM
FLYNLOW92rs's Avatar
Looks good......
shorten air filter?? There's the excuse you need to buy a new hood........
Old Aug 8, 2002 | 07:14 PM
Marc 85Z28's Avatar
Don't just let it vent into the engine bay or above the tank. Do it the right way. Cap off the line in the engine bay and buy a pressure relieving gas cap - like the factory used to do.
Old Aug 8, 2002 | 09:09 PM
Car: 99 Formula
Axle/Gears: 342
Originally posted by FLYNLOW92rs
Looks good......
I'd like the SS hood, but I'm broke now.
Old Aug 8, 2002 | 09:12 PM
Car: '89 IROC-Z
::evil chanting:: sounds sounds sounds sounds
Old Aug 8, 2002 | 09:23 PM
Car: 99 Formula
Axle/Gears: 342
OMG, dropped the idle to 650 and sounds fricken awesome. But that's in D, for some reason in P it's at 1k, so need to change that. But I'll most likely get a clip tomorrow for ya guys.
Old Aug 9, 2002 | 03:42 AM
Engine: 406
They dont make them for our cars.....Vented caps......the fuel system needs pressure ....keep the vent line open.. about the worse thing that will happen is, you may get a fuel odor(sp) once in awhile. I left mine open, with a Malory 3 port. No problems to date.
Old Aug 9, 2002 | 02:20 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
sweet setup there mark
Old Aug 9, 2002 | 03:22 PM
84TransAm's Avatar
So get to driving this bad boy, break it all in then dog it and tell us what times your getting!! Would be sweet if it does drop a whole second of your ET like planned.
Old Aug 17, 2002 | 01:34 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Hey Mark... I'll give ya hehe. Looks badass. No more computer for you then? Lucky SOB Now if I can only get mine running right
Later,
Harry
Old Sep 9, 2002 | 10:40 PM
johnyIROC's Avatar
What are the consequences to leaving the line plugged? I have had mine plugged for the last two months. The gas tank hisses big time when I fill up.... but does it matter? LS1s hiss like a ****!
Old Sep 10, 2002 | 04:09 AM
Engine: 406
You will be putting alot of strain on the fuel pump..it has to work extra hard to pump the fuel out of the tank with no vent...and you DONT want to be changing the FP any time soon.....I suggest letting it vent.
Old Sep 10, 2002 | 09:07 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
By plugging the vent line, you are not allowing air to displace the fuel being pumped out of the tank, creating a vacuum. The fuel pump will have to work harder to pump the fuel since there is nothing to displace it with. Get a 1 Liter coke bottle, punch a hole in the cap, and in the bottom of it. Fill it with water (while holding your finger over the bottom hole), put the cap on, and turn the bottle over. Notice very little, if any, water comes out. Take your finger off the hole (aka. the vent tube on your fuel system), and wha-la, you got flow. You might want to find another way to mount the charcoal canister (in the rear of the car maybe?), or just leave the vent line open as Riley's35089rs+ suggeted.
Old Sep 10, 2002 | 10:12 AM
Car: 99 Formula
Axle/Gears: 342
Mine is open now, and will leave it that way, unless something blows up.
Old Sep 10, 2002 | 10:26 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Why did you get rid of the vacuum reservoir tank? It sits out of sight and serves a purpose.
Old Sep 10, 2002 | 10:41 AM
Car: 99 Formula
Axle/Gears: 342
Is that what that was? Hmm, my brother was just rippin stuff out. I dared not touch anything, cause my luck, I'd pull something out and the car wouldn't start.
Old Sep 10, 2002 | 01:16 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Originally posted by bluegrassz
nice job.
You might be about to swap or buy a hood off of ebay for what that TPI is worth. I know someone selling one a little more then a G. Such a rip though..
Old Sep 10, 2002 | 02:28 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
looks like you could cook eggs on that thing.....very clean.
Old Sep 10, 2002 | 02:29 PM
Car: 99 Formula
Axle/Gears: 342
Thank you, now I just need to rip the engine out to paint the engine bay.
Old Sep 10, 2002 | 02:41 PM
MetKiss316's Avatar
Wheres the sounds, postwhore?
