Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
I'll throw in a "$HIT!" and a "WOOHOO"
Old Oct 20, 2002 | 06:16 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
My project for this weekend was to take off each of the wheels, tape up the lip of the wheel well and then paint the wheel well interior black to give the wheel well a cleaner look.
Well, the "$HIT!" part is that THIS didn't happen. I went to Canadian Tire to buy this "+" shaped tool that is suppose to get the lug nuts off. Unfortunately, the strength of me and 2 of my friends couldn't get those dam lugnuts off!!! I couldn't undo even one! I tried everything, but I guess my mechanic used his little power gun and tighted those bolts way too hard.
Any ideas how I can get them off?
My second project this weekend was to take off the TBplate, and polish it to a chrome like finish. Well, sort of worked and sort of didn't. I polished it up pretty good, but there were still some deep scratches in it. What did I do? I did what I wanted to do! I went and bought some metallic blue paint to match the exterior of my car, and sprayed the entire TBplate metallic blue. Sofar looks cool drying! Let's see how it'll look on the car!
Old Oct 20, 2002 | 06:42 PM
trigger GTA's Avatar
Car: 92 TA vert
all you need to do is turn it the other way and it will come right off
painting your TB plate? hmmmmmm where have i seen that
oh ya
Attached Thumbnails I'll throw in a "$HIT!" and a "WOOHOO"-project0154assembled-engine.jpg
Old Oct 20, 2002 | 07:20 PM
darbleinad's Avatar
Car: 84 Trans Am
are you some kind of moron?
Old Oct 20, 2002 | 07:35 PM
johnyIROC's Avatar
Tighty righty
Loosy lefty
Old Oct 20, 2002 | 07:39 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
c a n ' t s t o p l a u g h i n !!!!
Man I can't stop laughing !!!!
Old Oct 20, 2002 | 07:41 PM
dude i'm telling you the nuts are too tight, i've had everybody try, nobody can take them off by hand!
hey trigger, did you powdercoat your runners or paint your runners? I was thinking of painting my runners blue this week. will that work?
Old Oct 20, 2002 | 07:43 PM
darbleinad's Avatar
Car: 84 Trans Am
ever thought of putting a breaker bar on a rachet and trying that? some penetrating oil would help things too. maybe you should just stick to the basics, liking putting stickers that look gay on your car.
Old Oct 20, 2002 | 07:58 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
You must be turning them the wrong way. They can't all be that tight.
Old Oct 20, 2002 | 08:03 PM
Car: 92 TA vert
painting them will work fine
brad lay off man.. everyone has to lean. it seem he is trying to learn. cut him some slack
Old Oct 20, 2002 | 08:34 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
Alex, try putting the wrench on the lug nuts and then try and stand on the wrench at the end farthest away from the nut. The torque on that nut will equal what ever your weight is, in ft/lbs (provided the wrench is 12" long). I think you only need to tighten them to 90 ft/lbs or so. Most air driven impact guns can tighten nuts to around 240 ft/lbs or so.
If your car has the jack in the trunk of the car, use the wrench that comes with it. You can fit a pipe on the end of that one more easily than those 4 in 1 wrenches.
The other guys have already mentioned it, but to tighten the nut, turn clockwise, to loosen, turn counter-clockwise.
PS - you are trying to loosen them with the car on the ground right?
Old Oct 20, 2002 | 09:11 PM
Slade1's Avatar
dear ***.. our lugnuts are only supposed to be tightened around the 70 ft/lb range (something from auto shop class a long while ago)
Alex on the other hand couldn't get off a bolt hanging on to his coolant overflow bottle... hmmm lol
If you want, I can take a shot at it tomorrow afternoon.
Old Oct 20, 2002 | 10:52 PM
Brad: I could say something, but you've already shown how mature you are so I won't bother stooping down to your level.
Everyone else: Thanks for the ideas... The 4-in-1 thing didn't work no matter how hard anybody tried. My mechanic uses that power gun so they're on super duper tight.
I'm thinking I'll try a rachet tomorrow, but I'm not sure whether or not I have one that big, gotta check!
TRIGGER:
Did you paint your runners or did you powdercoat them???
If I do choose to paint them, do I have to sand them down beforehand? I figure I won't, because the paint will dry smooth overtop of the roughness???
Old Oct 20, 2002 | 10:54 PM
Car: 92 TA vert
i just painted them. you should still lighly sand them to help the paint hold. 400 would be fine
Old Oct 20, 2002 | 11:04 PM
ninety1TAgta's Avatar
If its any consolation to the ridicule alex, your posts always give me a good laugh. But anyway you need to sand the TB down you cant just polish it. If you just polish it, it will be shiny but not a smooth finish.
greg
Old Oct 20, 2002 | 11:57 PM
ok i'm going to do it this week.
one question scott... how did you exactly paint the runners? did you just lay them on some newspaper and paint every piece of metal you saw? or did you hang them up somewhere and paint them? what'd you do? only reason i ask is because i'm using the "motomaster perfect gm match" paint from canadian tire, and although it's not a perfect match it's pretty good paint. but i did notice that it's a little "runny" shall i say? how did you keep the paint from running and dripping, etc...
Old Oct 21, 2002 | 12:16 AM
Sinoed's Avatar
Its supposed to simulate something 'close' to real automotive paint (if that can actually be achieved from a can). Just spray a couple of very light coats letting it dry in between & you'll be fine. If Rovic can't get the lugs off for you let me know, I've got an impact gun I can take them off with.
Old Oct 21, 2002 | 06:25 AM
IROCKER's Avatar
No offense Easy, but painting the runners is not hard but for someone who's having a hard time getting lug nuts off?!? Just removing the runners alone is a couple hours work. Then prepping and stuff...it's a cool project, but it may not be as simple as you think.
Old Oct 21, 2002 | 06:44 AM
Car: 92 TA vert
you might want some help with that one. it will take some work and tools to remove the runners.
i painted then just like you see in the pic. i have paint mixed to match and used a paint gun.
Attached Thumbnails I'll throw in a "$HIT!" and a "WOOHOO"-project0114runners-clear-coated.jpg
Old Oct 21, 2002 | 07:15 AM
KWF's Avatar
KWF
So pretty.
:hail:
Old Oct 21, 2002 | 08:28 AM
Acceld Z's Avatar
Car: 1992 Z28
Pot
Kettle
Black
If the lugs are on that tight, be careful. You may tear up or break the wheel stud getting them off. Using an air gun on alloy wheels is teh st00pid.
Old Oct 21, 2002 | 08:47 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I always use a gun to tighten my wheels except its on a low setting..lol
From a tire wrench to a ratchet??Use a stubby box wrench instead??lol
Seriously get a pipe at the end of the cross tire wrench as leverage..then break that stud!!!
Daz
Old Oct 21, 2002 | 10:19 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
CTC paint is garbage..anybody else try to use the touchup stuff and have it fall back off??
Do your self a favour and get a custom spray bomb made in any colour at a REAL autobody paint shop. Should cost about $20.
Well worth it.
The wheel nut torque is 80lbft in our cars. Air guns are trouble!! You can actually warp rotors by overtorquing the wheel nuts with them.
Old Oct 21, 2002 | 05:17 PM
Well worth it.
l
l
Old Oct 21, 2002 | 05:33 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
easySPEEDcamaro.
I have been down the road of tight nuts(!) before many times. Using a long pipe on the end of a ratchet spells death for ANY ratchet. They are not designed to do this. A 24" breaker bar works wonders. BUT, if I were you, I would take the car back to the place (or another place) that used the airgun in the first place. I have an air gun that loosens up to 600 lb ft, so a shop airgun will loosen them for you with no problemo. Then use a torque wrench to tighten them back up again properly. Then drive back home.
Hope this helps.
Andy.
Old Oct 21, 2002 | 06:25 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Have someone losen them with an impact gun as mentioned above otherwise there's good chance you and your friends will twist the studs right off. Happened to me once just using a 4 way tyre iron.
Old Oct 26, 2002 | 12:29 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
http://www.motorsportconnect.com/car...e/Protege1.WMV
The infamous "Special Day" car.
(Not lugnuts, but close enough. )
Old Oct 26, 2002 | 02:25 AM
lol i still can't stop laughing. thanks for the good one
Old Oct 29, 2002 | 01:28 PM
justadba's Avatar
Car: 88 IROC convertible, 88 Sport Convertible---both RED
Engine: 350 TPI in the IROC, 305 TBI in the Sport
Transmission: 700R4 in both
Broke 3 of the 3" socket extensions trying to get one of my lugnuts off..(NO none of the extensions were snap-on, craftsman, husky, mac or any other name brand---came out of several tool kits I have that are either Made in Taiwan, R.O.C, Japan, etc....)
.some moron obviously torqued it with an impact gun....took it to Discount Tire and told them I had a slow leak in the tire (they fix flats for free) also asked would they change the oddsize lugnut I had on there with a new one I gave them. 3 nuts were SAE size and one was an 18MM naturally the 18MM was the super tight one. 5th one is a locking nut
Old Oct 31, 2002 | 11:00 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I'm 39 seconds into the video, and I'm expecting the tool to break and he falls on his head.
Fanatic1074
Oct 3, 2022 05:57 AM
apie2546
Oct 16, 2016 02:24 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
ndndndnd
Sep 28, 2015 08:00 AM
